green giant Samba Member
Posted: Tue Mar 29, 2016 6:22 am Post subject: vw oil sump plate problems |
while changing the oil in my 68 bug i discovered some of the studs for the oil sump plate are stripped out. is there any way I can fix this without having to get a new case??? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Tue Mar 29, 2016 7:03 am Post subject: Re: vw oil sump plate problems |
There are a couple ways to fix.
Weather YOU can do this or not is unanswerable by me
There are thread inserts.
where the hole is enlarged and a spring looking item is installed giving new threads. "helicoil"
and another called nutsert again requires an enlargened hole where a short tube like section threads inner and outer is put in the block.
and I believe there are also step studs available. Where the hole is enlarged and threaded to the next size thread. The new stud has afat end that screws into this enlarged threaded hole and the skinny end sticks out just like it was.
And there is the funky I think a 1/4" bolt. A 1/4" tap to the stripped hole allowing a 1/4" american bolt to be used. May have to waller out the plate hole just a bit to 1/4 inch. Going the 1/4" route still leaves plenty of meat for the tread inserts to be tried later. |
Cusser Samba Member
Posted: Tue Mar 29, 2016 7:12 am Post subject: Re: vw oil sump plate problems |
DeathTrap wrote: |
1/4 inch is about 6.25mm, marginally larger than the original 6mm thread size. If one does try 1/4 inch, I would still use studs and not bolts.
I do recommend the step studs though, especially the 7mm x 6mm ones; that's what I'd use on my own engines if I had this issue !!!! Notice the bold and large size? Next time I'll use capitals. Don't cheap out. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Mar 29, 2016 7:18 am Post subject: Re: vw oil sump plate problems |
This IS the preferred repair method, do it once and be done with it
http://vwparts.aircooled.net/Time-Sert-Tool-Rental...l-1610.htm _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Cusser Samba Member
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Fri Apr 01, 2016 6:51 am Post subject: Re: vw oil sump plate problems |
is there a particular reason my reply here was deleted? _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Posted: Fri Apr 01, 2016 5:57 pm Post subject: Re: vw oil sump plate problems |
I'm leaning towards step studs.do u have t drill and tap for them??? How hard are they to install |
Posted: Fri Apr 01, 2016 6:46 pm Post subject: Re: vw oil sump plate problems |
I never saw your post rockrod...I didn't delete it.idk how t delete posts.I'm fairly new t the samba |
buggnuttz Samba Member
Joined: January 28, 2006 Posts: 404 Location: southern cheeseland
Posted: Sat Apr 02, 2016 2:15 am Post subject: Re: vw oil sump plate problems |
if the studs pulled out then yes step studs can be used.
if the studs only stripped then replace the studs _________________ owned 39 different VWs so far |
Cusser Samba Member
Posted: Sat Apr 02, 2016 7:40 am Post subject: Re: vw oil sump plate problems |
green giant wrote: |
For the 7mm x 6mm step studs, personally I'd run a tap through. 7.0 x 1.0mm tap
For 8mm x 6mm step studs, I'd drill first, then tap. 8.0 x 1.25mm tap
These are easy to install. And with these options, you haven't "burned your bridges" if you decided at a later date to go to Time Sert.
I definitely recommend the metric step stud approach, rather than going to 1/4-inch or other SAE thread pitch; but it is YOUR VW.
With a Time-Sert you'd also drill first, tap to whatever the Time-Sert details, then use the Time-Sert tool to complete the installation. Could one get a tiny amount of oil seepage between the Time-Sert outer thread and the case? I would imagine so. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
