EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Tue Jan 19, 2016 2:52 pm Post subject: Case machining for larger cylinders |
On a 1600DP AS41 case, in order to fit a 92mm or 94mm piston/cylinder, what does the OD size (in mm) of the opening in the case need to be so the cylinder slips in? Thanks _________________ 1963 Ragtop Bug |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3294 Location: Rapid City, SD
Posted: Tue Jan 19, 2016 3:57 pm Post subject: Re: Case machining for larger cylinders |
About .010-.013" larger then the bottom register of your cylinders. I have found AA cylinders slightly larger then old mahle's.
Brian |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Tue Jan 19, 2016 4:56 pm Post subject: Re: Case machining for larger cylinders |
Here you go. The case opening for "traditional" 92's would be the same as for 90.5; that is, 92 "thin walls". 92 thick walls would use the same case bore as 94's. http://www.geneberg.com/cat.php?cPath=1_31 |
modok Samba Member
Posted: Tue Jan 19, 2016 5:17 pm Post subject: Re: Case machining for larger cylinders |
92 cylinder bottom 96mm
94 cylinder bottom is 97.3mm |
Posted: Tue Jan 19, 2016 6:29 pm Post subject: Re: Case machining for larger cylinders |
Rome wrote: |
Thanks, that's what I needed. Probably going to get thickwall 92s and bore to 97.25 or maybe use 94s. _________________ 1963 Ragtop Bug |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Wed Jan 20, 2016 6:33 am Post subject: Re: Case machining for larger cylinders |
When I use 94's I cut the case for 92's and have the cyl cut to fit the 92 spec. This way you have more sealing surface for the base of the cyl. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
