IdubThee Samba Member
Posted: Tue Mar 22, 2016 9:53 pm Post subject: squareback resurrection troubleshoot..no gas |
Beginning vw tech here... trying to perk up a 68 that has a converted engine...
I tried to fire up the engine for the first time after it had been sitting for several years and she wouldn't start. it seems as though there is no gas getting to the pump. There is new gas in the filter just north of the engine compartment, so its getting at least that far. Pulled the incoming line and blew into it and heard bubbling in the tank up front, so i dont think the line is blocked in any way. Should I swap the pump and eliminate that as the problem? What type should I get? Looks like they are about 30 bucks, so i figure that's about as much as i would spend on a compression testing setup (plus it seems to be hard to find a gauge in the 0-5 psi range.
photo note: These photos were taken a while back, so everything is now hooked up and ready to go.
Thanks for any help
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Tue Mar 22, 2016 10:03 pm Post subject: Re: squareback resurrection troubleshoot..no gas |
Does your oil smell like gas? If so, you know your pump is bad.
I'm suspicious of the SP wires, too. |
Posted: Tue Mar 22, 2016 10:09 pm Post subject: Re: squareback resurrection troubleshoot..no gas |
This photo is kind of old. I have since changed plugs and wires, rebuilt carbs, new points and condenser, moved fuel filter to outside of engine compartment and changed oil. Engine is turning but no fuel is getting to the pump it seems... |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Tue Mar 22, 2016 10:19 pm Post subject: Re: squareback resurrection troubleshoot..no gas |
IdubThee wrote: |
If you have fuel to the pump, but nothing comes out, then the pump is kaput.
Pull the pump, and measure the length of the pump push rod. If it's 110mm long, then it's a generator pump you need. If it's 100mm long then it's an alternator style pump you need. It's also possible that you've got a 100mm push rod under a generator pump, which means it won't pump fuel. I only mention the pump push rod, since you have a converted bug engine case, and we don''t know which pump it has. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Mar 22, 2016 10:43 pm Post subject: Re: squareback resurrection troubleshoot..no gas |
Measured the rod and it's a hair shy of 108mm. Also the flange is recessed which I think also points to generator style. There is no trace of gas in the tip of the incoming line into the pump either... |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed Mar 23, 2016 11:26 am Post subject: Re: squareback resurrection troubleshoot..no gas |
IdubThee wrote: |
I tried to fire up the engine for the first time after it had been sitting for several years and she wouldn't start. it seems as though there is no gas getting to the pump. |
Encountered the same when breaking my car out of storage. I thought the pump was shot, as there didn't seem to be gas getting TO the pump.
Removed the pump, stuck the supply line in a jar of gas and pumped by hand. After a few minutes of this, gas was spurting out of the pump.
Put it back on, no problems. I have a different pump than yours, but worth a try, for free. _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Wed Mar 23, 2016 7:42 pm Post subject: Re: squareback resurrection troubleshoot..no gas |
So you pulled the line going to the carbs and turned the engine by hand until gas came through? or you pulled the line that goes to the pump from the tank and pumped, if so how? |
Posted: Thu Mar 24, 2016 3:43 am Post subject: Re: squareback resurrection troubleshoot..no gas |
IdubThee wrote: |
Pull the fuel line off that feeds the pump, and blow into it listening for bubbles in the fuel tank. This is mainly to check and see if the feed line is plugged. Warning, fuel could come out of that line after you're done blowing thru it, so you might want a catch can of sorts handy. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Mar 24, 2016 8:58 am Post subject: Re: squareback resurrection troubleshoot..no gas |
IdubThee wrote: |
Your fuel pump is diff than mine, but basically work the same.
I removed the fuel pump from the car. Hose to jar of gas to fuel pump. This represents fuel tank to fuel pump.
Then using a pencil, depressed/released the lever inside the pump. This represents the actuator rod.
After about a dozen pumps, fuel was spurting out the delivery side of the pump.
I didn't have to do a Bob suggests since my fuel filter is near the trans (Hint, hint ) and there was plenty flow when I changed it. But worth a try in your situ. _________________ Everything known to man has been written.
Posted: Thu Mar 24, 2016 3:17 pm Post subject: Re: squareback resurrection troubleshoot..no gas |
I'm getting bubbles in the tank when blowing in the supply line. Pulled the pump out and the lever inside doesn't seem to move very freely at all. I'm pushing on it pretty hard with the rod and it's not really budging. Should it be pretty springy back and forth? bad pump? |
