AAZ IP Bosch Info, Anyone?
Team WorldTour
Team WorldTour is offline
PostPosted: Wed Mar 02, 2016 3:04 am    Post subject: AAZ IP Bosch Info, Anyone? Reply with quote
So, the Bible covers what was put in the van over all the years it was made.
Now that I have an AAZ pushing it, I need to add a supplement to my -Bentley- Bosch : AAZ Injector Pump.
Does anyone have one of these? PDF?
Cheers!
Nico
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Jeff's Old Volks Home
Jeff's Old Volks Home is offline
PostPosted: Wed Mar 02, 2016 6:38 am    Post subject: Re: AAZ IP Bentley Section, Anyone? Reply with quote
VW never released injection pump internal information to Bentley... You'd need to find it from Bosch.
www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI Smile
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Mar 02, 2016 9:38 am    Post subject: Re: AAZ IP Bosch Info, Anyone? Reply with quote
The Bentley for the B4 Passat covers the AAZ, since it was an option in Canada, though I doubt it will be any more pump specific with the info than a manual for the JX types of engines. I would ask around over at the TDI club for mTDI info, which will probably be much closer to the details needed for your AAZ pump...though not 100% the same.
Casey--
'01 Weekender --> full camper
y u rune klassik?
MsTaboo
MsTaboo is offline
PostPosted: Wed Mar 02, 2016 12:12 pm    Post subject: Re: AAZ IP Bosch Info, Anyone? Reply with quote
VWDiesel Forum:
http://vwdiesel.net/forum/index.php
IDI section for the older engines like the AAZ;
http://vwdiesel.net/forum/index.php/board,6.0.html
Look at the FAQs for links to Bosch guides.
Currently:
Defend democracy, support Ukraine.
Zeitgeist 13
PostPosted: Wed Mar 02, 2016 12:49 pm    Post subject: Re: AAZ IP Bosch Info, Anyone? Reply with quote
Oops, I forgot about that site...even though I've been a member there for lots longer than here. That's where you should go
Casey--
y u rune klassik?
