johnnygreenham Samba Member
Joined: January 17, 2013 Posts: 456 Location: Upper Jay NY
Posted: Sun Feb 14, 2016 12:56 pm Post subject: HELP: Broke down in Panama... AAZ alternator pulley |
So I haven't posted here for a while but that's because my wife and I moved into our van in the states and then decided to drive down to Panama. Broke down a few times and managed to fix everything without too much trouble.....until now.
We are on our way home and was on the mountain pass across to Bocas del Toro in the north west. Suddenly I lost my tach reading and my battery light came on. Pulled over and heard a slight whirling from the alternator. A quick check and the new-ish (18,000 miles) alternator clutch pulley has shit the bed. Just spinning both ways now and not turning the alternator at all. Drove it on the battery alone to a city called David about 100km away. Yay for mechanical diesels.
We have been here for two days and can not find a parts store that has German anything parts anywhere. I'm starting to think there is a conspiracy. Every parts store seems to be Asian/Japanese manufacturers only. I did not bring the original solid pulley or my tool to remove the clutch pulley which may end up being just as hard to find as the part itself. Will probably resort the the screwdriver in the alternator blade trick and cross my fingers. We left the casino this morning which we limped to last night and are now staying in a hostel where I can work on the van a little more. Haven't removed the alternator yet so not sure if driving the distance we did, on the busted pulley heated the shaft of the alternator up and damaged it or if the alternator has frozen. Seems like no one has Bosch alternators here either so swapping the alternator out may not as easy as I thought. If nothing else I got a chuckle at one store when there solution was ebay.eu
I'd be greatful for some part numbers of alternators that may fit like a 120Amp TDI one but it seems like german anything here is just not that popular and not sure if any modifications are required to fit another sized alternator..... BUT saying all this please post alternators that will work, especially larger amp alternators with a 'W' terminal.
I thought that this pulley was similar to a ford one used but ford parts are pretty hard to find here also. Trying to find Ford and VW dealers tomorrow as Sunday is a bust for most places in town.
Can people throw in some ideas or possible parts that may work. The shops did have a 7 grooved pulley from a Nissan which is 65.5mm diameter (10mm to large and I have no idea if the spines are the same or if the ID is similar. They seemed pretty excited when they found it and not so excited when I turned them down because it was so different.
These are the specs I have in my notes for the pulley. The engine is our beloved AAZ 1.9TD
The Specs for the pulley I have are are as follows.
Manufacturer VOLKSWAGEN
Number 028 903 119 AA
Description Freewheel Clutch, alternator
Outer Diameter [mm] 55
Width [mm] 40,3
Production Number
1220902
Cross numbers
FORD 1106734
FORD 1469755
FORD 6M2110344BA
FORD 95VW10344FA
HK G009Z
INA 535000110
SEAT 028903119AA
SEAT 028903119P
SKF VKM03106
TRIPLE FIVE 0380340
TRIPLE FIVE 139281
TRIPLE FIVE 335170
TRIPLE FIVE MBI28310
TRIPLE FIVE PBT8566
TRIPLE FIVE RKT2056
TRIPLE FIVE TA20511
TRIPLE FIVE Y2000
VOLKSWAGEN 028903119AA
VOLKSWAGEN 028903119AQ
VOLKSWAGEN 028903119P
I'm 99.9% sure that this web page has some of the makes/models that this pulley fits, so I can start there but its a bit of a rabbit hole.
https://infopart.org/ford-1469755-part
In an hour or so I'll start to pull the alternator when it's cooled off.
Appreciate any help thrown our way. Pura Vida! Help us get home!
Johnny _________________ 1982 Diesel 1.9TD AAZ |
rlevans Samba Member
Posted: Sun Feb 14, 2016 4:31 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
Could you weld the pulley (inside hub to the outer race(not to the shaft), and provided you can find a welding shop) solid until you find a new clutch pulley? |
Posted: Sun Feb 14, 2016 5:19 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
I must be getting tired on this trip because that is something I just did not think of and it is a great idea. I have no idea what metals the pulley is made from. Might be a tricky weld but totally doable. Lets make this our back up plan now and I like it. _________________ 1982 Diesel 1.9TD AAZ |
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Sun Feb 14, 2016 5:39 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
That's exactly what I was thinking. If they are incompatible for welding you might be able to have a machine shop affix the two together by pinning or broaching it for a keyway. Another thought is they might be able to modify a new Japanese pulley or your alternator's shaft depending on what you have. Where there's a will there's a way. Good luck. _________________ Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sun Feb 14, 2016 5:55 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
Here is a good read on decoupler style pulleys. They are being used on a lot of cars nowadays.
