Convoy Samba Member
Joined: March 17, 2011 Posts: 312 Location: San Clemente
Posted: Thu Feb 26, 2015 12:51 pm Post subject: Mud Flaps FAQ |
To link to this thread
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=620279&start=0&postdays=0&postorder=asc&highlight=]Mud Flaps FAQ[/url] |
Bus Mud flaps are on sale from CIP1. Are these the VW logo ones you have to adhere the letter "V" on after you get them? Anyone bought these from CIP1, quality? Looking to put them on my 74.
VWC-211-821-805-BBK MUD FLAPS (PAIR) W/ HARDWARE ONLY - BLACK W/ WHITE LOGO - BUS 50-72 for $39.99
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D821%2D805%2DBBK |
Brian Samba Moderator
Posted: Thu Feb 26, 2015 5:15 pm Post subject: |
They probably say VW but they can't advertise them.
I went down to pep boys and got some generic flaps for $20. A lot longer than the stock style ones. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
dillon70 Samba Member
Joined: October 20, 2008 Posts: 234 Location: Ventura, Ca.
Posted: Thu Feb 26, 2015 6:45 pm Post subject: |
They said they only have the EMPI logo or the year versions. No one is allowed to have the VW brand any longer. Found a set on Samba a month or so ago, but had to make my own brackets. I used stainless hinges. I don't think the flaps are OG because they have plastic logo, but not sure, but the logo is one piece.
Good luck in your search. If you find a set with the VW logo, don't think, buy!!
_________________ 2001 ZO6 (450+hp)
1985 930 Turbo (400+hp)
1970 Z28 (360+hp)
1979 911 (235 hp)
1970 Chimney Pop Top (120 hp) SRFBUS1
1990 Vanagon (95 hp)
1985 Vanagon GL (85 hp)
1969 Tin Top 1 owner OG
Can I get any slower?
2015 CC R-Line (heavily mod'd) |
kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Fri Mar 11, 2016 6:12 am Post subject: Re: Mud Flaps |
Any options pop up lately (Spring 2016) in regards to VW logo mud flaps?
Ebay seller in Turkey has them for >$50/pair without hardware. I like the logo, but over $100 for a set is a tough pill. _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Fri Mar 11, 2016 9:27 am Post subject: Re: Mud Flaps |
I have a pair of unused (still in their original packaging ), GENUINE VW accessory, textile-reinforced, black-rubber, rear mud-flaps, with the Wolfsburg emblem, which are surplus to my needs.
These illustrated in the following topic thread, appear to be similar or possibly identical.
http://www.thesamba.com/vw/forum/viewtopic.php?t=102329 _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Tcash Samba Member
Tcash Samba Member
Posted: Thu May 12, 2016 11:40 am Post subject: NOS T2a WEGU Mud flaps Mudflaps 1968 |
classiccult
Posted: Fri May 13, 2016 8:19 am Post subject: Re: Mud Flaps |
The VW Type 2 rear mud-flaps which have been fitted to my 1973 VW Type 2, since the early-1980s, have completely flat, smooth backs, with no vertical ribbing. I had to fabricate my own full-width, one-piece attachment brackets (bolt onto the bottom of the wheel-arch mud guards and the VW 1600 Type 2 engine's chassis-attachment brackets), from off-cuts of duralumin, because none were supplied with the mud-flaps or listed in the VOTEX accessories brochure.
Note the Swedish red squirrel undertaking a road-worthiness inspection of our Michelin XZX 185 SR14 Reinforced radial tyre and mud-flap. The wheel is hand-painted with Finnigan's silver-grey "hammered-pewter-finish" Hammerite paint
https://en.wikipedia.org/wiki/Hammerite
http://www.hammerite.co.uk/products/index.jsp#multi-purpose _________________ Regards.
Nigel A. Skeet
Posted: Sat Jul 02, 2016 8:24 am Post subject: Re: Mud Flaps |
Here are my spare 1968 onward, VW Type 1 Beetle mud-flaps, which as I write, are winging their way across the oceans, to Port Macquarie, New South Wales, Australia, where they will adorn a recently restored 1971 VW 1600 Type 2 Microbus L.
Nigel A. Skeet
obieoberstar Samba Member
Posted: Fri Dec 02, 2016 9:31 pm Post subject: Re: Mud Flaps |
A couple of years ago I purchased some gowesty front mud flaps. They worked and looked great. Mounted on the backside of the front jack points. Even made a small cut-out to be used with the side step.
So, I purchased a set of the rear flaps from them. The General Grabbers like to capture and release rocks at will.
The rear flaps are basically the same as the front. When mounted they would follow the curve of the rear inner fender liner and therefore be at a 45 degree angle and not perpendicular to the road.
Had to bend the metal brackets slightly to get them to hang straight down.
Work and look good. But I might make the rubber a bit longer. The local O'Reilly Auto Parts has semi truck mud flaps of various thickness in stock. Just have to trim it to what I want. One flap can easily do 2 for the bus.
Just a heads up. |
Tcash Samba Member
Posted: Sat Sep 02, 2017 7:53 am Post subject: Re: Mud Flaps FAQ |
Wegu Mud flaps for T2a 68-71
busdaddy wrote: |
Here's some OG mudflaps,
This bus is a 71 so the mount would be 68-71
This is a 72-79 (apologies for the focus but I'm not crawling under again)
And here's a 68-79 front (no they didn't come with robertson screws from the factory)
Sorry about the filth, the roads haven't been too nice lately |
MonkeySee wrote: |
Here's the 68-71 Bay mud flaps I just picked up. Funny thing is I didn't even know what they were for when I got them. I was just going to adapt them to what I have. Little did I know they were the exact factory piece for my both of my Bays.
Thx to mayor ratwell
Mudflaps (Schmutzfaenger)
http://www.ratwell.com/technical/Mudflaps.html
topaz. wrote: |
To link to this post
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=3622345#3622345]Mud Flaps Mounting T2b[/url] |
Hello to all.
This is how we mounted ours.
At first we had to collect everything to do the job right.
Then tightened the brackets and the flaps.
Next step we took the wheels off and marked to drill the holes.
Since we are still runing 1584cc we had to switch the brackets from left to right to work well, until we start runing a type IV engine.
Then tightened the bolts,however not enough so we could balance the flaps horizontally.
At last, after the balancing procedure we tightened the flaps and the brackets.
veskovici Samba Member
Joined: September 11, 2006 Posts: 359 Location: Belgrade
Posted: Wed Feb 14, 2018 3:29 am Post subject: Re: NOS T2a WEGU Mud flaps Mudflaps 1968 |
I have the same front mud flaps,puzzled how to hang them. pic from brochure is unrealistic so any pictures if any hanged front ones would be appreciated _________________ Oval 1954
Barndoor1954
Doubledoorsunroof |
