Merian Samba Member
Posted: Fri Nov 06, 2015 5:01 pm Post subject: Fuse & Relay Panel - more hacks by a PO |
I found these empty crimp on taps on red/gray and black/gray wires. Any ideas on what this PO could have been up to?
Like using a sharp probe, these things pierce the insulation, but are worse, as they can cut into the wire itself. OTOH, I usually figure it is worse to remove them than to just leave them there.
thoughts?
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Merian Samba Member
Posted: Fri Nov 06, 2015 5:58 pm Post subject: |
all I know is that when I took the pic, I made a note that this is of the "lower LH corner"
no idea if that is from the front or the back |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Fri Nov 06, 2015 6:00 pm Post subject: |
The color of each of the plastic connector blocks is unique and spelled out in the Bentley. That color along with the wire colors should make it simple to figure out what those wiring taps connected to.
Mark |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Fri Nov 06, 2015 6:13 pm Post subject: |
Looking closely, I don't see any 3rd wire sticking out of those "fire hazard" crimps. At this point, if they're not being used to splice or t-tap the wire, removing them or not will have no real effect. If they are being used to splice or t-tap, I would suggest replacing them. Personally, I always solder and shrink wrap connections, others may suggest a good quality crimp fitting. YMMV _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Posted: Fri Nov 06, 2015 7:03 pm Post subject: |
The grey/red and grey/black with the added taps are the wires to the front parking lights, right and left.
It looks like another one of those taps is hiding there too.
Since nothing it hooked to them I would just leave them alone.
Mark |
Merian Samba Member
Posted: Fri Nov 06, 2015 7:06 pm Post subject: |
Thx.
seems odd, what would somebody power off the front parking lights? |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Fri Nov 06, 2015 7:43 pm Post subject: |
Those are 3M T-Taps. Removing them will do more damage than good.
I have seen people power fog lights from those wires. Bad idea, but not that out of the ordinary... _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
Merian Samba Member
Posted: Fri Nov 06, 2015 8:16 pm Post subject: |
hmmm... it has added driving lights, so maybe that was an initial attempt by a PO, and later changed
not sure where they originate but they are on a relay now |
david2676 Samba Member
Joined: September 06, 2008 Posts: 452 Location: san jose, ca
Posted: Sat Nov 07, 2015 9:35 am Post subject: leave them |
those are likely from the PO installing some type of electronics ..radio gauges whatever .. take a meter and see if they are hot .. Key one or off ect .. or trace down the wire and see what wire they tapped into. it might give you place to add some gadget in the future. It will not hurt at all to leave them. removing it will leave a small pin hole. Not much to worry about. if it were me i would wrap its with tape.
this is really common on used cars likely they had a stereo installed and this is what is left. _________________ 64 bug
91 Vanagon/ Subaru swap Westfalia |
