Body number confirmation help
scottf1887
scottf1887 is offline
PostPosted: Wed Apr 06, 2016 11:04 am    Post subject: Body number confirmation help Reply with quote
Hey guys I was wondering if I could get some help to identify what year I have. I just bought what I was told was a 56. It's got almost incorrect everything but it does have a clearly stamped body number in the front apron. It's showing 489082. My research tells me this is a 53. Any help is appreciated, the pan is much later and it's missing any early oval stuff, like tails that I know about. If this is true it would be awesome, except my parts search just got much harder!! Thanks.
TheLadyBug
TheLadyBug is offline
PostPosted: Wed Apr 06, 2016 12:49 pm    Post subject: Re: Body number confirmation help Reply with quote
Looks to me like body is Oct '53.
You'll have fun finding correct parts; when you do, you may hope you're sitting down as some of it is ridiculous expensive. Embarassed
Aside from tails, you'll want ribbed doors, ribbed fenders, batwing steering wheel, speedo, seats, gas tank, door handles & window latches, headlights, and a bunch of other things are early oval specific. Also, an early 30hp engine dressed correctly; round regulator, engine tin, pulleys and fuel pump are obvious giveaways aside from case stamp.
Does the car have semaphores? Or were they filled in?
Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily
jason
jason is offline
PostPosted: Wed Apr 06, 2016 12:55 pm    Post subject: Re: Body number confirmation help Reply with quote
Its on the wrong pan, make it whatever year you want it to be. Only major difference would be rear apron and door pillars. Pictures of those would say.
scottf1887
PostPosted: Wed Apr 06, 2016 1:58 pm    Post subject: Re: Body number confirmation help Reply with quote
I'll post some pics in a little bit. Its missing every single piece that makes a 53 a 53, this is gonna be fun...What is different in the door pillars, that might be all I have left. Thanks guys!
TheLadyBug
PostPosted: Wed Apr 06, 2016 2:50 pm    Post subject: Re: Body number confirmation help Reply with quote
Door pillar should have the slot for a semaphore on each side, just in front of the rear quarter window. This area is thicker on early cars to accommodate; even if it's been filled in, the size of this area is tell-tale. Later cars had a thinner b-pillar.
Rear apron should have no exhaust cutouts.
Charmaine
57BLITZ
57BLITZ is offline
PostPosted: Wed Apr 06, 2016 3:28 pm    Post subject: Re: Body number confirmation help Reply with quote
On a bare body shell (or a car that has had parts swapped), check for the location of the interior heater vents.
If the heater channels have not been replaced, these can be important clues to determine the year of the car.
'55 and older has an oval-shapped heater vents with mesh screen inside.
'56 has one-year-only heater channels . . . louvered heater vents way up by the front bulkhead.
'57 and newer has louvered heater vents close to the hinge/door pillar.
As you know, the front sheet metal could have been replaced and has negated the stamped body number.
Jesucristo es mi Señor y Salvador!
scottf1887
PostPosted: Wed Apr 06, 2016 3:31 pm    Post subject: Re: Body number confirmation help Reply with quote
Cool, looks to be a legitimate 53 then! What are your guys' opinions. Is it worth the time and money making it correct if it's never gonna have the original pan?
57BLITZ
57BLITZ is offline
FWIW . . . the change in the "B" pillar occurred in 1965.
57BLITZ
57BLITZ is offline
PostPosted: Wed Apr 06, 2016 3:35 pm    Post subject: Re: Body number confirmation help Reply with quote
It will never be correct with the wrong pan.
TheLadyBug
PostPosted: Wed Apr 06, 2016 5:11 pm    Post subject: Re: Body number confirmation help Reply with quote
Yes; sorry I didn't realize it was so late!
Post pics so we can see.
Charmaine
TheLadyBug
PostPosted: Wed Apr 06, 2016 5:14 pm    Post subject: Re: Body number confirmation help Reply with quote
The early pans had a lot of differences; obvious is the heater control, other minuscule differences is where the cables exit the pan, how the e-brake cables operate, and even where the body bolts to the car are slightly different on early cars.
So as 57Blitz said, it will never be right unless you find an early oval pan.
Charmaine
57BLITZ
57BLITZ is offline
PostPosted: Wed Apr 06, 2016 6:25 pm    Post subject: Re: Body number confirmation help Reply with quote
"European" or "domestic market" Beetles had semaphores throughout the fifties.
This photo is from The Samba gallery (Looks like a 1960 . . . note the position of the door key slot!) . . .
scottf1887
PostPosted: Wed Apr 06, 2016 9:13 pm    Post subject: Re: Body number confirmation help Reply with quote
Is it possible that the car never had semaphores? I haven't stripped the paint on the pillar yet but I see no signs of semaphores
TheLadyBug
PostPosted: Wed Apr 06, 2016 10:29 pm    Post subject: Re: Body number confirmation help Reply with quote
A 53 would have always had them... I'm thinking your car may be pieced together. Are you sure you're reading the body number right? Im
guessing likely feb/57....
57blitz- I knew semaphore cars extended well into the 50's in Europe but for some reason i thought the pillar became thinner much sooner. My bad!
Charmaine
56Cabrio
56Cabrio is offline
PostPosted: Thu Apr 07, 2016 12:20 am    Post subject: Re: Body number confirmation help Reply with quote
The B pillers got thinner in 65 cause the Windows got bigger.
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
57BLITZ
57BLITZ is offline
PostPosted: Thu Apr 07, 2016 10:29 am    Post subject: Re: Body number confirmation help Reply with quote
If it is a '53, it came from the factory with semaphores.
As per my previous post . . . Please describe the front footwell heater outlets . . . I think ya have a 1957 like TheLadyBug said!
oldsplitvw
oldsplitvw is offline
PostPosted: Thu Apr 07, 2016 5:37 pm    Post subject: Re: Body number confirmation help Reply with quote
Hold up just as sec. Don't forget, that Volkswagen reset the body numbers to 0000 in July of 1955. Your body number would put it in the March 1957 range.
http://www.thesamba.com/vw/archives/info/bugchassisdating.php
While on the subject, Karmann convertibles had their own list of body numbers. Earlier cars had a 15- prefix, but this was dropped sometime in late oval production.
Basically, one number could correspond to 3 different cars. For example, Body# 37500 could be:
a 1948 sedan
a 1955 Sedan
or a 1957 convertible.
Will
jason
jason is offline
PostPosted: Sat Apr 09, 2016 9:19 pm    Post subject: Re: Body number confirmation help Reply with quote
Look for the door wedges on the pillars. It could have had the front clip replaced early in its life when earlier beetles were in the junkyards.
Izzygt500
Izzygt500 is offline
PostPosted: Mon Apr 11, 2016 11:43 am    Post subject: Re: Body number confirmation help Reply with quote
Like stated before, i think you have a 57. Any pictures?
