pjlove10 Samba Member
Posted: Fri Jan 29, 2016 8:52 am Post subject: Car shut off while driving. Wont start. No electrical. |
Hey ya'll.
Maybe I can get some ideas here. Last night I drive my car around the block, like I do every couple of days. While driving, it shut off. Both the Alt and Oil lights went on at the same time, then it turned off. I coasted it to the side of the road. After that I didn't have any electrical. Nothing. Didn't start either. No click or turnover. Just: DEAD. Any ideas? I had it towed home. Heh...
Thanks!
Aaron |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jan 29, 2016 9:09 am Post subject: Re: Car shut off while driving. Wont start. No electrical. |
NO lights either?
First I would check battery and ground cables at battery, be sure they are clean and tight... Also check other ends of cables at chassis connection and starter solenoid.... If all good there check 12 power connection at voltage regulator connections at B+ terminal, if good there check the connections on back of light switch (terminals 30) then to fuse panel...
Simple tool like test light will help find (or not find) the 12 volts and where you are losing it.... Also knowledge of wiring diagram and having one for your year model will help...
http://www.thesamba.com/vw/archives/info/wiringt1.php
Posted: Fri Jan 29, 2016 9:13 am Post subject: Re: Car shut off while driving. Wont start. No electrical. |
I will try these steps. Yes, no lights at all. Just dead. Thank you so much!
Aaron |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Jan 29, 2016 11:00 am Post subject: Re: Car shut off while driving. Wont start. No electrical. |
Source battery 12v ----> ground terminal loose ---->fuses _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6025 Location: CONGERS, N.Y.
Posted: Fri Jan 29, 2016 12:37 pm Post subject: Re: Car shut off while driving. Wont start. No electrical. |
Mostly not the battery but would be a good idea to check the battery with a meter and see if it is at least 12v. I have seen batteries go in a zillion ways.
It could have shorted internally. once tried jumping one and had to remove the battery and go from another car to the cables not attached to the battery. It started. Had to get a new battery, not a good idea to run it without the battery load. if it is ok and the battery ground is good you can run a wire from the + side of the battery to the 12v side of the coil. The dash should light up and you should be able to start the car. You just by passed the key switch etc. May be the key switch. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
Posted: Fri Jan 29, 2016 4:51 pm Post subject: Re: Car shut off while driving. Wont start. No electrical. |
I've lost all power before, check your regulator. there will be (2) big red wires going to the same terminal, one goes to the battery, and the other feeds the car. If one of those came off, then no power. I've had the terminals get old and corroded to where they would break and fall apart. _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Fri Jan 29, 2016 6:49 pm Post subject: Re: Car shut off while driving. Wont start. No electrical. |
Driving the car around the block? Take your oil cap off and look at it. If it looks like a chocolate milk shake, you are loading your crankcase with water. Same with your exhaust. You need to drive it long enough to cook the water out of it. Short hops are murder on it.
See - your car was trying to tell you something... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Sat Jan 30, 2016 8:45 am Post subject: Re: Car shut off while driving. Wont start. No electrical. |
Clean any problem connection well and/or replace any bad connectors and protect from corrosion with dielectric grease....
