txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sun Oct 13, 2013 7:36 am Post subject: |
Yes, the merged header was a pleasant surprise.
The pipes that are connected to cylinders 2&4 had to be shortened about 1". The pipe that connects to cylinder 1 had to be cut 1-1/2", while the pipe connected to cylinder 3 was good. I had to drill out the flange holes two drill bit sizes larger to fit a 36hp head.
The flanges on cylinders 2&4 were perfect (orientation), but I did have to cut, rotate, and re weld the flanges on cylinders 1&3.
For me it was well worth it, 1-3/8" tube perfect for 36hp, small header flange, and now I have several muffler options available to me.
Raw header was $140, ceramic coating $140, so for $280 I have an exhaust system I'm really happy with, which is one of the downsides to 36hp engines (lack of exhaust choices or big $$$). |
txoval Samba Member
Posted: Sun Oct 13, 2013 9:46 am Post subject: |
Updated Pics
andy rowe Samba Member
Joined: June 04, 2004 Posts: 115 Location: plymouth uk
Posted: Sat Oct 19, 2013 5:24 am Post subject: |
that looks cool,i have a speedwell supercharger too that im going to fit to my 55 oval,im just going to stick with the 28pci carb and maybe a vintage speed exhaust,single tip version,good luck with your car dude. |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
txoval Samba Member
Posted: Tue Feb 17, 2015 5:36 pm Post subject: |
I removed the speedwell blower and went with just the 30pict1 carb. I had a hard time getting the carb and blower to work well together. I'm sure if I changed to a 28pci carb I would have had more success.
The engine just ran so well without the blower that I sold it. The car runs extremely well, revs fast, and is smooth. I honestly give the credit to fully balancing the crank assembly (crank, rods, flywheel, pressure plate, and pistons). Mr. Motorhead's cam and heads do not hurt either!
I did upgrade to an 019 distributor from Glenn Ring, which also helped. My next mod is getting rid of the merged header and moving to a vintage speed abarth system. The 1-3/8 merged header is too much and the single quiet pack looks like crap...doesnt match the design of the car.
I do not have any dyno numbers, but it is much improved over stock. I did not have my GPS but I easily got past 80mph on the speedometer this past weekend for a bit.
I'll upload a new picture shortly |
txoval Samba Member
Posted: Sat Jul 11, 2015 6:59 pm Post subject: |
I removed my merged header and single quiet pack. I'll probably put them for sale on here shortly.
The merged header was too much for my engine...if I would have increased the stroke/bore it would have been great.
I went with a Vintage Speed Abarth style muffler with j-tubes and the heat risers. The install kicked my butt because I was being hard headed, once I gave in, it went in easily.
I can't believe how much difference it makes, the engine runs much better and the sound is nice. Much better low end torque and throttle response.
Vintage Speed products are top notch, I'll post a pic soon. |
txoval Samba Member
Posted: Tue Apr 19, 2016 6:27 pm Post subject: Re: Engine Build - 54 |
Latest picture of the engine:
I'm in the process of swapping to Okrasa heads and running dual IDF's. Manifolds were supplied by Speedwell and the heads came from WW. Mr. Motorhead is doing the port/chamber work for me.
Distributor is a VJ4 BR8 from Glenn, big improvement over the 009
The engine runs great, but I have a habit of changing things! I could have built a 200hp engine for how much money I have in this little 36, but it has been fun. Once I start installing the heads/carbs I'll post some install pics |
sled Samba Member
Posted: Tue Apr 19, 2016 9:47 pm Post subject: Re: Engine Build - 54 |
you will love it with the dual port heads and IDF's.
36 or 40 idfs with small vents?