http://www.gates.com/products/automotive/passenger...ulleys-adp _________________ Independent German Auto
671 Fern Drive
(321) 449-4665
Posted: Sun Feb 14, 2016 7:16 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
Quote: |
This is a case of too much technology failing. |
I could not agree more right now. I was kicking myself when I found out this failed. I was trying to explain to my wife what had happened and that I hadn't brought the original one with me as I thought this one would be ok due it being almost new before we started this adventure. I explained that the original one was just a solid piece and that this would not have never happened with the original one. She looked at me and said "so why did you swap it for the clutched one". To which I tried to justify by explaining about the forces when a diesel stops and that the crank nose would be damaged over time. Then I realized that I'd swapped the AAZ crank for a 1Z crank and didn't really have to worry about the crank nose problem, so I actually don't need this weak part in the system anymore. Of course all this doesn't get us back on the road and I would be very happy to find a solid pulley right now but I don't have any part numbers of a solid version to give to anyone to start with. To be honest that is just not how it seems to works down here. Everyone appears to privately owns their auto part store and what they have on the shelf appears to be what you can buy. We tried getting a few shops to try and see if they could order the part in but it seemed like they didn't have a system to order anything that wasn't from the norm. They would just say that they could not help anymore, but they always gave us directions to someone else. I think I may have to try and get creative or see if I can find one that is really close. If i can find a Bosch alternator then I'll just have to buy that with the pulley attached. There are always ways it's just a matter of how long you are stuck somewhere. We will be cutting it close with our Guatemala vehicle re-entry permit if we get stuck for too long. For me its time for another beer and some more brain storming. _________________ 1982 Diesel 1.9TD AAZ |
?Waldo? Samba Member
Posted: Sun Feb 14, 2016 7:37 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
While it may seem like excessive engineering, the high inertia alt used with the no-slip multi-v belt puts excessive loads on the end of the crankshaft. Without the decoupler alternator pulley, the crank sprocket will eventually fail and destroy the engine. I'd rather have the alt pulley fail than have the pistons mashing the valves. The D-shaped crank is better, but without the clutched pulley it too will fail in time. |
Posted: Sun Feb 14, 2016 8:19 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
If your freewheeling pulley is whole, just not functioning as designed, simply remove it and have a shop weld the outer pulley to the inner shaft sleeve and run it as a solid unit for the duration.
If you lack the special tool to remove it, some very cautious welding utilizing steps to abate the heat build up would work, it would take time and pack with cooling ice to save your generator from damage, but it would work.
Even drilling some holes into the bearing gap and tapping it for some machine screw threads then run in some bolts locking the portions together could work.
Evenly spaced and sized to maintain balance.
Looking at photos of the Bosch pulley, would welding a large washer to the outer pulley and the inner bushing do the trick?
BTW, I understand the technology behind the pulley, but for rural trips as this, in my book simple is better where possible. There is more of a chance at performing simple repairs on the fly.
My Dad often spoke of the simplicity of the common Jeep during WWII and how they kept them going in the most dire of situations.
Having owned an early Jeep in the 1960's clearly illustrated his point to me.
This may have been the basis for my love affair with the early air cooled Beetles.
Ghia
Vanagon
Beetle
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Feb 15, 2016 8:34 am Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
I am not able to look up the AAZ, but the AHU has this pulley number from Gates in the aftermarket. http://www.rockauto.com/catalog/moreinfo.php?pk=679060 Would that work? I see pulleys at IMC and World Pac for the ALH. I carry the tool, but will add a pulley to my list of spares.
Could that work? I can't imagine what the freight would be to get you the tool and a replacement pulley, but it is doable. mark _________________ ☮️ |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Mon Feb 15, 2016 9:07 am Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
Not that this will help you at all, what was the brand alternator did you use? Pulleys do fail, but I have only run into them seizing which causes a lot of vibrations with the drive belt.
