VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Dec 27, 2015 4:38 am Post subject: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
Folks, I have a Type 2 box and a set of Porsche 944 stub axles, CVs and drive-shafts.
No funny business planned with the rear suspension: just re-indexed IRS trailing arms, 25+mm torsion bars and standard damper stroke/travel...
Will it all work with Bug hubs/brakes and trailing arms? |
EnjoyNukaCola Samba Member
Joined: January 27, 2014 Posts: 491 Location: Santa Clarita
Posted: Sun Dec 27, 2015 12:54 pm Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
I've done a lot of research on this myself. You should be good to go with those parts. The stub axles will fit a Bug hub and the CVs will give you more travel than a Bug or Bus CV would.
http://blindchickenracing.com/How_to/CVJoints_Axles/cv_joints_101.htm _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help"
Last edited by EnjoyNukaCola on Tue Dec 29, 2015 8:03 pm; edited 1 time in total |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1059 Location: St. Louis
Posted: Tue Dec 29, 2015 7:39 pm Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
Yep, I run exactly that rear end in my sand rail, works great. 944 joints give extra travel too, and I use it. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
DWP Samba Member
Posted: Wed Dec 30, 2015 5:29 am Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
I run the same setup in my rail and baja no problems, you can even use the 944 porsche arms.
You do have to adjust the mounting of the trans by shifting a little to the left or right. I forget. I centered my setup by measuring the distance cup on trans to cup on arms. Take a look at this trans mount and you will see slots for shifting the trans.
DWP
http://www.mooreparts.com/vw-solid-steel-rear-tran...Hwod5HQDOQ |
VWCOOL Samba Member
Posted: Sun Jan 03, 2016 5:21 am Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
Thanks folks,
I intend to use the Porsche arms and spring plates in a performance track/road car (fitted with Bug stubs inside the Porsche brakes) with a Type I box and driveshafts
The Porsche stubs, CVs and drive shafts will be fitted in Bug IRS suspension arms (for spring plate compatibility) with Bug drum brakes and a Kombi/Type 2 box in the Baja
Hope that makes sense! |
danielzink Samba Member
Joined: August 03, 2004 Posts: 282 Location: Lansing Michigan
Posted: Sun Jan 03, 2016 10:25 am Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
DWP wrote: |
DWP
Quick question.
If you use the 944 arms. You're stuck with the 944 brakes only correct ?
Just trying to clarify in my own mind.
Thanks, Dan _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
www.danielzink.com |
VWCOOL Samba Member
Posted: Sun Jan 03, 2016 4:35 pm Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
danielzink wrote: |
DWP wrote: |
DWP
Quick question.
Thanks, Dan |
I hope not! I intend to run Beetle-type brakes on Porsche arms. That way I will have the Porsche's camber/toe adjustment at the spring plate without needing to re-drill VW arms |
Brian Samba Moderator
Posted: Tue Jan 05, 2016 2:51 pm Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
jimmyhoffa wrote: |
Yep, I run exactly that rear end in my sand rail, works great. 944 joints give extra travel too, and I use it. |
No shit, so T1 arms would fit in a T2 chassis? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
DWP Samba Member
Posted: Tue Jan 05, 2016 4:09 pm Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
The early 944 arms and some of the aluminum, early non turbo i think, are exactly the same as a type 1 arm. The type 1 brakes bolt right on. Or if you want you can use the porsche brakes. You just need to rig a different parking brake cable.
iF you can get the porsche spring plate and adjusting bolts. Allows for a fine tuning of the rear.
If you are using a bus trans just use the porsche stubs and axles. everything bolts up no problems
DWP |
VWCOOL Samba Member
Posted: Tue Jan 05, 2016 4:57 pm Post subject: Re: Bus/Kombi box; IRS chassis; 944 shafts and CVs? |
DWP wrote: |
DWP |
Thanks DWP, it seems I have all the bits I need to build two chassis (one Baja with Type 2 box, Porsche CVs/driveshafts and Beetle drum brakes, and a German Looker 1303 with Porsche disc brakes and Beetle CVs/shafts beside a Type 1 box) without buying any extra, or custom-machined, components. Excellent! |
