khalimadeath Samba Member
Posted: Wed May 11, 2016 9:36 pm Post subject: Re: Insulation / sound deadening thread |
Okay, so I am done re installing my interior after adding reckhorn deadening and refectix. It added to the overall thickness of the floor ect so it changed some of the dynamics of the westfalia interior, I had to drill a few holes and the Z bed fit is not as exact as it was without anything on the floor. So keep that in mind when you install it. It may be better to only install it in the ares where no interior pieces would touch.
AircooledHome Samba Member
Joined: October 13, 2015 Posts: 273 Location: California
Posted: Thu May 12, 2016 12:16 am Post subject: Re: Insulation / sound deadening thread |
Sweet flooring. Did you use a subfloor for this? |
Posted: Thu May 12, 2016 12:21 am Post subject: Re: Insulation / sound deadening thread |
Today I installed Foil Backed Butyl to my cargo area, wheel wells and rear cargo area. I was on a budget but wanted to get my flooring in so I can start working on my cabinetry, and wanted to do sound deadening before I put the flooring in.. So I bought generic brand "Noico" from amazon. $60 for 50 sq/ft plus 48 hr shipping and I couldn't go wrong. 1 pack of 50 sq/ft covered the whole area I just mentioned perfectly. I will buy more to do the front, and every door and panel in the near future. I drove the bus around after installing and didn't notice a noise reduction, but I didn't drive it on the freeway and I also had nothing else in my bus.. Will report back once the floors and cabinet are in.
I had POR15'ed the area prior.
http://www.amazon.com/Noico-Self-adhesive-Automoti...k129040-20 |
Posted: Thu May 12, 2016 8:43 am Post subject: Re: Insulation / sound deadening thread |
[quote="ThisMetalMess"][quote="khalimadeath"]
[img]https://www.thesamba.com/vw/gallery/pix/1499578.jpg
[img]https://www.thesamba.com/vw/gallery/pix/1503221.jpg
No, I just laid the boards down on the sound deadening. I used some thin birch in a few areas where there was a slight elevation change in the floor to make it more gradual. The flooring I used was some German made stuff that is pretty sturdy and sold in 6 foot planks. |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Thu May 12, 2016 12:21 pm Post subject: Re: Insulation / sound deadening thread |
I've put sound deadening on all the walls, doors, cab roof, nose, and front & rear wheel wells, and it's done a lot for sound quality and making it easier to talk, but I still have a lot more wind noise than I'm happy about. All that is left is the floor and engine area.
Has anyone found a big source of wind noise on the highway? I don't want to throw more money and unnecessary weight into the bus. I have new (quality) seals all around as well. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Big Papi Samba Member
Posted: Thu May 12, 2016 4:49 pm Post subject: Re: Insulation / sound deadening thread |
I found the outside link and advice that Scott from German Supply gave on sound dampening to be enlightening. The butyl product dampens vibration through the metal. Covering 25% of your surface area is apparently enough to accomplish that. I don't believe these products do much for acoustic waves propagating through materials. The heavier MLV absorbs these frequencies. I doubt you can get much noise reduction without both.
As far as the wind sound mentioned above, I imagine this is due to the aerodynamics of the bus. No way around that. Too much exposed glass to block it out.
I'm currently installing a Stinger Roadkill butyl product. Pretty nice stuff. No smell. Easy to install. Going to throw a blanket of the MLV on after. I'm imagining it will be like driving in a new mercedes after that _________________ 1978 ASI Riviera
TypeIV FI |
Posted: Mon May 16, 2016 9:52 am Post subject: Re: Insulation / sound deadening thread |
Just finished up adding some Stinger Roadkill butyl above the engine compartment and below the back seat. Seemed very nice. no odor. easy to apply.
Installed some insulation wrapped in plastic to the compartment lid.
Added some Mass Load Vinyl (MLV) (no VOCs) from home depot on top of the butyl.
TypeIV FI |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Mon May 16, 2016 10:13 am Post subject: Re: Insulation / sound deadening thread |
If I wanted to have a clean and stock look is the any reason why I couldn't put mlv inside the cushions underneath the foam?
