FutureVan
Merian
Merian is offline
PostPosted: Sun Dec 27, 2015 12:45 pm    Post subject: FutureVan Reply with quote
you know you want it... or something like it
You can add this active swaybar (which can be found in junkyards; used on the Porsche 'pepperpot' SUV)
Merian
Merian is offline
PostPosted: Sun Dec 27, 2015 12:47 pm    Post subject: Re: FutureVan Reply with quote
Air Suspension...
http://www.porsche.com/australia/models/cayenne/cayenne-s/chassis/air-suspension/
or rip one off of the newer Jeep Cherokee:
http://www.wk2jeeps.com/wk2_quadralift.htm
- either way, you get self-leveling which helps for sleeping and headlight aim variation with different loads
Merian
Merian is offline
PostPosted: Thu Dec 31, 2015 6:38 pm    Post subject: Re: FutureVan Reply with quote
or...
boof1306
boof1306 is offline
PostPosted: Thu Dec 31, 2015 6:52 pm    Post subject: Re: FutureVan Reply with quote
I hate to rain on your parade but the electronics behind making those sway bars work are complex and not a retrofit proposition as they require inputs from other control units.
Team WorldTour
Team WorldTour is offline
PostPosted: Fri Jan 01, 2016 3:07 am    Post subject: Re: FutureVan Reply with quote
Well, thanks for that.
Sheesh! Interrupting my perfectly good fantasy with truth!
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
insyncro
Banned
insyncro is offline
PostPosted: Fri Jan 01, 2016 9:28 am    Post subject: Re: FutureVan Reply with quote
The only limiting factor for all upgrades will be the budget of the van owner.
Anything is possible Exclamation
Happy New Year.
Butcher
Butcher is offline
PostPosted: Fri Jan 01, 2016 10:26 am    Post subject: Re: FutureVan Reply with quote
Which is to say it is impossible.
Merian
Merian is offline
PostPosted: Fri Jan 01, 2016 12:15 pm    Post subject: Re: FutureVan Reply with quote
some things are impossible, but what we think of as impossible often becomes merely hideously expensive, followed by luxury, then by std. equipment on all cars
Here is an old old idea from the guy who started the whole "VW thing," now coming back into prominence:
Butcher
Butcher is offline
PostPosted: Fri Jan 01, 2016 12:30 pm    Post subject: Re: FutureVan Reply with quote
Which is why it would be impossible for any VW Vanagon owner. If I'm wrong, someone will chime in and make it possible.
I'm not holding my breath. I've worked with some of the riches people in the worlds vehicles and they are not interested in Vanagons. One of them tried to get a Porsche in the country several years back and could not until the law was changed [somehow he helped changed that too].
https://en.wikipedia.org/wiki/Porsche_959
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jan 01, 2016 7:11 pm    Post subject: Re: FutureVan Reply with quote
Agree that active swaybar would be a non starter for a retrofit. It relies upon a large data flow from a variety of sensors. The sensors in turn feed a processor, which then tells the powerful swaybar activation what to do. This must happen in real time.
Even if all the components were in place there is no data map for what the system should do for a Vanagon, to assist in its handling. Those maps are created by teams of engineers, track time and simulators.
So, it is a pretty daunting task, and the skills to do it would not likely reside outside of an automaker's suspension engineering department, or a sizable vendor tasked with doing this specifically for the automaker under a spendy contract.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
Merian
Merian is offline
PostPosted: Fri Jan 01, 2016 9:45 pm    Post subject: Re: FutureVan Reply with quote
that won't stop someone from trying to hack one in - it is a VW after all
240Gordy
240Gordy is offline
PostPosted: Fri Jan 01, 2016 10:50 pm    Post subject: Re: FutureVan Reply with quote
Oh somebody will hack it. It might not be as sophisticated as the Porsche but someone will.
After Greg got the Subie deisel going I will never say never again.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
240Gordy
240Gordy is offline
PostPosted: Fri Jan 01, 2016 10:57 pm    Post subject: Re: FutureVan Reply with quote
Merian wrote:
Air Suspension...
All doable now with off the shelf aftermarket components. You might need to fab some brackets etc. But the electronics and sensors are all available.
Tencentlife said,
Type17
Type17 is offline
PostPosted: Sat Jan 02, 2016 1:14 am    Post subject: Re: FutureVan Reply with quote
I'd just be happy with a sway bar that could be decoupled on the fly.
Which is totally possible, but still not worth it.
insyncro
Banned
insyncro is offline
PostPosted: Sat Jan 02, 2016 7:38 am    Post subject: Re: FutureVan Reply with quote
Not only possible, but have been mounted to a Syncro of mine for years now.
Pictures have been posted.
IdahoDoug
PostPosted: Sat Jan 02, 2016 8:24 am    Post subject: Re: FutureVan Reply with quote
Decoupler = easy peasy. Powered, active swaybar tailored to the Vanagon = nearly impossible without automaker-grade resources.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Jan 02, 2016 8:50 am    Post subject: Re: FutureVan Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?p=6685312
These ones?
Any update on these?
Happy New year 2016 by the way Dylan (and others of course: may your projects come to fruition Wink )
MsTaboo
MsTaboo is offline
PostPosted: Sat Jan 02, 2016 1:01 pm    Post subject: Re: FutureVan Reply with quote
Any pictures of them actually mounted on the Syncro?
Currently:
Defend democracy, support Ukraine.
insyncro
Banned
insyncro is offline
PostPosted: Sat Jan 02, 2016 1:16 pm    Post subject: Re: FutureVan Reply with quote
These ones?
The only issue with them is that they are NLA from the fabricator that built them.
The last I had heard is that he had some health issues.
The links are sweet and have served me well thus far.
Currently mounted with T3's 25mm bar and my custom mounts.
Happy New Year to you as well Alika, I hope your rental vans are coming along nicely.
Merian
Merian is offline
PostPosted: Sun Jan 10, 2016 4:47 pm    Post subject: Re: FutureVan Reply with quote
To many Vanagonites, styling is much more important than utility, so how about...
