EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Mon Dec 14, 2015 7:22 pm Post subject: Decklid differences |
Anyone know why this decklid doesn't have the reinforcement piece where the latch goes thru? I don't see any sighs of the piece ever being there, no spot welds, no holes. Supposedly the decklid is from a '62.
_________________ 1963 Ragtop Bug |
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
63vbug82 Samba Member
Joined: April 16, 2015 Posts: 146 Location: Cedartown Ga
Posted: Tue Dec 15, 2015 1:15 am Post subject: Re: Decklid differences |
Nope not a 62 at all dose not have the lines that that swoop out on the plate light area and as mentioned its a push button lid the 62 would be a t handle lid. And the holes where light housing would bolt up and plate mount holes are different then a push button I was told that mid 64 and up to 67 would be the lid that you have I don't know if its true or not but maybe that helps _________________ 62 bug , 66 split bus ,63 bug R.I.P, |
Slow 1200 Samba Member
Posted: Tue Dec 15, 2015 2:02 am Post subject: Re: Decklid differences |
that's a 65 lid, a 66 would have the holes for the 1300 (or 1200 in the case of 1200As) script, while a 64 and 67 are different altogether |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Dec 15, 2015 6:39 am Post subject: Re: Decklid differences |
Plus good information within > Official "What year is my decklid" thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=490378
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
notsnarb Samba Member
Posted: Tue Dec 15, 2015 7:55 pm Post subject: Re: Decklid differences |
Slow 1200 wrote: |
x2 a '65 only lid |
Posted: Tue Dec 15, 2015 8:18 pm Post subject: Re: Decklid differences |
Thanks guys _________________ 1963 Ragtop Bug |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Tue Dec 15, 2015 10:08 pm Post subject: Re: Decklid differences |
Slow 1200 wrote: |
As a used lid, yes a 65, but when I worked at a dealer 1971 -72 era. The factory replacement hood for 65-66 did not come with any holes ( except for the latch ) because those hoods could be used for T-111 "A" sedan 1965 which had no script and used the 63 and earlier license plate lamp, or a T-113 deluxe 1965 which had no script and used the 64 and newer larger license plate lamp.
1966 T 111 1200A used the 1200 script and the old style small license plate lamp. 1966 T 113 used the large license plate lamp and the 1300 script.
That is also why front and rear fenders were not drilled for tail lamps and front turn signal lamps. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Wed Dec 16, 2015 12:40 pm Post subject: Re: Decklid differences |
Wouldn't an OE 65 have the wider span for the larger license plate light mounting holes? |
Posted: Wed Dec 16, 2015 7:53 pm Post subject: Re: Decklid differences |
Sharp64 wrote: |
Yes someone drilled holes for an earlier light housing. _________________ 1963 Ragtop Bug |
Posted: Wed Dec 16, 2015 8:02 pm Post subject: Re: Decklid differences |
EMPIImp69 wrote: |
Sharp64 wrote: |
Yes someone drilled holes for an earlier light housing. |
That's what I'm saying. Where are the other holes? Possibly a repop? |
Helfen Samba Member
Posted: Wed Dec 16, 2015 10:03 pm Post subject: Re: Decklid differences |
Sharp64 wrote: |
Apparently you didn't read my post. My 65 type 111 is a "A" sedan.
The image below is my 65 111 and my friends 1966 1200A type 115 a rag top. Both cars use the small type lic. plate. Note my car came with towel rack bumpers because that was the only was the car would be able to pass U.S Customs. see below:
https://www.thesamba.com/vw/gallery/pix/516078.jpg |
