How to Install Fram external Oil
djway3474
djway3474 is offline
PostPosted: Sun May 31, 2015 1:45 pm    Post subject: Reply with quote
I think it is Flat Four that makes the replicas although I don't know if they have the Ghia bracket.
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Fri Sep 04, 2015 5:11 am    Post subject: Reply with quote
DONGKG wrote:
rtroy wrote:
zundapp wrote:
skyto wrote:
Those with a 40hp installation, please post pictures. What's the best looking option for the return line hollow bolt? A fuel pump or generator pedestal stud? Or drill & tap a hole somewhere?
Distributor clamp is not an option, that's a blind hole in a 40hp case.
I did the drill and tap into the genny stand. There is a rounded area cast into it for some reason. It was the perfect size for the hollow bolt to thread into.
This setup came with an Okrasa oil cooler but I eliminated it because it's just a bad idea. It warms the air that is supposed to cool the motor but I doubt it did much to cool the oil. Preheating air that then is supposed to cool oil in the factory oil cooler seams counter-productive to me. Confused
Firstly, with this setup, you can eliminate the bolt and thread the 90 degree piece straight into the generator stand - more or less exactly as Porsche did on its early engines.
And secondly, the oil cooler in front of the fan intake can be seen from an engineering point of view as nothing more than increasing the area of the existing oil cooler. There is extra capacity for it - it's not such a bad idea after all.
Regards,
Richard
I did this set up on my vw too.
I did this one, but my experience is that if the either the oil filler cup or the inlet connected to the air cleaner is not property sealed, chances are, the pressure doing from the engine will push the oil emanating from the small hole drilled through the base of the generator stand. and oil will be spilled out! So, checking regularly the oil filler cover and the inlet from the air clearer will keep the oil from spilling out.
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20
jdub63
jdub63 is offline
PostPosted: Fri Nov 06, 2015 8:36 pm    Post subject: Reply with quote
Has anyone ever posted the actual dimensions of the oil lines? Anyone know if the 356 lines will be long enough to work on a filter installed on the fan shroud?
Brian Anthony
Brian Anthony is offline
PostPosted: Sat Nov 14, 2015 10:33 pm    Post subject: Reply with quote
I did this also but I tapped the inside of the through hole in the generator stand 1/8 NPT and installed a 1/8 NPT 90 street elbow and a short piece of 1/8 pipe to get the oil return below the baffle. I had to cut down the 1/8 NPT tap to get it to fit inside the generator stand. I cut a small hole in the baffle for the 1/8 pipe to go through. With the oil being returned below the baffle and being shot straight down into the engine, I haven't seen any problem with oil in the breather tube to the air cleaner.
1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans.
Braukuche
Braukuche is online now
PostPosted: Fri Dec 11, 2015 1:13 pm    Post subject: Reply with quote
No, the limes are too short.
On the return line on both my cars I used a hollow Distributer stud. It's been so long I forget where I got it from.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
56samba
56samba is offline
PostPosted: Mon Aug 22, 2016 2:38 am    Post subject: Reply with quote
Hi,
you can produce them on your own, my first attempt was very good. You need a M8 allen screw. First step is to drill a hole in it from the top to the bottom, so it's hollow. Then you have to drill a bigger hole in the head of the screw, but not too deep!!! This hole is for the thread; in the head of your hollow screw you have to cut a M10x 1.25 thread. I'm no really sure about this thead, I'm going to have a look for it to be sure. The last thing you have to do is to screw in another hollow screw with threads on both of its side, on side has M10x1.25, the other thread is in inch, same threat size as the threat on your oil filter can...
better you see the pictures Very Happy
The nut is for holding the dizzy, the copper gaskets rings were made of pennies Laughing
I don't know how Mr. Gerhard Oettinger did connected the Fram filter with his engine, but this method is quick and you don't have to drill in your engine case.
Regards, Jan
jdub63
jdub63 is offline
PostPosted: Mon Aug 29, 2016 2:56 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
I wanted to add this picture from the gallery for future reference...
grailoc
grailoc is offline
PostPosted: Sun Jan 22, 2017 10:47 am    Post subject: Re: How to Install Fram external Oil Reply with quote
Hi everyone,
I am reopening that thread,
I have a NOS FRAM OIL Filter and Hose and looking for the studs adapters to go in and out of the 36hp engine.
