Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Fri Feb 19, 2016 6:42 pm Post subject: New Case Corrosion |
Yes, I searched and read a ton but still am not sure about the answer.
I acquired a brand new Brazilian AS41 case that was stored in a damp area for years, it has considerable corrosion but not rotted beyond use. I want to try chemical cleaners, so far vinegar and a mild aluminum cleaning acid without success. What chemical melts corrosion from these magnesium cases? Soda blasting the main saddles might be the final step.
Thanks! _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Posted: Fri Feb 19, 2016 6:48 pm Post subject: Re: New Case Corrosion |
Pictures? _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Fri Feb 19, 2016 6:50 pm Post subject: Re: New Case Corrosion |
Remember "chemicals" don't melt corrosion, they eat the metal out from under the corrosion so it falls off. I'd go soda blasting all the way. Or, first use a fine stainless wire brush on a air die grinder to remove what non-critical areas can be reached, then soda blast the rest. It's easy to become obsessed with getting it cleaned up but honestly mag oxide isn't particularly harmful thing to have in there. it's not a sin to be ugly |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Feb 19, 2016 7:27 pm Post subject: Re: New Case Corrosion |
I bought a few cases from a guy that had hoarded them in his garage, about 50 feet from the bay on Long Island. They were all standard, uncut, and covered with salt air corrosion. Soda blasting is the answer! Clean off everything you can with a brass or stainless toothbrush, and then soda blast them good. I run them through a thorough hot water wash after soda blasting, with brushes through the bores, and dry them in front of a propane salamander. I've had two of them sitting for two years since doing this and the corrosion hasn't come back.. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Fri Feb 19, 2016 10:34 pm Post subject: Re: New Case Corrosion |
Phosphoric acid WILL literally melt/dissolve, the powdery corrosion. Use it diluted and slowly build the strength up and when done, neutralize with,baking,soda,and water and rinse well......not all acids are the same. Ray |
Posted: Sat Feb 27, 2016 2:26 pm Post subject: Re: New Case Corrosion |
I didn't try phosphoric acid, do you know where to buy it? (swimming pool place, construction supplies, etc?)
Here's pics before, the saddles are corroded, rough to the touch and lifters will not go into the lifter bores:
Soda blasting was the trick- it took (2) 12 lb bags ($5 ea at Costco or cheapie store). I used a simple siphon tube setup.
Here's pics after: There's still some staining but the saddles are smooth to the touch and should be fine holding the bearings. Lifters slide in nicely and are free in the bores.
'65 Standard Bus
Build threads:
Thomas Lindemann Samba Member
Joined: May 07, 2013 Posts: 111 Location: Gloucester, VA
Posted: Sat Feb 27, 2016 3:50 pm Post subject: Re: New Case Corrosion |
Have it Vapor Blasted and drive on |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
Posted: Sat Feb 27, 2016 4:44 pm Post subject: Re: New Case Corrosion |
I have a case I would like to do the same to, could you explain how to setup a simple siphon? Your case looks great, Casey _________________ 1966 Java Greens |
