BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Wed Nov 18, 2015 10:04 am Post subject: Re: Middle seats |
EverettB wrote: |
I checked my '55 Bus and it has the same round head fastener above on both sides of the fold-down. |
Which same above: shouldered or wiped out threaded ones? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Wed Nov 18, 2015 5:43 pm Post subject: Re: Middle seats |
BarryL wrote: |
EverettB wrote: |
Fully threaded, I added a pic to my post above to be 100% clear.
The shouldered one above is the screw for the front seats.
Middle seat
Front seat
_________________ How to Post Photos
lumber-baron Samba Member
Posted: Thu Nov 19, 2015 9:05 am Post subject: Re: Middle seats |
I'm getting ready to upholster my middle seat and am hoping someone can explain how the back is assembled. I've scrolled this entire thread and it's partially addressed on page 27 that there is a card installed under the cover. My question is how is the seam at the bottom of the back cover joined to the front cover where it comes around the bottom of the frame?
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4186 Location: Boston, MA
Posted: Thu Nov 19, 2015 3:31 pm Post subject: Re: Middle seats |
lumber-baron wrote: |
Both ends of the upholstery cover tuck into the lower rear frame tube, that has a slot in the back of it to tuck the ends in. Here are a few pix of a seat that I restored recently in my shop.
Middle seat backrest cover in place for final pull.
Back and front portions pull and tuck into this little slot in frame.
It was a very tight squeeze, especially the areas around the middle leg that my upholstery guy modified/reinforced.
Finished tuck.
_________________ Stan's Classic Service, specializing in air-cooled VWs:
http://www.thesamba.com/vw/classifieds/detail.php?id=614073
www.stanagon.com
My '61 Mango bus thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=110367
My '64 vert thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=386344
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709
Posted: Thu Nov 19, 2015 6:38 pm Post subject: Re: Middle seats |
This is a 1966-ish bus middle seat that I restored in my shop.
Seat covers and coco pads are from Wolfsburg West. Covers are actually TMI, I think. I used wire wherever possible, instead of string, to anchor seat covers to frames. Some modifications were necessary to make covers work with pre-'67 seat.
Frames and springs were repaired, using an early bay window front seat for replacement middle seat backrest springs that had rotted. Frames and spring sets were de-rusted, primed and painted.
Seat springs were covered with burlap (dark brown color) hog ringed to springs, coco pads (light brown color) and batting (white color).
Original grab handle was re-used with new ends and center cap.
Before:
Broken backrest springs.
Bay window donor seat.
Replacement springs (4) installed on left side of backrest.
Outer frame was also reinforced using sections of frame sandwiched on with metal clips.
The 'tuck' slot was straightened and cleaned as best as possible.
Frame painted.
Burlap over springs to protect bottom sides of coco pads.
Batting was placed over coco pads and tucked into springs. You can also see pull wire here, which replaced flimsy string, as supplied.
Seat bottom cover is on.
Ashtray mount dimensions on backboard.
Upper screw was added to hold new backing panel to seat frame.
Reinforcement plate for ashtray mount, on inside of backboard.
I re-used the original mount plate after rust treating and fresh paint.
We all know how this part works.
Pulling and tucking backrest cover is hard work on the fingers.
This shows the modifications I had my upholstery guy stitch up to make the seat cover work with a pre-'67 seat.
Customer ordered '67 seat covers, but middle seat is actually a '66 or earlier model with slightly different seat leg locations than the '67 seats.
Original grab handle was cleaned and re-used. New end caps and center cap are from Brad "volksheime"; http://www.thesamba.com/vw/classifieds/detail.php?id=1411448
www.stanagon.com
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Thu Nov 19, 2015 7:31 pm Post subject: Re: Middle seats |
Nice work, Stan.
Need some overall pix of the completed seat! _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Fri Nov 20, 2015 11:51 am Post subject: Re: Middle seats |
EverettB wrote: |
2Pack wrote: |
EverettB wrote: |
Anyone know if the middle seat screw above is correct |
I have a seat with the same fastener. M8X1.25 X 18mm thread length, threaded along entire length. The other fastener from the same seat is a hex head. It is an early seat. I have seen photos of other early seats that have a hex head fastener. The thread is the same though.
Later seats I've seen have two with a head like the one you posted. Not sure when the change was or if it was consistent. |
Thanks.
I have seen some seats with normal hex heads bolts too but I always figured those were replaced because they fell out. My other '63 seat, which has been recovered, has a bolt in it like that.
