Lifted busses ( not big meats under stock suspension)
Page: 1, 2, 3, 4, 5  Next
Babyblue60
Babyblue60 is offline
PostPosted: Wed Aug 12, 2015 10:06 pm    Post subject: Lifted busses ( not big meats under stock suspension) Reply with quote
I'm tired for the stock bus with big meats. Let's post pics of builds with lifted busses and there mods/ combos.
mandraks
mandraks is offline
PostPosted: Thu Aug 13, 2015 5:15 am    Post subject: Reply with quote
i see no pics? did you forget to post yours?
regards
Uli
Babyblue60
PostPosted: Fri Aug 14, 2015 5:04 am    Post subject: Reply with quote
Mine is under construction. 61 turkis 11 window. No the dog leg is getting reaced and no I'm not running that wheel. Has bay beam with adj and rear I haven't decited if I want to go irs or leave rgb. Tires are bfg a/t 215/75/15
Babyblue60
PostPosted: Tue Aug 18, 2015 7:06 pm    Post subject: Reply with quote
Beam installed
joe cool
joe cool is offline
PostPosted: Tue Aug 18, 2015 7:30 pm    Post subject: Reply with quote
(Bus belongs to Ronnie in Lake Havasu, other pics in gallery, I think there is a thread somewhere on the build, involved raised spindles not bay beam)
Babyblue60
PostPosted: Wed Aug 19, 2015 8:54 am    Post subject: Reply with quote
I would of went lift spindles from Nate if I had link pin beam but I bout the bus beam less and got the bay beam free
64 ragtop volks
64 ragtop volks is offline
PostPosted: Wed Dec 16, 2015 5:10 am    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
i have bay beam and big nut redux boxes. 215/75/15 dynapro mt hankooks on stock rims. my bus sits 2" higher then friends stock suspension bus running the same tires.
brettsvw
brettsvw is offline
PostPosted: Wed Dec 16, 2015 6:16 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
Lets see someone come up with some custom raised RGBs.
Design a new box with a third gear between axle drive gear and stub axle gear to lift.
Axle rotation would be the same as stock straight axle.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
chrome
chrome is offline
PostPosted: Wed Dec 16, 2015 7:04 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
This was my last bus a 64 kombi
bay beam
67 trans 1 notch up on the spring plates
Armstrong 215/75/15's all around
damn I miss this one Crying or Very sad
65 21 window
57 T1 ragtop
58 ghia vert
68 fastback
71 T2 sunroof
63 mercury meteor wagon
54 flxible visicoach
cdennisg
cdennisg is offline
PostPosted: Wed Dec 16, 2015 8:35 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
Saw this bus at a Vintage Meet in Seattle several years back. I think it was being built by Franklin's. No idea what ever happened to it.
" Everything's a smoke machine if you use it wrong enough"
AvE
73sports
73sports is offline
PostPosted: Wed Dec 16, 2015 8:47 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
I will never lie, but sometimes the truth changes.
Central Jersey VW Society
cdennisg
cdennisg is offline
PostPosted: Wed Dec 16, 2015 9:11 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
^^^ did that thing ever get found after it's unfortunate journey?
AvE
joe56vw
joe56vw is offline
PostPosted: Wed Dec 16, 2015 9:19 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
the suspension is probably sitting in his shop somewhere pretty sure he sold the bus with different suspension soon after that show
he's never had a great track record with finishing his own projects usually ends up selling them Wink
'60 15 window walkthrough
why is there no sarcasism button on here?
73sports
73sports is offline
PostPosted: Wed Dec 16, 2015 9:51 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
Not that I know of.
GTV
GTV is offline
PostPosted: Wed Dec 16, 2015 10:06 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
There was a MASSIVE oval window baja bug in Colorado built like that, probably 20 years ago or more.
IRS with reduction boxes would be the ultimate.
EMPI Power Rules!
cdennisg
cdennisg is offline
PostPosted: Wed Dec 16, 2015 10:30 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
I looked into fabbing some RGB's with a dual roller chain setup, but it was just too complicated for my skills. Talked with a friend who does that shit for a living, and he said it would be very tough to make it all work right and be driveable at highway speeds.
Have you ever seen the rear drive system from the 70's agricultural vehicle called a Spra-coupe? There is a VW industrial engine and an early bay bus tranny in there. that is connected to those tall white boxes inside of each wheel. Pretty sure that is a chain drive setup.
AvE
64 ragtop volks
PostPosted: Mon Jun 20, 2016 11:00 am    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
29x8.5x15 super swampers, made in usa $160 each at 4 wheel parts, free shipping
Tim MacDonald
Tim MacDonald is offline
PostPosted: Sun Aug 21, 2016 7:37 pm    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
64 ragtop volks wrote:
29x8.5x15 super swampers, made in isa $160 each at 4 wheel parts, free shipping
Any rubbing issues? what did you do to the bus to raise it?
64 original Turkis paint Canadiana camper in progress project
84 mint original paint westfalia
64 ragtop volks
PostPosted: Mon Aug 22, 2016 7:44 am    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
i have early bay front beam ( raises the front about 2" ) and re indexed the spring plates in the rear ( big nut redux boxes), coil over shocks in front and stock style shocks in the rear. running bug smoothies in front and crows feet rims in rear. no rubbing on the street, going back to big bend state park for thanksgiving weekend to put it to the test. we went last year and had a blast, took a few of the 4wd hi clearance trails, and buses did great.
Glenn A
Glenn A is offline
PostPosted: Mon Aug 22, 2016 8:46 am    Post subject: Re: Lifted busses ( not big meats under stock suspension) Reply with quote
My favorite lifted bus.
mannys66 wrote:
In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it.
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R
Page 1 of 5
