AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Tue Mar 01, 2016 6:03 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
I'm running the OE Diesel CAT ........ once it begins to operate (which is fairly quick, even on a cold day), the odor is very similar to chlorine (bleach). And, at WOT it does not bellow black smoke ... maybe a light cloud of dust. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Wed Mar 02, 2016 12:16 am Post subject: Re: Syncro TDI Info and the WBX Conundrum |
A diesel vanagon never will be as quiet as a petrol one.
I have a 1Z mtdi with all the later JX exhaust and inlet setup, have hydro mounts and it is still a lot louder than the JX was (it runs harder so the sound is from combustion, direct injection vs indirect injection) and the JX was louder than my friends DJ.
And they wont be quiet without the factory underside cover tray.
Plus that the latest diesel vanagons in europe (from model year '89 I think) had an extra sound deadening foam like material inside the engine bay on all the exposed flat surfaces and a bigger exhaust silencer to meet the EURO1 environmental standard that involved a sound pollution limit.
The petrol ones had no modification required.
A friend of mine has an AFN e-tdi Vanagon. With late JX exhaust, AFN air filter in a 89 van. More silent than my mtdi, comparable to the JX but louder than the DJ. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Wed Mar 02, 2016 12:08 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Loyd Tulluch from the UK showed a photo of a factory VW oil separator that goes inline in the vent tube that runs from the block to the breather "puck". I have never seen this. Is this a worthwhile this to hunt down and install? If so, does anyone have the part numbers for the upper and lower hose/pipe pieces and the separator itself?
_________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Wed Mar 02, 2016 12:15 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
More worthwhile is to add a Mann Provent CCV filter. |
tjet Samba Member
Posted: Wed Mar 02, 2016 3:01 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Yes, the white cylinder. From what Loyd said, "...the air path through it is a bit convoluted...It also looks to have a diaphragm and spring inside". It's meant to catch the oil before it gets to the puck and then it naturally drains back into the block. I've never seen one, so I'm just relaying what Loyd has said about it. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Wed Mar 02, 2016 3:22 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
On mine TDIs i through this tube out.
The seperator would make sense in the other tube going from head cover to inlet. |
Posted: Wed Mar 02, 2016 3:45 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
You can see the Provent in the left lower corner of this photo, to the left of the valve cover.
Last edited by westyventures on Wed Mar 02, 2016 3:58 pm; edited 1 time in total |
Posted: Wed Mar 02, 2016 3:58 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
[quote="westyventures"]You can see the Provent in the left lower corner of this photo, to the left of the valve cover.
Cool, thanks! Is that the ProVent 200? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Mar 02, 2016 4:00 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Christopher Schimke wrote: |
Cool, thanks! Is that the ProVent 200? |
Yes. (I changed the photo to show a later view also, the VNT control wasn't finished in the first photo I posted) |
?Waldo? Samba Member
Posted: Wed Mar 02, 2016 4:32 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Karl, I remember you mentioning having a runaway issue due to the provent install. What was the issue and solution to prevent that happening? |
Posted: Wed Mar 02, 2016 4:49 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Andrew A. Libby wrote: |
The issue was lack of instructions included with the Provent I received. I didn't realize a check valve was required on the drain - if above oil level - and lacking that, it ran away and damaged that pretty 20k-mile engine. The check valve solved it, although too late, because 8000 miles later the engine grenaded due to the earlier runaway which had melted piston crowns. |
Waldi Samba Member
Posted: Thu Mar 03, 2016 1:51 am Post subject: Re: Syncro TDI Info and the WBX Conundrum |
If you put more gimiks into your van, the more you have to worry about.
The engine works also without it.
But the inlet gets more oil with the installed tube from down to up, and its not needed on a 50 degree instal.
Edit:
Also the plastik part on the button with a O-ring is a part more that can cause leaks. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Thu Mar 03, 2016 9:47 am Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Instructions for installation of the Provent are here:
https://www.mann-hummel.com/fileadmin/user_upload/service/catalogues/pdf/ProVent_en_2013.pdf
There is also the Parker/RACOR CCV4500 which is basically the same idea, but different dimensions. I think it is larger diameter so that hurts in a tight engine space.
I saw this for $142. on this website:
http://racorstore.com/racor-ccv55024-ccv4500-hose-...gQodutQAKA
Aside from dimensions the downside is recommended filter change is at 750 hrs. They do also have a little RED pop-up button to tell you when the filter is blocking up so you need to change the filter...so far I have about 2000 hrs since the last filter changes and the RED button has not popped up. However, I am changing the generator oil & oil filters every 250 hrs.
If your engine is high mileage and worn out then you'd maybe want to change it every oil change. Provent states it depends on the application.
http://www.parker.com/literature/Racor/55021_Rev_C_CCV_Series.pdf
I have these installed on my Generators and they work as advertised.
The size restrictions would be what dictates which one I would use.
Posted: Thu Mar 03, 2016 9:58 am Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Waldi wrote: |
Edit:
I understand what you are saying about having more to worry about, but these also filter the blow-by oil returning to the crankcase and dirty oil is one less thing to worry about. |
Waldi Samba Member
Posted: Thu Mar 03, 2016 10:06 am Post subject: Re: Syncro TDI Info and the WBX Conundrum |
He ?
A seperator filters the oil ?
Well yes, you have to replace the amount of oil that is in the seperator by new one.
If i worry about dirty oil, i change it. |
Posted: Thu Mar 03, 2016 10:18 am Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Waldi wrote: |
He ?
The do have filters in them. It is not the fine particle filter as used in the main oil filter, but works good for combustion blow-by.
If you change your oil per mfg. recommendation then your covered about having good oil.
I'd really like to see an Oil Centrifuge on the engine. These basically just have a paper liner around the inside wall of a can. Inside the can is a spinning piece with jets on the ends. It simply shoots the oil out the jets and the center spins. Any heavier than oil particles are thrown up against he paper liner and stay there, the hot oil flows back into the crankcase leaving the residue on the paper liner.
You sometime see 1/4" on residue (6-7mm) thickness of residue on the paper.
What they do is increase your oil change intervals up to 500 hr.
But again, something else to worry about cleaning regularly. |
Waldi Samba Member
Posted: Thu Mar 03, 2016 10:26 am Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Sure there are alot of ways to do some things better on every system.
But the stock engines run about 300-500k km.
Isnt it better to leave them alone ? |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
Posted: Thu Mar 03, 2016 2:09 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
I've never had any issues with running a hose straight from the puck right into the turbo inlet pipe. Yes it coats the intercooler in oil but who cares ? I say keep it simple. I don't see a need for the provent. |
Posted: Thu Mar 03, 2016 5:27 pm Post subject: Re: Syncro TDI Info and the WBX Conundrum |
Waldi wrote: |
Edit:
The Mann Provent is not a 'gimmick'. It is a proven and reliable filter to eliminate all oil from the breather system and drain it back into the sump. Every 50-degree TD/TDI engine I've seen has some oil in the intake system. In engine still running the EGR, eliminating oil vapor from the intake also minimizes carbon buildup that ALL EGR-equipped TDIs have in the intake.
Also, a coating of oil inside the intercooler is bound to decrease its efficiency.
Everyone is welcome to do whatever the hell they want. I do it my way and am quite happy with it. |