Does anyone know where either find following hose kit or just the studs that connect on the engine?
My 59 low light ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=452128
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
My oldspeed 36hp autotechnik express build: https://www.thesamba.com/vw/forum/viewtopic.php?t=670827
My garage build: http://www.garagejournal.com/forum/showthread.php?t=199438
grailoc
grailoc is offline
PostPosted: Sun Jan 22, 2017 10:50 am    Post subject: Re: How to Install Fram external Oil Reply with quote
Here is a pic of the kit I have right now.
As you can see I am missing the stud to connect on the 36hp case.
Any help to source the right studs or hose kit as pictured above would be great
thanks,
Jerome
jjjjack
jjjjack is offline
PostPosted: Mon Mar 06, 2017 8:12 am    Post subject: Re: How to Install Fram external Oil Reply with quote
Hi Jerome,
Not exactly sure what parts you need, but I got an F3-P to replace an incorrect filter on my PreA and will be replacing the lines while I'm at it. These guys might have what you need:
http://www.partsklassik.com/c-29-engine-lubrication.aspx
HTH,
Jack Stenner
1959 Mango Westfalia SO-23
1953 Porsche 356 Coupe
IG:j.stenner
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
Joshua B
Joshua B is offline
PostPosted: Wed Nov 01, 2017 9:51 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
Does anyone have a picture of what their restrictor looks like in the 90 degree inlet fitting? How large is the opening? Mine doesn't have it so I need to figure it out. Does anyone just sell the fitting?
59VWBUG
59VWBUG is offline
PostPosted: Sat Jan 27, 2018 12:39 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
I am going to put the restrictor at the 'street tee' at the oil pressure switch.
This what I am using:
https://www.ebay.com/itm/Brass-Turbo-Oil-Feed-Rest...2749.l2649
More Oil (feed,flow) restrictors on eBAY:
https://www.ebay.com/sch/i.html?_odkw=oil+%28flow%...p;_sacat=0
HTH
Bob
Braukuche
PostPosted: Sun Jan 28, 2018 1:14 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
grailoc wrote:
Hi everyone,
Got mine from Michael Bucchino in MA.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
grailoc
grailoc is offline
PostPosted: Sun Jan 28, 2018 1:55 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
yep bought it from him too
mkbug
mkbug is offline
PostPosted: Sun Feb 11, 2018 9:14 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
Is there a better template on where to drill the shroud then this?
Looks like 120 mm from the center line of the generator to the left. And 50 mm from the top of the shroud to the top of the canister's bolt. But what if the brack has been moved on the canister?
Hate to hit the cooler or the directional vanes in the shroud.
Thanks Martin
I'm Martin
My Build: https://www.thesamba.com/vw/forum/viewtopic.php?t=667183
jorgeschmidt
jorgeschmidt is offline
PostPosted: Thu Jan 21, 2021 6:37 pm    Post subject: Where I can find this part? Reply with quote
62ItalianRagtop wrote:
I'm working on my dual carbs 40hp and I want to install my Fram oil filter.
I have seen this installation kit
and this one
The second one with oil cooler is better ?
Hello, someone know where I can Buy this oil cooler?
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri Jan 22, 2021 3:32 am    Post subject: Re: Where I can find this part? Reply with quote
Mike makes these: https://www.thesamba.com/vw/classifieds/detail.php?id=1979669
John.
motofly196
motofly196 is offline
PostPosted: Fri Jan 22, 2021 8:45 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
Some top quality lines and fittings from Mike! Cohine lines that match the early lines perfectly.
evanfrucht
evanfrucht is offline
PostPosted: Sun Aug 08, 2021 3:42 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
I need one of the oil sender/filter fittings like the one pictured above in the top left corner. And also the last page near the top was a picture of a broken one...
Who makes them, who has them, or how can I get one. I'm trying to get a hold of one ASAP.
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
5500
5500 is offline
PostPosted: Sun Aug 08, 2021 5:22 pm    Post subject: Re: How to Install Fram external Oil Reply with quote
vwmike333 on the Samba makes the lines and sells kits with fittings and lines. I suspect if you reach out to him he may sell you the fitting you are looking for. Search for okrasa style fram oil filter hoses and fittings.
Page 5 of 6