What have peoples experience been with the mlv in terms of effectiveness? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Mon May 16, 2016 10:32 am Post subject: Re: Insulation / sound deadening thread |
the best way to find wind noise are something these and a buddy. The guy outside uses air from a compressor to blow against the car. One may find just a small tiny screw hole causing 99% of the problem.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon May 16, 2016 10:41 am Post subject: Re: Insulation / sound deadening thread |
SGKent wrote: |
That's a great idea! Thanks SGKent _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Pinetops Samba Member
Posted: Mon May 16, 2016 11:20 am Post subject: Re: The great insulation/ sound deadening thread... |
Big Papi wrote: |
Pinetops wrote: |
Reckhorn ABX
Reflectix velcro'd on
Home Depot Acoustical barrier (mass loaded vinyl)
How did you affix the MLV on to the other substrate materials? I have read that adhesives are not recommended because they can reactive with the MLV. |
It stays in place on its own. The bed/seat and those metal tabs that the bed sits on hold it in place. A heavy duty velcro would probably work where needed though. _________________ "A rolling bus gathers no rust."
Posted: Mon May 16, 2016 11:26 am Post subject: Re: Insulation / sound deadening thread |
Peel n Seal works but it contains asphalt and I wouldn't recommend it on the inside of your bus/vehicle. Above the tank is probably fine. There are affordable, butyl based alternatives to dynamat. _________________ "A rolling bus gathers no rust." |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Jun 08, 2016 10:46 am Post subject: Re: Insulation / sound deadening thread |
how many sqft would I need to cover the cargo floor, engine compartment (inside of bus side), wheel wells, front floor, doors, and sidewalls?
PS. 1970 transporter no interior currently. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Wed Jun 08, 2016 6:30 pm Post subject: Re: Insulation / sound deadening thread |
Spike0180 wrote: |
PS. 1970 transporter no interior currently. |
The best way to know for your specific application.
_________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Wed Jun 08, 2016 6:37 pm Post subject: Re: Insulation / sound deadening thread |
If you want to use the same product I used, a helpful guide with regard to quantity can be found here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=373683&start=0 _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
curtp07 Samba Member
Posted: Wed Jun 08, 2016 6:39 pm Post subject: Re: Insulation / sound deadening thread |
To each his own of course, but I m not sure where the trend to cover every square inch of panel came from. In my experience it doesn't work, and in the end just leaves a mess...I believe to deaden sound on a panel you don't have to coat everything, just a select piece. And the floors? Waste. Nothing some jute and a carpet won't fix.
I wish I didn't do my beetle..there was no noticeable improvement and now it looks worn and terrible... _________________ Subaru |
Posted: Wed Jun 08, 2016 7:26 pm Post subject: Re: Insulation / sound deadening thread |
Most of the deadening done by the dynamat type products is accomplished by piece covering just 25% of the panel. Covering the whole panel will give you marginally more sound deadening. Layering it with mass loaded vinyl and a middle barrier layer is how professionals do it. _________________ "A rolling bus gathers no rust." |
wcfvw69 Samba Purist
Posted: Wed Jun 08, 2016 8:19 pm Post subject: Re: Insulation / sound deadening thread |
I installed some Fat Mat, rattle trap 80mil in my fuel tank compartment and the ceiling of the engine bay. My 70 bus w/stock engine and muffler was much louder than I cared for though the original tar boards were missing from the main section of the roof.
Overall, I'd say I was rewarded w/a 20% reduction in engine noise in the cab at both city and highway speeds. The remaining noise level is very tolerable and what I'm accustomed to w/my bugs.
What have folks used in place of the tar boards above the engine, on the ceiling in these early bays? Ideally, I'd like to find something to put up there that would be the same thickness as the tar boards so I can use the clips (and spray adhesive) and make it look stock. I certainly wouldn't mind it being a sound absorber either. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jun 08, 2016 8:36 pm Post subject: Re: Insulation / sound deadening thread |
thank you, i missed it the first time and the second time that you mentioned the amount of stuff you purchased for the job. This is just what I needed. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
WissBrauSean Samba Member
Posted: Fri Apr 07, 2017 10:47 am Post subject: Re: Insulation / sound deadening thread FAQ |
Has anyone successfully insulated their camper pop top with anything that looks nice? _________________ 1979 Westy Automatic 2000cc Fuel Injected |