36 dells would have been awesome as well. nice with the additional progression port.
comp ratio? _________________ drive your split. |
txoval Samba Member
Posted: Wed Apr 20, 2016 4:30 am Post subject: Re: Engine Build - 54 |
The current setup compression is 7.5:1 static
I'm not sure what the final chamber volume will be on the Okrasa heads
40IDF's, small vents |
txoval Samba Member
Posted: Sat Jul 16, 2016 2:42 pm Post subject: Re: Engine Build - 54 |
I got my Okrasa heads from Matthew at AircooledResearch. They look great.
I also decided to move forward with a pair of Italian 36IDF's versus 40's.
I'll post some pics soon. |
Posted: Mon Jul 18, 2016 2:01 am Post subject: Re: Engine Build - 54 |
If I wasn't going to be collecting some ratio rockers at the weekend I'd be very jealous of your heads and carbs...... _________________ Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253 |
EVfun Samba Member
Posted: Tue Jul 19, 2016 9:41 pm Post subject: |
txoval wrote: |
I removed the speedwell blower and went with just the 30pict1 carb. I had a hard time getting the carb and blower to work well together. I'm sure if I changed to a 28pci carb I would have had more success. |
What jetting did you end up with for a 30 PICT carb? I was wondering about a 30 PIC carb as a possible mild upgrade. My engine is stock so your setup wouldn't be exactly right, but it should be close. _________________
Wildthings wrote: |
txoval Samba Member
Posted: Wed Jul 20, 2016 11:53 am Post subject: Re: Engine Build - 54 |
I have only played with the main jet, the rest are stock. I'm currently running a 122.5 main jet but it is rich. I have gone up to a 127.5 with the blower, but I need to step down to a 120.
I believe it comes stock with a 115 or 117.5, which is what I ran on my stock 36.
I went with the 30pict carb for ease of parts, cost (rebuilt 28PCI's are ridiculous), and I wanted an electric choke.
The original choke knob on my dash is used to power my electric fuel pump. Looks just like the original knob
Of course, in a couple of weeks I'll be pulling the heads and installing the Okrasa's and dual 36 IDFs |
EVfun Samba Member
Posted: Wed Jul 20, 2016 4:30 pm Post subject: Re: Engine Build - 54 |
Thanks for the info. I would have guessed richer. I take it your starting point was a stock 1967 type 30 PICT with the power enrichment circuit? I'm eyeing the aftermarket 30 PIC with a manual choke, thinking that there may be 1 or 2 horsepower to free up. _________________
Wildthings wrote: |
txoval Samba Member
Posted: Wed Jul 20, 2016 5:40 pm Post subject: Re: Engine Build - 54 |
Mine is an aftermarket version too, bought from www.aircooledresearch.com
It's a replica of the version used on 1500's
It's a Brazilian version, not Chinese. |
jz56oval Samba Member
Joined: September 03, 2007 Posts: 375 Location: bay area
Posted: Sat Dec 31, 2016 9:48 am Post subject: Re: Engine Build - 54 |
Is there any benefit to straight cut gears? Did they ever quiet down a bit? Do you have any photos of the vintage speed abarth exhaust installed?
Great car.
Thanks |
txoval Samba Member
Posted: Sat Dec 31, 2016 10:27 am Post subject: Re: Engine Build - 54 |
The general consensus is that straight cut gears are not needed until you run dual valve springs. However, the stock gears cause thrust wear and in my opinion, unnecessary friction. Straight cut gears remove this.
I cannot even hear mine...the noise I originally heard was from the blower. There is no disadvantage to running them.
Here is the best picture I have of the VS Abarth installed
Posted: Sat Dec 31, 2016 10:51 am Post subject: Re: Engine Build - 54 |
Very cool. Is that strato silver? |
txoval Samba Member
Posted: Sat Dec 31, 2016 10:55 am Post subject: Re: Engine Build - 54 |
Yes |
Posted: Sun Jan 01, 2017 5:36 pm Post subject: Re: Engine Build - 54 |
Strato silver is my favorite color amd was the original color of my 56.
I sent you a email with a question.
Thanks |
