Anyone have 85 TinTop AC with Subaru ?
guzyk
guzyk is offline
PostPosted: Fri May 30, 2014 5:37 am    Post subject: Anyone have 85 TinTop AC with Subaru ? Reply with quote
I'm helping someone install a Vanaru 2.5 into an 85 tin-top. They have this funky center AC system:
Bentley doesn't mention this system. Was this 1985 AC aftermarket or a dealer installed system? (the way things are installed it looks dealer installed) and more importantly has anyone revived one of these systems? If so, can you share some tips? (this one hasn't worked for many many years)
Jake de Villiers
Jake de Villiers is offline
PostPosted: Fri May 30, 2014 7:33 am    Post subject: Re: Anyone have 85 TinTop AC with Subaru ? Reply with quote
Hi, Paul. My '84 GL has that dealer-installed A/C. It puts a lot of cold air right where you want it.
It worked well but I didn't like how much power the compressor robbed from the engine, so didn't use it much. Obviously, with a 2.5 that won't be an issue!
'84 Vanagon GL 1.9 WBX
www.crescentbeachguitar.com
www.thebassspa.com
Howesight
Howesight is offline
PostPosted: Fri May 30, 2014 4:11 pm    Post subject: Reply with quote
Hi Guzyk:
I can't say that I have revived one of those funky systems, but the steps are always the same:
1. Check, with a proper gauge set, whether there is any refrigerant pressure in the system at all. If so, you are in luck because this means there is likely little to no contamination in the system since it was not open to the elements.
2. Remove all the refrigerant hoses and have them rebuilt with new barrier hose, using as much as possible, the existing VW fittings. Flush the components which you intend to reuse (evaporator and condenser). Use new O-rings everywhere. Note that the original hoses develop cracks and leaks from the inside out. External visual inspection will not reveal the hose condition. No 30-year-old hose will be useable and replacement is a must. You can save money by ordering bulk hose and crimping fittings yourself.
3. Remove and drain the compressor. Measure the amount that comes out and note the measurement. Check whether it was ever "converted" to R134A refrigerant. If not, then it contains mineral oil. Run clean mineral oil through it, turn the shaft and drain several times. This is done to clean it out. You cannot run solvents through the compressor, so this is the tedious method.
4. Alternatively, buy a new compressor from Nostalgic AC Parts:
http://nostalgicac.com/compressors.html
5. Clean the fins of the evaporator and the evaporator fans.
6. Check that evaporator enclosure drains are clear and repair as needed.
7. Replace the expansion valve on the evaporator. Nostalgic has them. You don't have to use a VW-spec unit - - the generic ones Nostalgic sells will work.
8. Replace the receiver-drier with new - - again, this is s generic item.
9. Use RedTek refrigerant. If you use R134A, the performance of your system will be poor UNLESS you install a modern parallel-flow condenser. Nostalgic sells those too, and for less than the VW factory (low performance) condenser. Here's the 16" x 22" unit I recommend:
http://nostalgicac.com/16-x-22-superflow-r-134a-condenser.html
10. Even with a new condenser, I still recommend using Red Tek refrigerant. Since your whole system will be like new, do not use any "leak stop" products as they are not needed.
'86 Syncro Westy SVX
guzyk
guzyk is offline
PostPosted: Sun Jun 01, 2014 7:14 pm    Post subject: thanks howesight Reply with quote
Thanks for all your great advice Howesight. The hoses/lines were unhooked and full of crud so no doubt I'll get all new ones made front to back that will mate with Subie compressor.
Subaru compressor will be late model, (engine is 2011) I think for around $100 new condenser makes sense, ditto on receiver/dryer and expansion valve.
I'm just dreading the plastics in the ceiling, hopefully they don't disintegrate when I open up the evaportator. I guess I'll have to check the blower in the ceiling also and make sure it works then figure out how to flush the evaporator. At that point I'll have close to a new system.
Didn't know about RedTek but it sounds more suitable for Vanagon than R134A.
guzyk
guzyk is offline
PostPosted: Sun Jun 01, 2014 7:19 pm    Post subject: Install guide for early AC? Reply with quote
Has anyone come across the installation manual for this early Vanagon "dealer installed" AC system? If so, a scan/link would be wonderful.
Jake de Villiers
PostPosted: Sun Jun 01, 2014 9:46 pm    Post subject: Re: Install guide for early AC? Reply with quote
I take it back - I used to have a copy but I can't find it on my hard drive... I had a crash a few months ago and a few things appear to have gone missing.
I do have the Behr In-dash A/C Manual.
www.thebassspa.com
guzyk
guzyk is offline
PostPosted: Thu Jun 19, 2014 3:45 pm    Post subject: Source for expansion valve ? Reply with quote
Where's the best place to buy a new one of these A/C expansion valves for the "dealer installed" 85 ceiling a/c unit?
I want decent quality, I know there's $10 Chinese ones out there, but I don't want to replace it again anytime soon....it's a PITA to get to.
Would this be a good kit to buy?
http://nostalgicac.com/driers-valves/expansion-valves/oring-expansion-valve-replacement-kit.html
TequilaSunSet
TequilaSunSet is offline
PostPosted: Thu Jun 19, 2014 4:25 pm    Post subject: Reply with quote
I have one in my 85 too with a 1.8T, but I'm not much help in regard to helping you get it going. I can say it's not great by a long shot, but on hot days it is far better than not having it.
