MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Fri Jul 25, 2008 5:53 pm Post subject: Transmission tunnel insulation replacement - PICS |
If your Westfalia is over 20 years of age, I recommend you have a look at the insulation above the transmission in the "transmission tunnel", for lack of better words.
You may find something like this:
That is a sagging mess of old, cracked backing and disintegrating foam which has lost much of its usefulness. When you pull it out it will look like this:
Next time you do a clutch or a job that requires for the trans or the engine to come out, you may want to consider to replace that mess with something a little more effective. I chose aluminized Refletix 25'' x 16' "bubble" insulation that comes in rolls.
After I pulled out the old insulation in pieces I put the puzzle back together to get a good idea of the size I needed to fit:
I used aluminium tape to seal the folds and to give it a finished look. I also cleaned the transmission tunnel area. It was remarkably clean with only some glue residue and minor dust.
When I finished it looked like this:
I also added a few patches of sound insulating material behind Reflectix. This should do a better job of keeping the heat from the transmission away from the passenger compartment, and do a decent job of suppressing the noise. |
tencentlife Samba Member
Posted: Fri Jul 25, 2008 9:46 pm Post subject: |
Looks nice!
What'd you use to stick it up? _________________ Shop for unique Vanagon accessories at the Vanistan shop:
1621 Samba Member
Posted: Fri Jul 25, 2008 10:13 pm Post subject: |
Very nice work! I did something similar, but not quite as thorough as you. I had an additional sheet of Motor Mat Pro from a different project that I used. http://www.secondskinaudio.com/thermal-insulation/motor-mat-pro.php I simply took some measurements, trimmed to fit, and put it over the existing insulation. It tucks nicely under the wires holding the original stuff in place. It does make a bit of difference (not scientifically tested), and keeps things clean. Also, you don't need to remove the transaxle to put it in place. _________________ '85 Westy |
Posted: Sat Jul 26, 2008 5:21 am Post subject: |
Thanks!
The material is held up in place with original wires that clip into place - if you look at the "old" pictures you can see them.
I think the Second Skin material has better noise absorbing properties. If It were available to me I would have used it along with Reflectix.
FYI, I folded the Reflectix material in half and taped it for a thicker application. |
the caveman Samba Member
Joined: August 09, 2004 Posts: 885 Location: island state of Montreal
Posted: Sat Jul 26, 2008 10:40 am Post subject: |
Everyone should get rid of that foam. It holds water and rots metal behind it. |
mediaguy99 Samba Member
Joined: April 05, 2011 Posts: 46 Location: Boulder, CO
Posted: Fri Dec 06, 2013 2:49 pm Post subject: "Everyone should get rid of that foam" |
Which product are you talking about? |
randywebb Samba Member
Posted: Fri Dec 06, 2013 4:28 pm Post subject: |
your pics are gone - can you repost them? _________________ 1986 2.1L Westy 2wd Auto Trans. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Fri May 08, 2015 5:32 pm Post subject: |
Hoping someone can provide some direction, or alternatives (especially since the pictures are gone). My engine and tranny are (still) out and I just noticed how bad my insulation looks.
I'd like to know what people have successfully used as options and how it was held in.
Thanks! _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Fri May 08, 2015 8:50 pm Post subject: |
vanagonjr wrote: |
Thanks! |
I have a set of the original wires that held the insulation in place. They are in great condition no rust. Pm me if you are interested in them |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
GypsyDriver Samba Member
Joined: November 06, 2012 Posts: 190 Location: Columbus, GA
Merian Samba Member
Posted: Sat May 09, 2015 11:30 am Post subject: |
there is a place that specializes in custom fab of heat and sound insulation panels - forget the name but they mostly do stuff for the Detroit hotrod market
worth a search - somebody could even ask for bulk pricing and do a resale
what does GoWesty do when they refurb a Van? |
madmanvan Samba Member
Joined: December 20, 2010 Posts: 147 Location: Louisville
Posted: Sun Jan 03, 2016 4:52 pm Post subject: Re: Transmission tunnel insulation replacement - PICS |
What about not putting anything back? Is that nuts?
I'm doing the rattle trap INSIDE the van for noise reduction. _________________ Madmanvan
1967 Bus turned Westy
1985 Vanagon Weekender (SOLD)
Current Build: '67 Kombi goes Westy
http://www.thesamba.com/vw/forum/viewtopic.php?p=8343416#8343416 |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Merian Samba Member
Posted: Sun Jan 03, 2016 5:50 pm Post subject: Re: Transmission tunnel insulation replacement - PICS |
madmanvan wrote: |
not at all - it's in the back and there will be plenty of wind noise to drown it out
the foil material above is mainly for heat |
Posted: Mon Jan 04, 2016 6:57 am Post subject: Re: Transmission tunnel insulation replacement - PICS |
I'm going to call my style "zen": I'd like to delete anything that isn't 100% necessary. I can live with a little extra noise at the benefit of not having anything hold moisture against metal.
Same with the rear heater delete: the idea of coolant running into a relatively hidden spot in the van is nuts to me.
The front heater I guess I gotta have for defrost, but also doesn't seem as bad of a design - and I'll know sooner if it is leaking. The sweet smell of hot coolant.
The AC that a PO had begun to delete, I've finished and now my radiator area looks nice and tidy. _________________ Madmanvan
