OG 1967 Bendix Radio worked now it crackle's???? Help
aa390392
aa390392 is offline
PostPosted: Sun Dec 13, 2015 12:36 pm    Post subject: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
Hey, I took the engine in for rebuild, prior the radio worked,now with the rebuild engine, the radio now makes crackling noise?
Specs.dual port, 12volt,1967 stock bedix radio,
Like I said it worked fine before. .....something to with the distributor?
Thanks for any and all suggestions
Thomas
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
grandpa pete
grandpa pete is offline
PostPosted: Sun Dec 13, 2015 12:58 pm    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
distributor should give you a wineing noise and can be fixed with a noise suppressor;
crackle might be the speaker is broken or loose
New repop speaker is less than ten bucks at Wolfsburg West
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
EVfun
EVfun is offline
PostPosted: Sun Dec 13, 2015 2:26 pm    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
A bad speaker, a bad power or speaker connections, or a cracked solder joint -- these are the usual suspects. A failing part cannot be ruled out. In your advantage is that you have some function, which should should make troubleshooting easier. After checking all external connections you may want to find an old school electronics repair shop.
Wildthings wrote:
aa390392
aa390392 is offline
PostPosted: Sun Dec 13, 2015 4:06 pm    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
Nope none of the above,
Static,and poping when eng. Is running, like I said was perfect before eng. Rebuild..nothing like a resistor in dist?
55 ragtop
56 delux sedan
56 Kabriolet
aa390392
aa390392 is offline
PostPosted: Sun Dec 13, 2015 4:08 pm    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
Condensor? Wiring from dist. To plugs?
55 ragtop
56 delux sedan
56 Kabriolet
rcooled
rcooled is offline
PostPosted: Sun Dec 13, 2015 5:26 pm    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
This is only happening when the car's running, right? Does the noise change in any way when you rev the engine? If so, check the plugs to make sure they're the resistor type. Are the plug wires shielded?
No resistor, but you might check to see if the condenser was replaced during the rebuild.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
aa390392
aa390392 is offline
PostPosted: Mon Dec 14, 2015 6:41 pm    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
Rcooled are not all plug wires created equal....or do some have resistors in the wiring?
And if the condenser is new or the old one used? Does that make a difference?
Thanks for help
Thomas
55 ragtop
56 delux sedan
56 Kabriolet
rcooled
rcooled is offline
PostPosted: Mon Dec 14, 2015 9:04 pm    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
Some wires have a compressed-copper core, or are jacketed in wire mesh to suppress radio static. Un-shielded copper wire (found in the standard Bosch VW cable set) acts like an antenna to broadcast RFI. If you use these wires, you need to pair them with resistor-type spark plugs.
The condenser helps to minimize sparking at the ignition points when they open & close. This is another source of RFI. Condensers usually last a good long time, but you never know...
aa390392
aa390392 is offline
PostPosted: Thu Dec 17, 2015 10:01 am    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
Thanks for help that should cure symptoms
Thomas
55 ragtop
56 delux sedan
56 Kabriolet
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Dec 17, 2015 10:52 am    Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help Reply with quote
...or regular plugs plus the OEM resistor (1KΩ) bakelite SP connectors.
