Radius Rod connection on sub frame
Page: Previous  1, 2
SCM
SCM is offline
PostPosted: Sun May 15, 2016 5:44 pm    Post subject: Re: Radius Rod connection on sub frame Reply with quote
I just took on this job and it all went really well until I ran into this.
Being a Rocky Mtn van that isn't driven in winter, it was easy enough to budge my late model radius rods with the help of leverage (standing on the wrench on the passenger side, using a floor jack to lift it on the driver side).
All went well on the passenger side but the driver's side radius bushing was worn through to the point where the rod was gouged and galled from wearing on the chassis. If I would have just used the same lower nut, without trying to take it off the rod, I would have been fine but I wanted to use the new hardware. Trying to do that messed up the rod's thread enough (this picture doesn't show it) that I decided to buy a new radius rod.
I told my wife that I saved our lives by removing a severely word radius rod - yep, I'm a hero.
So, if you're doing this job, maybe inspect your threads where they go through the chassis, and if they're messed up maybe consider keeping that old lower nut instead of removing it and replacing. Or, you can spend $100 for a new rod and hardware.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
Vanagon Nut
Vanagon Nut is online now
PostPosted: Sun May 15, 2016 6:01 pm    Post subject: Re: Radius Rod connection on sub frame Reply with quote
That's exactly what my radius rod sleeve, rod looked like. Wore into the hole at chassis.
I've read that when using a mig to patch holes, one could use copper as backing; the fill won't adhere to the copper.
Given marks comments, in hindsight, I would've just back filled the damaged hole so metal at repaired hole retains the OEM thickness.
Or, use really thin metal to patch area and backfill.
Neil.
1981 Westy air cooled to 15 ABA swap: http://tinyurl.com/y9n4xob8
50 ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
foodeater
foodeater is offline
PostPosted: Sun May 15, 2016 7:54 pm    Post subject: Re: Radius Rod connection on sub frame Reply with quote
Neil.
Yup, copper works great as a backer that MIG wire won't stick to, when welding steel. You can buy copper spoons or paddles for doing this in hard to reach places.
89 Bluestar-2.5 Subaru Powered
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
IdahoDoug
IdahoDoug is offline
PostPosted: Sun May 15, 2016 11:24 pm    Post subject: Re: Radius Rod connection on sub frame Reply with quote
I found a thick walled pipe with the correct outer diameter, and a too-small inner diameter. Had it drilled to the precise inner size and cut to lengths to replace my bad ones. Worked fine.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
SCM
SCM is offline
PostPosted: Mon May 16, 2016 7:22 am    Post subject: Re: Radius Rod connection on sub frame Reply with quote
Thanks for the tip Doug. I have new metal tubes on hand. They came with the Powerflex kit that T3 sells. I'm just glad I caught this before the sub-frame holes became damaged.
I'm bummed out that I couldn't get my hole project finished this weekend but once the new rod shows up it should go fast.
Retsgard
Retsgard is offline
PostPosted: Mon Aug 29, 2016 8:33 am    Post subject: Reply with quote
thummmper wrote:
has anyone gotten the oe diameter of that hole?
Anybody? Smile
Page: Previous  1, 2
Page 2 of 2
