Carb/fuel tuning Bay Area?
teamasr
teamasr is offline
PostPosted: Fri Jan 01, 2016 11:14 pm    Post subject: Carb/fuel tuning Bay Area? Reply with quote
Anyone local in Nor Calif who has a snail sync tool to help tune carbs?
My pressure is low, using a carter electric pump, showing around 1psi. No change when turning the adjustment bolt on the Holley regulator, so will replace it, but also getting some pops from one of the carbs which may have gotten out of sync during install of new motor.
Let me know if you can help.
stan_tichomirov
stan_tichomirov is offline
PostPosted: Fri Jan 01, 2016 11:52 pm    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
Where are you, and what carbs? I'm not a huge expert, but may be able to help, or at least have a look.
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build
teamasr
teamasr is offline
PostPosted: Sat Jan 02, 2016 8:28 am    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
That would be great, I'm in Dublin.
cjsuner
cjsuner is offline
PostPosted: Sat Jan 02, 2016 1:09 pm    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
Ya, I'm the same as Stan, Im no expert, but i do have Weber 40's that run smoothly, and i tuned them myself, so i may be able to help as well. Im up in Pleasant Hill.
Maybe all 3 of us could meet
71' Super Convertible (Orange)
74 Super Beetle (Red)
74 Thing
74 Thing is offline
PostPosted: Sun Jan 03, 2016 3:25 pm    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
Is NAG still around? https://www.facebook.com/NAGVW/
They used to have a meeting the second Friday of the month in Pleasanton at the In and Out Burger.
stan_tichomirov
PostPosted: Sun Jan 03, 2016 4:18 pm    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
Dublin is a bit far to swing by without planning, but maybe we can plan a small meet.
1psi won't do it, you need closer to 3psi. I have Carter pumps on Beetle with 40IDFs with a Holley regulator, and on Fastback with ICTs without a regulator. It should work fine without a regulator, maybe your fuel line or sock in gas tank are clogged?
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
teamasr
teamasr is offline
PostPosted: Mon Jan 04, 2016 9:29 am    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
I am also running webers.
I have new Holley FPR and will install this week to see if I can get a better read on pressure. Given the rain this week, I'll coordinate a time to meet the following week.
teamasr
teamasr is offline
67jason
67jason is offline
PostPosted: Tue Jan 05, 2016 11:42 pm    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
im in pittsburg, keep me in the loop as to when you all gtg, i can help.
and yes NAG is still around, they meet at the In & Out in Pleasonton every 2cd friday of the month.
67 bug x3
67 ghia
64 bug
stan_tichomirov
PostPosted: Wed Jan 06, 2016 8:12 am    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
Hey Jason, is BLTN meet still active, do you go to it?
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
67jason
67jason is offline
PostPosted: Wed Jan 06, 2016 8:52 am    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
Stan
BLTN is still sorta active. I haven't gone to the meets regularly in years due to my work. usually 3-10 guys still show up sometimes. It is certainly not what it used to be however.
67 bug x3
67 ghia
64 bug
stan_tichomirov
PostPosted: Wed Jan 06, 2016 10:40 am    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
I wouldn't mind meeting up sometimes. I remember your bus from BLTN meets. I haven't gone since 2007, I was out of it for a while.
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
67jason
67jason is offline
PostPosted: Wed Jan 06, 2016 10:17 pm    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
Stan
ya the old shitbox!! PM sent
67 bug x3
67 ghia
64 bug
teamasr
teamasr is offline
PostPosted: Tue Jan 26, 2016 6:42 pm    Post subject: Re: Carb/fuel tuning Bay Area - Solved - but Low Pressure Reply with quote
Solved the carb problem, now a different issue.
Carbs 3 and 4 had no response to accelerator using snail sync. Took the idle jets out, cleaned them and reinstalled. That solved the problem. Idle was smooth, air flow to carbs were at 6 on sail sync and both sets of carbs respond to accelerator equally.
After about 3 minutes of idling can hear small pops in the exhaust. Noticed the fuel pressure dropped to zero from 3psi. Took gas cap off to check for pressure in tank, none there.
Using the Cb performance electric pump with holley fuel pressure regulator.
Clogged screen at gas tank? Fuel filter just outside of tank is clean.
stan_tichomirov
PostPosted: Tue Jan 26, 2016 8:51 pm    Post subject: Re: Carb/fuel tuning Bay Area? Reply with quote
You can put one of those clear filters in line before your pressure gauge and carbs, if you are not getting fuel you'll see it. Check the sock. I've also run a throttle cable through hardline after the tank to make sure there is no gunk.
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