I checked my '55 Bus and it has the same round head fastener above on both sides of the fold-down. It's the original seat and I believe they are original.
This style
Sorry to interrupt the rebuild conversation, but just wanted to comment that Everett's explanation makes alot more sense. I agree that the hex headed bolts are probably random bolts people replaced originals with. I've only seen a few hex heads and if an original needed replacement it makes sense that it would be a hex. Also, why would VW use two different styles? _________________ Please buy my Treasure |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Fri Nov 20, 2015 12:07 pm Post subject: Re: Middle seats |
Stanagon wrote: |
We are still looking for a source, or solution for the armrest pad on this seat. |
GREAT work on this seat. My 2/3 middle is sitting downstairs, painted and ready for upholstery. I'm psyching myself up for the job, knowing how the front buckets were to do.
Stan, what card did you use for the seat back insert, and where did you get it?
Also, I have my arm rest remains sitting on my coffee table, pondering solutions. Will start experimenting soon and post any reasonable (or really terrible) results. |
Posted: Fri Nov 20, 2015 5:50 pm Post subject: Re: Middle seats |
2Pack wrote: |
EverettB wrote: |
2Pack wrote: |
EverettB wrote: |
Thanks.
This style
Sorry to interrupt the rebuild conversation, but just wanted to comment that Everett's explanation makes alot more sense. I agree that the hex headed bolts are probably random bolts people replaced originals with. I've only seen a few hex heads and if an original needed replacement it makes sense that it would be a hex. Also, why would VW use two different styles? |
I also should have said that of the seats that I have owned and can remember, those that had a hex head bolt only had it on the outside edge, where it could easily be removed or fall out.
The inside one, which is sort of stuck in there because of the seat material, had the normal round screw pictured above. _________________ How to Post Photos
scvw Samba Member
Joined: September 02, 2006 Posts: 3544 Location: South Carolina
Posted: Sat Nov 21, 2015 2:24 am Post subject: Re: Middle seats |
Everett's description is exactly the way my seat is, round head on the inside portion of the flipper and hex head on the outside. _________________ 58 Coral Red ragtop(Diana's car)
57 PG/SG standard
63 Ruby Red SC
SOUTHERN INTEGRITY AIRCOOLERS
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775 |
Posted: Sat Nov 21, 2015 7:19 am Post subject: Re: Middle seats |
Z wrote: |
Stanagon wrote: |
I used door panel material that I got from my upholstery guy to make the panel for the back of the seat. It was a little thicker than the original black backing panel. I used a few interior panel screws with collars to secure it to the seat frame. It seems like the original backing panel was not attached to the seat frame, but perhaps just held in place by the seat cover.
One of the backing panel mounting screws I used is shown here, above the rivets for the ashtray mount.
Any detailed pictures of the armrest pad and mounting bracket could be helpful to me. thanks _________________ Stan's Classic Service, specializing in air-cooled VWs:
www.stanagon.com
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709 |
2Pack Samba Member
Posted: Sat Nov 21, 2015 11:03 am Post subject: Re: Middle seats |
scvw wrote: |
Everett's description is exactly the way my seat is, round head on the inside portion of the flipper and hex head on the outside. |
The hex heads I have seen were on the outside as well. Add "check tightness of outer middle seat screw" to the maintenance list _________________ Please buy my Treasure |
Posted: Sat Nov 21, 2015 7:48 pm Post subject: Re: Middle seats |
I'm thinking vacuum formed plastic negative mold filled with dense urethane two part foam over a metal screw bar would be the way to reproduce the arm rest. Paint with Krylon fusion flexible plastics paint.
http://www.amazon.com/Liquid-Urethane-Density-Includes-Quart/dp/B007V231P6 _________________ Founder and Chairman Emeritus, ECMSAS
tanhis Samba Member
Joined: July 23, 2005 Posts: 655 Location: Rauma Finland
Posted: Tue Dec 08, 2015 6:04 am Post subject: Re: Middle seats |
Is this bay or split seat?
No recline handle but has extra supports on the legs _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Tue Dec 08, 2015 6:41 am Post subject: Re: Middle seats |
tanhis wrote: |
No recline handle but has extra supports on the legs |
Split 67 middle seat _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
tanhis Samba Member
Posted: Tue Dec 08, 2015 7:19 am Post subject: Re: Middle seats |
zuggbug wrote: |
tanhis wrote: |
Split 67 middle seat |
Well then I will pick these up next weekend.
-62 Typ 34
-65 Typ 34
-69 typ 2, 9 seater
