ghiafreek Samba Member
Joined: December 19, 2002 Posts: 937 Location: San Antonio, Tx
Posted: Sat May 07, 2016 10:05 am Post subject: 9 pin flasher relay problem |
Flasher works when touch casing with hand or screw driver to screw that holds it onto bracket. Once I let go blinkers turn off. It looks to be grounded fine to bracket and ground wire runs from "S" terminal to E flasher switch.
What do you think? |
grandpa pete Samba Member
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat May 07, 2016 2:58 pm Post subject: Re: 9 pin flasher relay problem |
BTW, the "-S" wire to the hazard switch provides no overall ground for the main flasher relay, it only "grounds" when you turn that switch on and that just activates the hazard portion of the relay. It's open normally. _________________ Andy T.
Posted: Sun May 08, 2016 8:51 am Post subject: Re: 9 pin flasher relay problem |
grandpa pete wrote: |
I think you ground isn't 100 %. There have been several cases where new paint ruins the ground . |
That's what I thought so I used a wire brush and made contact point on bracket nice and shiny and made sure contact area on box itself was nice and clean. No go. Any other way to ground. I though about putting ground wire between contact point of box and bracket and finding other ground. Would that work? |
