Top of dash and windshield out. Wiring Q&A
khalimadeath
khalimadeath is offline
PostPosted: Tue May 10, 2016 9:02 pm    Post subject: Top of dash and windshield out. Wiring Q&A Reply with quote
So I have some interesting wires, mostly everything works fine and no to much PO molestation. The windshield wipers dont do anything when I turn the knob however the grounds look ok and the connections look solid, maybe a fuse? Anyway I took some pictures and Ill do my best to explain them. Please point out any problems I dont mention.
What we are looking at
Fuses, there is a missing one, there is an aftermarket black wire that has been ripped off a spade connection coming of the no fuse connection.
These pics arent that great but this blue wire runs by the wiper area but doesnt go to anything, it points to the fuse its connected to.
Same questions about wires that are not connected but look like the should
The last one is my turn signal switch. I have a new one since the old one was hacked for some reason. The new wires have 2 black and white wires I can only assume they are both ground and can go to either ground? It appears there are 2 red and back wires that run off the old harness. Same concept?
I have looked at some wiring diagrams, they arent like any I have seen before, in that past I have prided myself at being pretty decent at wiring. This is a bit intimidating since it seems vw just threw the wires in there and hoped for the best.
busdaddy
busdaddy is offline
PostPosted: Tue May 10, 2016 9:11 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Seems like your best option is to list the colors of the wires coming from a paticular component so we can tell you where they go. for example where does that shiny black encased harness originate? (I'm guesing ignition switch?). Deal with one issue at a time to keep it simple.
Слава Україні!
khalimadeath
PostPosted: Wed May 11, 2016 8:56 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Yea thats the turn signal switch, I think I pretty much have that one handled, my only question is that there are 2 black and white wires, both of which I can assume are grounds. I am more worried about why my wipers aren't working. I think it may have something to do with a missing fuse and wires from there.
kreemoweet
kreemoweet is offline
PostPosted: Wed May 11, 2016 9:35 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Why would you assume your black/white wires are grounds? VW NEVER used black or white or black&white wires for a ground connection.
'67 bug: seized by the authorities
busdaddy
busdaddy is offline
PostPosted: Wed May 11, 2016 9:47 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Exactly what year and model of bus are we discussing here?
Слава Україні!
Tcash
Tcash is offline
PostPosted: Wed May 11, 2016 10:24 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
With a 411 937 505 A fuse box. Guessing you are working on a 1970 bus.
Wiring diagrams
http://www.thesamba.com/vw/archives/info/wiringt2.php
1970 Wiring diagram. Click on pic to enlarge.
#7 missing fuse with the burnt black wire is the accessory fuse. Who knows what the PO had it hooked up to.
http://www.thesamba.com/vw/archives/info/wiring/70busfuses.jpg
The only solid blue wire I see, unless added by po. Goes to K2 (gen light) on the fuel gauge cluster. Does your gen light work?
As painful as it is. You are going to need to follow the wires and see what they are connected to.
Installing aftermarket turn signal switch
Good luck
Tcash
khalimadeath
PostPosted: Wed May 11, 2016 1:16 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
1970 (westfalia)
khalimadeath
PostPosted: Wed May 11, 2016 1:19 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Tcash- Good to know of that I suppose ill use that for a stereo since I do not have one.
what is the Gen light?
I bought the switch complete and just have the wires coming out, the end of the harness.. I also still have the OG harness still plugged in. I was hoping to just match wires and replace them accordingly. I hope its that simple.
khalimadeath
PostPosted: Thu May 12, 2016 9:08 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Well I got my wipers figured out for the most part, according to rat well
http://www.ratwell.com/technical/Fuses.html#70
I need a 16A fuse in the place where there is no fuse.
Upon further examination I am starting to make sense of the diagrams. Ill repost back after some fiddling with wires. Im pretty sure I have the turn signal and wiper hammered out.
khalimadeath
PostPosted: Thu May 19, 2016 3:31 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Ok so stereo is all wried up and working.
I fixed a lot of ground that were not connected. Ive sorted through the wires and ensured that they are running to the proper placed from the proper fuses.
The problems I am still having are:
-Wiper motor does not work still. Although I am thinking this is part of the reason why...
These wires seem to be just shoved in there. Also when the key is on the motor gets warm to the touch. I am thing the motor may be bad or the grounds are bad.
-The Dash lights stopped working. I tried to replace them with LED's they didnt work, my other bulbs blew. Ill see if new bulbs fix it. The test light reads power to them when headlights are switched on.
-The turn signal switch is wired up properly and the blinkers work when they want to. The relay sounds like its having a seizure. The brights click on and off fine. Hazards work most of the time. Thoughts?
SGKent Premium Member
SGKent is offline
PostPosted: Thu May 19, 2016 3:44 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
It is good to see you are not in a hurry. Chasing down PO wiring hacks is a pains but as you eliminate circuits and get them right the job is like a jogsaw puzzle - the fewer the pieces left, the quicker it goes.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
khalimadeath
PostPosted: Thu May 19, 2016 3:56 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
indeed, the wiring wasnt in too bad of shape. Some of what i thought were "hacks" were for the stereo that was once in there, so I didnt have to re run a constant 12v with an in line fuse since there was aready one in there. However I like to properly solder all my connections if possible.
busdaddy
busdaddy is offline
PostPosted: Thu May 19, 2016 4:03 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Ever considered the linkage may be siezed?
Those wires look like the park circuit, you may be looking for a replacement if you can't find where they should go.
Слава Україні!
khalimadeath
PostPosted: Thu May 19, 2016 6:21 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
I suppose I could check the linkage, it looks like there is still grease in there. No rust or anything..
What is the Park circuit? I searched for pictures of this motor wired up correctly but I couldent find any good ones. I find it hard to believe these ground wires are supposed to be shoved in there like that.
khalimadeath
PostPosted: Thu May 19, 2016 8:47 pm    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Wiper problem solved!! ....... Its broken Sad
Anyone have a working one for sale or know where I can get a new or refurbished one for a decent price? I was thinking of the Bus Depot one.
Tcash
Tcash is offline
PostPosted: Fri May 20, 2016 7:08 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
What Bus Depot one?
khalimadeath
PostPosted: Fri May 20, 2016 8:17 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
Tcash wrote:
What Bus Depot one?
This one
http://www.busdepot.com/j11784
or this one
http://www.busdepot.com/211955113h
Jbugs ships fast to me so most likely this one
http://www.jbugs.com/product/211955113H.html?Category_Code=vw-bus-windshield-wipers-1968-1972
khalimadeath
PostPosted: Fri May 20, 2016 11:27 am    Post subject: Re: Top of dash and windshield out. Wiring Q&A Reply with quote
I ended up purchasing a NOS wiper motor in the classifieds. Ill post pics of that installed and hopefully solve my wiper motor issue once and for all.
Im glad it was broken, it encouraged me to rummage through the wires and in turn, I found some things out of place and learned some more about my VW.