"Krusty" Satin White - 85 AUTO w/ 3.27 R&P Vanagon HIGH Top w/ Westy Camper bits, 1.8t Very Happy
2014 Lancer AWC
2007 Tango (Home) Living small
Don't harsh my mellow...
geodude
geodude is offline
PostPosted: Thu Jun 19, 2014 4:36 pm    Post subject: Reply with quote
I have one of those systems that I pulled from a wreck. R134 filled when I pulled it and all the hoses had been replaced with newer hose and even had a new compressor. But I never used it. I recall that it wasn't too hard to pull all the hoses and such, just took a couple hours. Might be worth pulling the hoses and have a shop make new ones. I believe there were two really long hoses and one or two shorter ones. The pile of parts are in storage so can't take a quick look. The parts are pretty generic and not particularly Vanagon specific. The expansion valve is available and cheap. http://www.discountacparts.com/addtocart~year~1985...-01538.asp
1990 Vanagon Carat
1982 Vanagon Diesel - In pieces at the moment
1987 Syncro - RIP
2010 Sportwagen TDI the road warrior
Howesight
PostPosted: Thu Jun 19, 2014 5:05 pm    Post subject: Re: Source for expansion valve ? Reply with quote
Hi Guzyk:
The unit in the link above is good quality. Nostalgic Air uses a lot of old-school technology (as opposed to the electronic controls, for example) in their kits to service the hot-rodder segment of the DIY AC market. They sell the good stuff, unlike some parts jobbers who will never see you again.
MarkWard
MarkWard is offline
PostPosted: Fri Jun 20, 2014 8:58 am    Post subject: Re: Source for expansion valve ? Reply with quote
If the capillary tube is intact, you probably don't need to replace it. If you look at the one end you will see two set screws for adjusting it. I imagine you could just clean it out and put it back into service. They would clog during a component failure and be replaced. At one time VW even had a cone shaped screen filter on the inlet, but in production probably realized it was better to not stop crud there and got away from that. If you are resurrecting and old system, I have seen inline filters you can add to the high side coming out of the compressor to catch any debris. If you can get the system flushed well, you would not need an inline filter.
AC rocks.
1982 Vanagon Camper with ALH TDI conversion.
1990 Vanagon Camper project Syncro conversion.
Cubscout
Cubscout is offline
PostPosted: Tue Jul 15, 2014 9:49 am    Post subject: Reply with quote
Speaking of the expansion valve being a PITA to get to. Any tips on getting to it? Im stuck on this part of the red tek conversion process....
guzyk
guzyk is offline
PostPosted: Tue Jul 15, 2014 10:39 am    Post subject: Reply with quote
You gotta drop the center section of the AC. The expansion valve is near the drivers side tubes that run up the added inside pillar.
Easiest to drop the whole ceiling unit take it apart on the floor of the van. Start from front of van work back to remove. Helper makes it easier.
guzyk
guzyk is offline
PostPosted: Mon Aug 18, 2014 5:38 am    Post subject: Where does "coat hanger" wire go? Reply with quote
When I took it all apart I didn't note where the "coat hanger wire" goes. it is connected to the right dial in front and I know it goes down the center tube but where in the rear section does it go? Does it just sit on top of the evaporator fins or just hang out in the rear section somewhere?
Terry Kay
Banned
Terry Kay is offline
PostPosted: Mon Aug 18, 2014 6:17 am    Post subject: Reply with quote
The capillary tube gets stuck on the evaporator with some strip caulking direct onto the coils--nowhere specific, just as long as it'll be able to read the temp of the coils.
Don't try and clean out the expansion valve--you can, but whatever might be in there will get stuck at the dead end of the capillary tube & it wouldn't function properly if it's full of junk.
There's no way outa there if whatever goo might be in there gets jammed at the end of the tube, and it will mess up the AC's operation.
T.K.
guzyk
guzyk is offline
PostPosted: Mon Aug 18, 2014 6:52 am    Post subject: Reply with quote
I meant the long wire that goes from front section to rear.
(front "dealer installed" ceiling a/c unit 1985)
It appears to be connected to the temp dial up front
But where do I set the other end of the "coat hanger" wire in the rear section?
BTW, the capillary tube of expansion valve is clipped to the other hard line of the evaporator (I did take a photo of this before replacing so I'm good with that)
guzyk
guzyk is offline
PostPosted: Fri Aug 22, 2014 7:51 pm    Post subject: coat hanger location figured out! Reply with quote
The evaporator end of the coat hanger goes into the hole in the black plastic evaporator cover, see photo above. The small hole is only on one side of the black cover, and there's a corresponding hole on the big cover piece. I'll post pictures once it's all back together.
guzyk
guzyk is offline
PostPosted: Fri Aug 22, 2014 8:00 pm    Post subject: Reply with quote
Now I need help with the electrical bits. Is this extra fuse panel beside the main dash panel related to the aftermarket A/C? If so, what fuse is missing to the right of the yellow 20Amp fuse?
Also, in the engine bay it appears only one wire is AC related. I think it simply went to the AC clutch. However, later model "factory air" Vanagons had two wires, one for AC clutch, I think the other to increase idle when AC was on??
Any advice how best to integrate the VW aftermarket AC wiring with Subaru wiring?
Modtechteam
Modtechteam is offline
PostPosted: Sat Jun 04, 2016 10:34 am    Post subject: Re: Anyone have 85 TinTop AC with Subaru ? Reply with quote
I have an 83 Air Cooled Vanagon with factory AC, I need the double pulley that went under the compressor does anyone know a place I can get one? Thanks
