Justkysor Samba Member
Posted: Sat Apr 02, 2016 1:23 pm Post subject: Vanagon won't go into reverse (manual trans)?? |
aloha,
I am looking into a vanagon to purchase. the body is in good shape but the owner says the clutch plate is off and so it wont go into reverse, it is manual transmission. is this a real possability, or is the transmission shot? anything else i should invesitgate?
any info would be helpful.
thanks. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7161 Location: Honolulu,Hawaii and France
Posted: Sat Apr 02, 2016 1:46 pm Post subject: Re: vanagon wont go into reverse?? |
it can be so many things, specially the early aircooled transmissions.
I would check the shift linkage from front to back specially the condition of the inside of the box above the spare tire and the selector at the transmission, but the clutch it definitely not the reason: that's BS!
You're gonna drop big coin on this van down the line anyway, so start low  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sat Apr 02, 2016 2:46 pm Post subject: Re: vanagon wont go into reverse?? |
thanks for the reply, i dont mind wrenching on it as it would be a project. its good to know that its not the clutch, so if it is the shift linkage should i be looking at replacing these parts? i see some places offer kits to fix sloppy shifting. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10615 Location: Western WA
Posted: Sat Apr 02, 2016 3:43 pm Post subject: Re: vanagon wont go into reverse?? |
ALIKA T3 wrote: |
but the clutch it definitely not the reason: that's BS! |
If the clutch slave is blown it might be not go into reverse and just "buzzes". If that's the case the problem might be very simple (clutch slave & bleed). _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sat Apr 02, 2016 4:32 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
the seller did say that sometimes it will go right into reverse and other times it has trouble, when i was there looking at it the transmission would not go into reverse at all. |
Sodo Samba Member
Posted: Sat Apr 02, 2016 4:35 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
Engine running when trying to put in Reverse? Is the clutch OK when driving forward gears? Sorry ya never know what the sellers level of mechanical understanding is.
What you describe could br a normal linkage problem, maybe just adjustments, or maybe needs some linkage parts renewed. In general I'd bet its external linkage, solvable, and you can use it to get a lesser sale price. _________________
Posted: Sat Apr 02, 2016 5:33 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
thats what i like to hear and so i will keep my fingers crossed that all it would need is an adjustment. thank you for the responses. |
Posted: Sat Apr 02, 2016 11:20 pm Post subject: Re: vanagon wont go into reverse?? |
Sodo wrote: |
ALIKA T3 wrote: |
If the clutch slave is blown it might be not go into reverse and just "buzzes". If that's the case the problem might be very simple (clutch slave & bleed). |
Seller said clutch plate, not clutch slave cylinder, that's why I call BS
It's probably a long known problem, tricky seller. Most likely a linkage problem somewhere if it's a WBX transmission (091/1). It's hard to kill the reverse on these but anything is possible.
Too bad it's not on O'ahu man, I would have checked it out with you  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Wed Apr 13, 2016 3:14 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
Update.
I did end up purchasing the above mentioned vanagon. I havent had a chance to work on the shift linkage adjustment but on my drive home with it i noticed that not only does it not go into reverse but also will not go into 5th gear. This seems to go right along with all the things I have read about the linkage being out of adjustment.
i will get some pics up and let you all know how it goes in the next couple weeks.
thanks for all your replies. |
wyldryce Samba Member
Joined: August 14, 2011 Posts: 83 Location: Annapolis, MD
Posted: Wed Apr 13, 2016 4:22 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
Hmm, since most of the Vanagons don't have a 5th gear, this isn't terribly surprising
Does the van go into reverse with the engine off? What happens if you try to shift into reverse with the engine off and then start it? If it will, can you then get it out of reverse with the engine running? |
Posted: Thu Apr 14, 2016 12:54 am Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
At this point all I can say is the shift knob showes 5th on it. I played around with the linkage adjustment only to find I'm missing the spacer ring under the rubber guide the shift lever goes through. So I will be on the look out for a new spacer ring before I proceed. |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Thu Apr 14, 2016 1:38 am Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
The knob can be changed.
But if your 1st is down left it is a 5G.
I just had the same problem with bad working R.
After changivg the plastic parts on the shifter, it worked.
What you should try is to dismount the shift on the gearbox and try to shift into R direkt on the gearbox. If this works, the problem should not come from the gearbox. |
Thebeas Samba Member
Joined: February 27, 2015 Posts: 159 Location: Mississippi
Posted: Thu Apr 14, 2016 6:20 am Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
Since its not the original shift knob, is it possible the gears on the knob dont show where the gears really are?
I've owned cars where R is on the right side and down. Vanagons are to the left and up.
its possible right? I used to struggle the first week or so of getting mine to go into R, but someone pointed out you have to push down. felt like a dope... _________________ 1983 2WD 1.9 Digijet |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17127 Location: Brookeville, MD
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15344 Location: Syracuse, NY
Posted: Thu Apr 14, 2016 6:28 am Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
the shift rod coupling bushings up over the gas tank on air cooled models.
you have to drop the fuel tank to service them, they used to be NLA but I believe busdepot & Vanagain have that bushing again.
it's smart to refresh the fuel tank seals/hoses anyways.
you can just see the coupling by peering in the front pass wheel well over the fuel tank.. bright flashlight and someone to move the shifter to see how much slop is there. _________________
Abscate wrote: |
Posted: Thu Apr 14, 2016 10:47 am Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10364 Location: Orbiting San Diego
Posted: Thu Apr 14, 2016 12:17 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
That is not a vanagon shift knob. 5th is in the wrong place on that knob.
On Vanagons for reverse you must first push down toward the floor, then left and forward with the lever.
Mark |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12161 Location: Port Manteau
Posted: Thu Apr 14, 2016 1:01 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
That's a knob from a Mk2 Golf/Jetta _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
freddymac Samba Member
Posted: Sat Oct 22, 2022 10:59 pm Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
hello, when I push down then left and forward, it goes into first!!!! I can not get into reverse,,,, I have a Vanagon Westfilia 1981,,,, Please any help//// |
Posted: Sun Oct 23, 2022 1:23 am Post subject: Re: Vanagon won't go into reverse (manual trans)?? |
freddymac wrote: |
The adjustment procedure is given in the Bentley manual, which you must own if you intend to operate one of these vehicles. You also need to go through multiple old posts to see what others already have learned about the shifting system. Any excessive slop in the system if going to give problems, which typically means your significant other is going to be sitting in the drivers seat moving the stick around and operating the clutch while you lie underneath watching what is happening. |
