How to fit a stock muffler on a stroked engine
perello
perello is offline
PostPosted: Wed Jan 27, 2016 4:27 am    Post subject: How to fit a stock muffler on a stroked engine Reply with quote
This may be answered before...but I can't find it.
How you guys go when fittting a stock muffler on a stroked engine?
Do you bend the pipes that go to the heads to fit or better re-do welds?
In my case its a stock 36hp muffler to be fitted to an okrasa engine (spacing increases by half an inch).
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
perello
perello is offline
PostPosted: Tue Feb 02, 2016 12:51 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
to answer myself..
After trying to bend pipes with no satisfactory results the easier way is to redo welds
1974 German Thing
1978 Bug 1200
tobiasax
tobiasax is offline
PostPosted: Tue Feb 02, 2016 9:55 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
Half an inch wider? Shocked What crank and rods do you use?
__________________________________________
perello
perello is offline
PostPosted: Wed Feb 03, 2016 1:15 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
rather ask Joe Ruiz, he did the build
1974 German Thing
1978 Bug 1200
Mr. Okrasa Premium Member
Original Old Speed
Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Mr. Okrasa is offline
PostPosted: Thu Feb 04, 2016 1:40 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
In all my years (40+) building these little engines, I have never used any amount of barrel spacers that equaled 1/2" combined. Without looking at the engine, the problem is the muffler pipes. I have purchased new mufflers with the exhaust flange in the wrong location. Another problem is if the muffler has had a rough "shelf life" and maybe dropped on its end, the pipe(s) would be bent inward thus decreasing the distance between the 2 & 4 exhaust flanges. What I have done to fit new Abarth mufflers to stroked Okrasa engines is fit/start the #2 pipe first and then bend the #4 pipe outward and try to get the flange started onto the exhaust studs. I apply heat to the #4 exhaust pipe until it "softens" and bends into position as the nuts are drawn down until the flange square is with the head. If you look closely at the #4 exhaust pipe below, you can see where the paint has burned off as I heated it when pre-fitting before ceramic coat.
BTW: Did I actually build this engine or is someone passing off an engine that looks like mine in order to raise the price?
This has happened many times before! Shame on you What's the history/origin of this engine above?
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
perello
perello is offline
PostPosted: Thu Feb 04, 2016 6:52 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
Hi Joe,
Do you remember shipping a box with an engine to Spain?
You sent it to me Smile
Yes until now my bus its not restored to a point I can dedicate time to fit the engine...
Barrels on that engine do have a bottom spacer, but of course muffler may not have a standar fitting width...my question was only on the best method to make it fit (with no answers)
1974 German Thing
1978 Bug 1200
txoval
txoval is offline
PostPosted: Thu Feb 04, 2016 6:57 pm    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
Just a question, if you installed at stroker crank, Okrasa dual port heads/bigger valves, and dual carbs, why are you choking it with the stock exhaust?
Vintage Speed's 36hp performance exhausts have adjustable flanges to work with stroker engines, plus have the stock single or dual tips. They also sell an Abarth replica that looks great (what I have).
It looks like you fixed your issue though...
tobiasax
tobiasax is offline
PostPosted: Fri Feb 05, 2016 12:05 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
If you use a VW original exhaust with free flowing end pipes you have a very good solution. The Original VW exhaust has no restrictions inside plus it has equal length pipes. In the "souping the VW engine" book from 1959 the stock muffler with better end pipes is the recommended solution.
As far as I know the Vintage Speed exhaust does not feature equal length pipes.
I run a NOS 30/36 hp system with Theo Decker end pipes on my 1295cc.
https://www.youtube.com/watch?v=_joJzUv3V9s
(please note that "stock" aftermarket systems typically have internal restrictions and lack equal length pipes.)
perello
perello is offline
PostPosted: Fri Feb 05, 2016 12:44 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
txoval wrote:
Jwhy are you choking it with the stock exhaust?
the easy answer: I had one german original and I like it Smile
others would argue why use this engine on a bus with RGB transmission, the answer would be the same Smile
1974 German Thing
1978 Bug 1200
txoval
txoval is offline
PostPosted: Fri Feb 05, 2016 6:18 pm    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
That's a good answer! If you are ever in the market for a new one, I'd recommend a vintage speed muffler, very high quality
perello
perello is offline
PostPosted: Mon May 29, 2017 3:30 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
first start
1974 German Thing
1978 Bug 1200
Peter_N
Peter_N is offline
PostPosted: Tue May 30, 2017 2:45 am    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
Nice Perello, I've been looking into using the same engine setup for my split (with small nut RGBs).
I'm very interested in the general performance of the setup in a RGB splitbus. Please keep us updated Laughing
My 1958 PGSG project topic
exotic plants
exotic plants is offline
PostPosted: Tue May 30, 2017 4:05 pm    Post subject: Re: How to fit a stock muffler on a stroked engine Reply with quote
perello wrote:
first start
Looks very nice.
1956 Beetle - Jungle Green.
Parts needed to complete:
Front driver side fender.
Rear driver side fender.
Cash waiting.
