Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Sat Apr 09, 2016 9:59 pm Post subject: Door contact switch wiring question |
PostPosted: Today 2:30 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) Reply with quote Edit/Delete this post Delete this post
Ok. I'm looking at my door contact switch with contact for buzzer. I'm looking at the diagram and at where my wires are. If the button on the diagram is oriented correctly, then my wires are wrong (done my PO and explains why my buzzer and interior lights didn't work)
Here is the question. Where should each of these wires go or what do the internals of this switch act? Here is the diagram I'm working off of. (F3 is the object in question) http://www.thesamba.com/vw/archives/info/wiring/baybus_70_wiring.jpg
And here is what I have.
_________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Curtquarquesso Samba Member
Joined: April 14, 2010 Posts: 63 Location: Orlando, FL
Posted: Sat Apr 09, 2016 10:35 pm Post subject: Re: Door contact switch wiring question |
Well, you can run a simple continuity test with a volt meter to find out whether the switch opens/closes on opposite left/right sides, or back/front sides of the switch.
Brownish-grayish wire: To ground. Goes through T1 insulated connector behind instrument cluster as seen in diagram, then goes to the steering wheel.
Gray/Black Striped Wire: Goes to the buzzer relay, if you still have one.
Brown/White Striped Wire: One wire goes to the dome light, one wire goes across the the other door switch.
White: I'm not entirely sure actually. Where does it lead to currently? |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Sat Apr 09, 2016 11:02 pm Post subject: Re: Door contact switch wiring question |
You're holding F2 in your hand. The wires look correct to me. They are all ground wires and when the switch closes (door open) they are all grounded to the frame through the switch and screw.
Gray/Black goes to buzzer relay #85
Brown/White wires go to right door switch and interior lights
Brown wire goes to ignition switch
White wire goes to ???
Clean the contacts on the switch and try touching the unpainted metal part that you're holding in your hand to a good unpainted ground. _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Sat Apr 09, 2016 11:27 pm Post subject: Re: Door contact switch wiring question |
My wires in my 70 didn't match the diagram, but things are working.
Here is where my wires are going:
1) Brown/white dual wire one goes to interior light and passenger door jam.
2) Brown is ground
3) Black/white is going to ignition
4) White is going to the buzzer _________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
Posted: Sun Apr 10, 2016 8:27 am Post subject: Re: Door contact switch wiring question |
BayCreamPuff wrote: |
Clean the contacts on the switch and try touching the unpainted metal part that you're holding in your hand to a good unpainted ground. |
So really front and back and side to side orientation doesn't matter then. I just have to make sure that any of the wires go to any one of the specified locations on the diagram. Perfect! Thanks! _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Tcash Samba Member
Posted: Sun Apr 10, 2016 9:36 am Post subject: Re: Door contact switch wiring question |
The brown wire with the blue connector has been added by a PO.
That wire should go to a ground lug on the body located to the left of the fuse box.
The other wires are ok where they are. Note there is two sides to the switch. One side is for the door buzzer and the oher side is for the light.
Tcash |
Posted: Sun Apr 10, 2016 10:15 am Post subject: Re: Door contact switch wiring question |
Tcash wrote: |
Tcash |
Not the PO. The CO. And thank you tcash. I'll give it a shot. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
SevenOaks Samba Member
Joined: April 24, 2012 Posts: 264 Location: Friendswood, TX
Posted: Wed Jul 11, 2018 6:27 pm Post subject: Re: Door contact switch wiring question |
Okay, so I know this is an old thread but I stumbled across it while searching for something else. It enlightened me enough to go take a closer look at my dome lights, dash light switch, door switches and wiring. One hour later the front dome light now comes on when either door is open (and turns off when the doors are closed) and the rear dome light turns on and off with the dash switch. Woo Hoo! I’ve had the bus for five years now and it’s still a thrill to fix something even that small.
_________________ David
1974 9-passenger bus
1969 Single cab
1966 Beetle |
Tcash Samba Member
Posted: Wed Jul 11, 2018 8:23 pm Post subject: Re: Door contact switch wiring question |
SevenOaks wrote: |
Okay, so I know this is an old thread but I stumbled across it while searching for something else. It enlightened me enough to go take a closer look at my dome lights, dash light switch, door switches and wiring. One hour later the front dome light now comes on when either door is open (and turns off when the doors are closed) and the rear dome light turns on and off with the dash switch. Woo Hoo! I’ve had the bus for five years now and it’s still a thrill to fix something even that small. |
stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Mon Oct 01, 2018 1:27 pm Post subject: Re: Door contact switch wiring question |
Been hunting for the correct thread, but can't find it at the moment. Is it correct that Late Bays don't have a door contact/buzzer switch on the passenger side? _________________ 1979 Microbus |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Oct 01, 2018 2:04 pm Post subject: Re: Door contact switch wiring question |
No bays have the buzzer contact on the right door, only a single pole switch for the dome light, very early buses (68/69) didn't have any switches at all on either side. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Joined: January 01, 2007 Posts: 16862 Location: sticksville, ct.
Posted: Mon Oct 01, 2018 2:15 pm Post subject: Re: Door contact switch wiring question |
I forget what year it changed...but yes. door switch on drivers side did the cab light, and door switch on slider door did cargo light. neither were controlled by any dash switch as it was omitted _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Oct 02, 2018 1:54 pm Post subject: Re: Door contact switch wiring question |
The dome light switches can also vary by country. My Irish RHD double cab, although 1978, had a dome light switch only for the driver's door. But now it is rewired to have switches on all four doors. Yes! It's now a 4-door double cab.
[I really need to do a build thread on that truck. I've got over 6 years of work and over 2000 photographs to catch up on.] _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