I have found if the sales pitch says it has a lifetime warranty, it's time to steer clear. |
SonnyApril Samba Member
Joined: April 15, 2015 Posts: 4 Location: Corpus Christi, Texas
Posted: Mon Feb 15, 2016 11:00 am Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
If you can't find the parts needed in that town maybe find a shorter belt that bypasses the Alt. and drive in the daytime to the next town. A backup battery and solar charger might be a good investment if you go that route. Best of luck |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon Feb 15, 2016 11:15 am Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
Be cautious on the welding. A lot of folks down there weld, but this has to be welded perfectly square, and perfectly concentric. Otherwise, you'll have a crazy vibration even if its a little off. Even during the welding, the heating and cooling of the separate parts could cause asymmetry of the final assembly. So, doable but find the best guy in the area who can make or use a jig to preserve alignment while welding. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Feb 15, 2016 11:54 am Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
From what I can remember, I tried to find one that was not made in Asia so i think the company was in California.......something like, LActrical, and from what I understand it was made in USA but I'm starting to think maybe it was just tested in USA _________________ 1982 Diesel 1.9TD AAZ |
Posted: Mon Feb 15, 2016 3:33 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
Ok, so we struck out on finding any part that may work. We have ended up having to get it welded. The guy did a decent job. I think I will have to get a drill in the next few days and drill out some of the weld to even out the weight and balance it a little better. There is slightly more weld on one side than the other, not a huge amount but enough that I will probably do something about it in the next week. There are no vibrations coming from the alternator and you would not be able to tell the difference by sound but I can only test it at idle revving it with no load. Under load at 3 times the speed may be a different story and it may start to wear the alternator bearings quicker. This is just a temp fix until we get to Mexico where VW parts seem to be easier to source. _________________ 1982 Diesel 1.9TD AAZ |
fleet_maintenance Samba Member
Joined: November 01, 2013 Posts: 323 Location: Upstate NY
Posted: Mon Feb 15, 2016 6:09 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
I enjoy good roadside fixes.
Would it be easier to weld another glob opposite rather than grind, provided there are no clearance issues? |
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Tue Feb 16, 2016 10:56 am Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
I too was left stranded by an overrunning overrun pulley. I ended up drilling and 'driving' 3- 6mm bolts in the clutch of the pulley to lock it all together, it would still be on the van if I didn't keep a spare one at the shop. _________________ www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab |
Witless Joe Samba Member
Posted: Tue Feb 16, 2016 3:18 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
Andrew A. Libby wrote: |
But in *how much* time will it fail?
As John Maynard Keynes said, "In the long run, we are all dead."
As this thread proves, in the short run, you may have a failed decoupling alternator pulley.
So is there any real objective data on this point, or is there only speculation and opinion?
Do we have *any* documented cases where people had a D-shaped crank end on their AAZ, and also a solid alternator pulley, where there was a crank failure?
If so, how many miles on the engine when that happened?
With respect, Andrew, unless we have some objective data, this seems like only a theoretical bogeyman, for people with the D-crank instead of the stock AAZ keyway crank.
Just how much prophylaxis do we really need, especially when it carries the danger of an early failure all by itself?
I realize this underlying theory has made the decoupler pulley mod a hugely popular mod for AAZ owners. Probably it's so popular that the number of people with D-crank AAZs and solid alt pulleys is so small as to be statistically insignificant at this point. But if any of those people have had crank failures, then I'd like to know, and compare it with the number of crank failures experienced by people with both the D-crank and decoupler pulley. |
Posted: Tue Feb 16, 2016 3:35 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
I personally assisted a friend with an AHU that had the D-shaped crank fail. Yes, it had the decoupler pulley on the alt, but the pulley had seized and no longer uncoupled on overrun. I do not know how many miles he drove without the decoupler working. That wasn't specifically an AAZ with D-crank but the situation was the same. Mark that down as one firsthand account of failure. I have heard of several other similar AHU failures, but as they did not happen to me, they are now secondhand accounts. I'm sure if you go on TDI club you'll be able to track down several firsthand failed AHU D-cranks and of the folks in that group who then checked the alt for decoupling, virtually 100% will have had a locked up decoupler. If you feel there is no cause for concern, I would encourage you to run a solid alt pulley. Please report back how many miles it takes for your crank to fail. |
Zeitgeist 13 Samba Member
Posted: Tue Feb 16, 2016 4:22 pm Post subject: Re: HELP: Broke down in Panama... AAZ alternator pulley |
MB also started installing overrunning alt pulleys as of '98 or '99 on their turbodiesel models. The '99 engine I put in my 124 wagon has one, and it looks and acts exactly like the version on my '02 ALH. These were added to higher torque engines for some reason despite the concerted efforts of bean-counters who were trying so desperately to keep costs down at the time _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
