Volksdraggin Samba Member
Joined: December 19, 2009 Posts: 320 Location: Bryan, Texas
Posted: Fri Jan 22, 2016 5:27 pm Post subject: Mexican Beetle Starting Issue |
I have a 2003 beetle and recently started to not start. The n80 valve is clicking whicheck I never noticed before. I went to locate a new n80 valve with zero luck.
Any suggestions? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jan 22, 2016 5:36 pm Post subject: Re: Mexican Beetle Starting Issue |
"Not start" as in cranks good but no fire?, or turn the key and nothing but a click? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jan 22, 2016 6:31 pm Post subject: Re: Mexican Beetle Starting Issue |
Now that you mention it, the starter won't turn over with the key which I assume is an issue with the ignition (I've been starting it for over a month with jumper on the starter) but when I mean not start, I mean it won't begin running if I try to push start or use the starter. It was running just fine yesterday but this has been an issue the last few weeks. Usually I just cycle the key a few times and it will fire up. |
Posted: Sun Jan 24, 2016 10:23 am Post subject: Re: Mexican Beetle Starting Issue |
All of that points towards a funky ignition switch, maybe a Mexibeetle expert knows of another possible cause. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Sun Jan 24, 2016 10:34 am Post subject: Re: Mexican Beetle Starting Issue |
Maybe check relay #30, not the same symptoms, but worth a look:
http://www.1600i.de/1600i-elektronik/relais-steuergeraet/CheckingandrepairingtheECUrelay.htm _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
