AndyBees Samba Member
Joined: January 31, 2008 Posts: 2327 Location: Southeast Kentucky
Posted: Thu May 26, 2016 4:56 pm Post subject: Stock Vanagon Clutch Disc in a TDI conversion |
This topic may have already been discussed to the Moon and back, but I never found anything ....
So, I recently pulled my transmission to install a Pilot Shaft that has larger splines to accept the TDI Clutch Disc (228mm).
Yesterday, I just happened to take a close look at the new TDI clutch disc and was comparing it to the Sachs OE style 228mm Clutch that I removed with about 50k miles on it.
The following photos reflect what I found... (look for the cracks in the metal)
I believe the TDI engine and no doubt Subies, 1.8Ts, etc., may be more than the OE style Vanagon Clutch can stand. Or, was this just a freak thingy that occurred?
My engine has a Stage 1 Tune which bumps the HP from 90 to about 110-115. I'm not sure about the torque increase.
Almost two years ago, I did pull my PopUp Camper on a long road trip to Alaska and return... I doubt the damage would have hung together for 30k more miles... _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
Zeitgeist 13 Samba Member
Posted: Thu May 26, 2016 5:28 pm Post subject: Re: Stock Vanagon Clutch Disc in a TDI conversion |
I suspect your trailer towing was the primary culprit _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 440 Location: Bangalore India
Posted: Thu May 26, 2016 6:54 pm Post subject: Re: Stock Vanagon Clutch Disc in a TDI conversion |
Thanks for the input. It's an eye opener.
I have already acquired TDI shaft & have Donor's low run TDI clutch plate.
This Info will hurry up my work.
Higher HP, change in Gear ratio & pulling trailer on uphill, downhill should be the cause.
5 speed in your next project? |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Fri May 27, 2016 1:16 am Post subject: Re: Stock Vanagon Clutch Disc in a TDI conversion |
Nice info.
But i think this happens very rare.
i was driving the wbx disc on a mashined fly wheel on my AAZ for long time.
2 weeks ago i changed it finaly to a original TDI fly wheel and cluch with shaft, because of the anoying rattling in the gearbox with the light fly wheel.
I have mashined the tdi fly wheel only a bit for the original starterand 4 stripes for the oilpan screws. Balanced afterwards.
Using this plates
https://www.tk-carparts.de/article/4040/Trennblech_2_teilig.html
No more rattling in the gearbox on idle, and the engine runs smoother.
After doing 2,500km the last 2 weeks i notice also a better mpg. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17112 Location: Retired South Florida
Posted: Fri May 27, 2016 10:24 am Post subject: Re: Stock Vanagon Clutch Disc in a TDI conversion |
Andy, I should be pulling my clutch out over the next few weeks. I am also running the stock diesel clutch. I'll look for the cracks and let you know. mark _________________ ☮️ |
Posted: Fri May 27, 2016 12:37 pm Post subject: Re: Stock Vanagon Clutch Disc in a TDI conversion |
You know, there's little doubt that the PopUp Camper trailer did stress the clutch plate. But, that was almost two years ago and a bit over 30k miles later.
Like many of us, there's been a few times I thought the tranny was in neutral and let the clutch out or dumped the clutch due to my foot slipping off the pedal. It would seem a few of those incidents would take a toll on the plate as well.
Of course, I do drive it almost like I stole it...
Today, I finally got the last welding done on the exhaust system, including the hangers. I'm almost ready to give it the final hang. I also have the two carrier bars with OE diesel engine rubber mounts ready to install. While all that stuff is out, I'm doing a few mods to the AC line connections, PS hose, and few things dealing with the electrical circuits in that area. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
