splitjunkie Samba Member
Posted: Wed Apr 06, 2016 8:28 am Post subject: Re: JB Weld as a Fix on deck Lid |
Take the decklid to the sheet metal fabrication shop. Ask them if they have a resistance spot welder, which they should and ask them to spot weld the panel back down. Have them add a few extra for good measure. They will have to sand the paint off on both sides of the panels where the spot welds will be so you will need to paint those areas at the very least.
_________________ Chris
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Wed Apr 06, 2016 8:35 am Post subject: Re: JB Weld as a Fix on deck Lid |
Unfortunately in those torn areas a spot welder is not going to help. Will need to be filled in with stick or wire feed... _________________ In Stereo, Where Available! |
Posted: Wed Apr 06, 2016 12:06 pm Post subject: Re: JB Weld as a Fix on deck Lid |
You would spot weld in new areas of good metal around the old failed spot welds. It will create a lot less heat than MIG welding so repainting the entire deck lid or trying to match the color on an exposed portion would be unnecessary. _________________ Chris
Harris Samba Member
Posted: Wed Apr 06, 2016 12:10 pm Post subject: Re: JB Weld as a Fix on deck Lid |
Thanks Eric & Barb
Clay actually went over that just a few minutes ago. He was pointing out where the welds should be, but will let the guy doing it decide. We want it tight. Body shop has it until I'm called. He said the burn from the spot weld does not radiate much. He did find on the top outside a small paint crack which comes from the stress of the separation I guess. We still have matching single stage enamel from the last time if needed. I do as well in spray cans and one pint that we can use. Glad I found this
Noticed I has a bump about halfway down when lowering the lid. Assuming the separation widens and then releases causing the bump feeling.
Thanks for all the help. I'm quite old and need it. |
Harris Samba Member
Posted: Wed Apr 06, 2016 4:14 pm Post subject: Re: JB Weld as a Fix on deck Lid |
splitjunkie wrote: |
You would spot weld in new areas of good metal around the old failed spot welds. It will create a lot less heat than MIG welding so repainting the entire deck lid or trying to match the color on an exposed portion would be unnecessary. |
Thanks I 'm assuming they will take the best route. Body shop is 60 years old. Mr. Drurey ran it for years--7 children. Clay and Billy Drurey now operate it and have for several years. They are as detailed as their dad. They are a base coat clear coat business, but have some older old school guys that do single stage at it's best. The work they do is fantastic. One rule--- they call you when ready. You can go by and have coffee, but don't ask when? |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Wed Apr 06, 2016 6:12 pm Post subject: Re: JB Weld as a Fix on deck Lid |
Welded mine.
_________________ 1963 Ragtop Bug |
Harris Samba Member
Posted: Thu Apr 07, 2016 6:43 pm Post subject: Re: JB Weld as a Fix on deck Lid |
Early Report--Clay called this afternoon for the L-87 Single stage matching paint I have. The spot welding is done (remarks Eric & Barb please) and that area will be refinished as it was. The top lip of the engine lid with the blue tape (outside view) is as it was before--pristine.
bugheadred Samba Member
Posted: Thu Apr 07, 2016 9:22 pm Post subject: Re: JB Weld as a Fix on deck Lid |
I would have wielded it myself I only told you to use pop rivets because you didn't have to paint it and jb weld never would have worked |
62ItalianRagtop Samba Member
Posted: Fri Apr 08, 2016 12:13 am Post subject: Re: JB Weld as a Fix on deck Lid |
I also have to do this job on my 62 pearl white _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
Posted: Fri Apr 08, 2016 8:43 am Post subject: Re: JB Weld as a Fix on deck Lid |
Looks great. Actually that is not spot welding, but looks to be MIG (wire feed) welded up. Should hold up for a few more decades! _________________ In Stereo, Where Available! |
Posted: Fri Apr 08, 2016 8:52 am Post subject: Re: JB Weld as a Fix on deck Lid |
Harris wrote: |
The Resistance Spot welder would have produced spot welds that looked like they had been done at the factory since that is how they did them when they built them. It probably would have been cheaper for a sheet metal shop to do it too.
Also since you asked if you could fix it with JB weld I assumed that you were looking to do this on the cheap.
Using MIG to do spot welds is fine. I would grind them down better so they won't be visible once painted. _________________ Chris
Harris Samba Member
Posted: Fri Apr 08, 2016 11:22 am Post subject: Re: JB Weld as a Fix on deck Lid |
Harris wrote: |
Using MIG to do spot welds is fine. I would grind them down better so they won't be visible once painted. |
Actually looking for the less invasive route. Not afraid to spend what it takes, but did not want to mess things up and I may have on the welding. I'll know in a few days. The end result will tell me if I made a mistake on this. I like things clean and in some sort of original appearance.
Thanks Lou |
Harris Samba Member
Posted: Sat Apr 09, 2016 3:19 am Post subject: Re: JB Weld as a Fix on deck Lid |
Harris wrote: |
Yes, probably would have been the thing to do. I'm a little anxious about the final results here, but hopefully they perform their usual good results on the lid. Thanks for the suggestion. Lou |
58Blue Samba Member
Joined: June 30, 2010 Posts: 114 Location: Ontario, Canada
Posted: Sat Apr 09, 2016 8:17 am Post subject: Re: JB Weld as a Fix on deck Lid |
For a slightly different perspective, I put mine back together using 3M panel adhesive. It's been two years now, and it's still holding fine. There was no heat warping, no need for grinding, and I didn't even have to repaint. Granted, 3M adhesive is considerably more expensive than JB Weld, but I had a few other things I could use it for, so I got my money's worth out of the tube. |
Harris Samba Member
Posted: Sat Apr 09, 2016 6:29 pm Post subject: Re: JB Weld as a Fix on deck Lid |
58Blue wrote: |
Always something new out there. I do wish the JB would have worked. Clean with no mess, but likely not the thing to do. You would think with todays technology that something out there would work without the welding, the mess and the painting. Rivets are secure but are obvious. If you are wanting to make it look orig. Thanks for the suggestion. I have written it down. The jury is still out here. May find out Monday or Tuesday how we came out.
I want it right. I know what is there even it passes in a show with others. |
Harris Samba Member
Posted: Fri Apr 22, 2016 8:38 pm Post subject: Re: JB Weld as a Fix on deck Lid |
Picked up my engine lid today and am very pleased. They only painted the welded section area. Preparation before paint was well done. Will be glad to get it back on. Thanks for all your advice
Lou
glutamodo The Android
Joined: July 13, 2004 Posts: 26320 Location: Douglas, WY
Posted: Fri Apr 22, 2016 8:43 pm Post subject: Re: JB Weld as a Fix on deck Lid |
looks comparable to the fix I had on my 62's original decklid many years ago. _________________ Andy T.
