pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2068 Location: Ontario Canada
Posted: Wed Feb 24, 2016 3:08 pm Post subject: Type 4 engine tin |
Reassembling all the painted engine tin today. Everything went pretty smooth until I realized I had one piece left over...yikes. In the Haynes manual on page 21 it's called "warm air duct (R rear)" Rear as in near alternator or near firewall? I can't see/figure out where it goes at such a late place in the assembly. Anyone? _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Wed Feb 24, 2016 3:50 pm Post subject: Re: Type 4 engine tin |
photo please. _________________ where its cold and snowy |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21510 Location: Oklahoma City
Posted: Wed Feb 24, 2016 3:58 pm Post subject: Re: Type 4 engine tin |
If memory serves it has one or two botts that bolt to the 3/4 cylinder side cylinder cover plate....listed as part #2 in the lower picture on page 21.....and has two bolts that attach it ro part # 5 in the lower picture which is the 3/4 lower "sled tin".
You should be able to put it on after removing the lower sled tin ......with a little wiggling. Ray |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Feb 24, 2016 4:45 pm Post subject: Re: Type 4 engine tin |
Or perhaps the warm air duct that goes from 1-2 side into the engine bay stock air cleaner set up. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Tcash Samba Member
Posted: Wed Feb 24, 2016 5:05 pm Post subject: Re: Type 4 engine tin |
010-27 is the culprit _________________ "Always waiting for tomorrow ruined everything"
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51118 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Feb 24, 2016 5:18 pm Post subject: Re: Type 4 engine tin |
You can't just leave it out if that's what you are hinting at, try to gently jam it in but I suspect you'll have to move a step backwards before proceeding further.
I know it's exciting to be remantling but now's the time to do it right, it won't be any easier later. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Feb 24, 2016 5:35 pm Post subject: Re: Type 4 engine tin |
Great videos but...The you tube video leaves out the installation of this part. Looking at the alternator,is it on the right surrounding the alternator or firewall end? _________________ "Always waiting for tomorrow ruined everything"
Posted: Wed Feb 24, 2016 5:46 pm Post subject: Re: Type 4 engine tin |
Like I said POST A PHOTO of the tin these numbers mean nothing. _________________ where its cold and snowy |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Wed Feb 24, 2016 5:50 pm Post subject: Re: Type 4 engine tin |
Quote: |
Like I said POST A PHOTO of the tin these numbers mean nothing. |
Right? I was thinking the same thing. Then you said it the first time.
Then I thought the same thing.... _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Wed Feb 24, 2016 5:58 pm Post subject: Re: Type 4 engine tin |
Posted: Wed Feb 24, 2016 6:00 pm Post subject: Re: Type 4 engine tin |
Ok maybe this will speed things along these two are on the right side of the engine one is up by the firewall and ones behind the alt which one?
Goodhand77 Samba Member
Joined: August 18, 2013 Posts: 236 Location: Forest Ontario
Just rebuilt mine recently and took a lot of Work to makesure I had ALL the tin first clean and shiny
So post a photo of the extra piece and we can all stop trying to guess _________________ my world consists of my three girls , my wife and my daughters
and my 72'S!!!!!
1972 beetle sedan almost original
1972 westfalia current project, and loving it!!! |
Posted: Wed Feb 24, 2016 6:03 pm Post subject: Re: Type 4 engine tin |
That one ok pull the blower housing. _________________ where its cold and snowy |
Posted: Wed Feb 24, 2016 6:05 pm Post subject: Re: Type 4 engine tin |
Sorry photos came up slow that piece fits in on alternator side near rear of bus so rear passenger side pretty sure it just kinda snaps into place as you mount other pieces no bolts hold it I place
I will go have a closer look at mine
But you need to install for sure directs heat / air flow
These other guys really know there stuff so don't ignore their advice _________________ my world consists of my three girls , my wife and my daughters
and my 72'S!!!!!
1967250s Samba Member
Posted: Wed Feb 24, 2016 6:15 pm Post subject: Re: Type 4 engine tin |
Ok, that piece goes to the rear of #2 cylinder. The top edge there in the pic goes against the engine case. That hole at top right is the cable from the thermostat, so is upper left. The screws at the bottom secure the top right tin over the cyllinders. To get it in the fan housing will need to be loosened up so it can be slid in. The rear edge goes under the fan outlet lip and flap. You kind of have to hold it in position and push the fan in to hold it there. _________________ '72 Elm Green Deluxe |
Posted: Wed Feb 24, 2016 6:38 pm Post subject: Re: Type 4 engine tin |
thanks-I'll try tomorrow _________________ "Always waiting for tomorrow ruined everything"
Tcash Samba Member
SGKent Samba Member
Posted: Wed Feb 24, 2016 9:05 pm Post subject: Re: Type 4 engine tin |
BTW TO STRESS WHAT TCASH posted - taking the fan apart is a no-no. Without a lathe and time on your hands it is near impossible to get it running true again. Ask me how I know. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Feb 25, 2016 6:52 am Post subject: Re: Type 4 engine tin |
All done-simply slip that piece of tin in it's place...FIRST! haha- will nominate the videos for a sticky _________________ "Always waiting for tomorrow ruined everything"
