Jrb572 Samba Member
Joined: August 30, 2013 Posts: 191 Location: St. Louis
Posted: Fri Oct 30, 2015 3:10 pm Post subject: 36 hp oil cooler |
I am just about done rebuilding my 36hp. I was thinking about the oil cooler. Should I have it boiled out? I put fresh oil in it. Then turned it upside down again. It appears to have not huge but some type of chunk that comes out with the oil. Any ideas? I was looking to possibly move up to a 356A oil cooler. But they look super expensive. |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
morymob Samba Member
Posted: Mon Nov 02, 2015 6:29 am Post subject: |
Being otta sight, i used a later better one in my 57. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69804 Location: Phoenix Metro
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Mon Nov 02, 2015 2:52 pm Post subject: Re: 36 hp oil cooler |
Jrb572 wrote: |
Was it the oil cooler on YOUR motor? Was the motor running, or did it blow up and fill the cooler with metal? |
Jrb572 Samba Member
Posted: Mon Nov 02, 2015 8:09 pm Post subject: |
There was a wrist pin knocking. But the motor had been sitting for sometime before I put about a 100 or so miles on it. I went ahead and ordered on from someone on here that had one that was cleaned and pressure tested. It was $36. Figured it would be best to not reuse it. |
Posted: Tue Nov 03, 2015 5:42 am Post subject: |
Spelled out: OIL COOLER! |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Nov 03, 2015 6:47 am Post subject: |
So what is the difference in the OIL COOLERs
is the question ask. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Fri Nov 06, 2015 4:13 pm Post subject: |
EverettB wrote: |
Yes, if this was not clear - what is different about the "later better" oil cooler? |
The oil cooler was shortened, the number of tubes reduced from 36 t0 32, they were brazed instead of soldered, painted black instead of silver. I don't know if any of the changes resulted in better performance. Perhaps if anything slightly better airflow to the cylinders and heads and fewer leaks but I'm just guessing.
Edit: Also the early ones win the oil cooler beauty contest hands down.
tobiasax Samba Member
Posted: Sun Nov 08, 2015 2:01 pm Post subject: |
Snort wrote: |
EverettB wrote: |
The oil cooler was shortened, the number of tubes reduced from 36 t0 32, they were brazed instead of soldered, painted black instead of silver. I don't know if any of the changes resulted in better performance. Perhaps if anything slightly better airflow to the cylinders and heads and fewer leaks but I'm just guessing. |
My thinking is that the changes were made to improve durability. Pre-early-1957 coolers had problems with cracks and leaks. The new design proved to be so good it was used by VW until 1970 when the engines did have 1500 cc and lots more hp. My belief is that the 57-70 oil cooler is good enough for a street driven hopped-up 30/36 hp engine. _________________ __________________________________________ |
Posted: Tue Nov 10, 2015 9:04 am Post subject: |
tobiasax wrote: |
Snort wrote: |
EverettB wrote: |
My thinking is that the changes were made to improve durability. Pre-early-1957 coolers had problems with cracks and leaks. The new design proved to be so good it was used by VW until 1970 when the engines did have 1500 cc and lots more hp. My belief is that the 57-70 oil cooler is good enough for a street driven hopped-up 30/36 hp engine. |
To clarify for myself:
Are we talking about the change from the "dome" oil coolers to the later style or ? _________________ How to Post Photos
Snort Samba Member
Posted: Tue Nov 10, 2015 3:34 pm Post subject: |
EverettB wrote: |
Are we talking about the change from the "dome" oil coolers to the later style or ? |
I made that assumption, so seeing no other comments to the contrary I would say yes. |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Mon Nov 23, 2015 10:17 pm Post subject: Re: 36 hp oil cooler |
Buy a new one. I saw a picture where someone sawed off the top of the cooler after having it professionally cleaned. There was enough &^%* in the cooler to ruin 10 engines.
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Tue Nov 24, 2015 11:59 am Post subject: Re: 36 hp oil cooler |
I used the one from the link to Wolfsburg West.
The only key item being, you must use the "Green" oil cooler seals. They are designed to use this cooler on the early engines. 8mm ports to 10mm ports.
If you use the early seals (black cylinders) they will leak immediately and you will have a heck of a mess...don't ask how I know this |
My57Oval Samba Member
Posted: Sun Feb 14, 2016 7:36 pm Post subject: Re: 36 hp oil cooler |
http://www.nlaparts.com/store/aluminum-cooler-p-691.html
Is this cooler the same basic dimensions as stock for say ,a '57 36HP motor?
Because if not, and it is taller or will block air flow to #3, than you may have cooler oil but higher head temperature right?
Rob |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
