lostarter Samba Member
Posted: Thu Jun 02, 2016 12:33 am Post subject: Matching vin and engine numbers |
I read through a few threads mentioning none or very little documentation of this. I have a 1972 safari that has proof it seems. Figured I would add this to the lexicon. Unfortunately the original orange was painted over... But everything else seems to be original. Seemingly only 28,900 miles , I think it was towed around.
Bruce Samba Member
Posted: Sat Jun 04, 2016 12:04 pm Post subject: Re: Matching vin and engine numbers |
Even though the Mexican authorities are calling your car a 1972, your car is actually a 71. The 3rd digit in the chassis number is what VW used to identify the year.
The true mileage is likely to be much more. The engine case you have is not the original case. But don't change anything. Since the number stamped in the case matches the label applied by the Mexican authorities, you're in compliance of the law (assuming you are in Mexico) where your engine number must match the documents. _________________
Posted: Sat Jun 04, 2016 8:31 pm Post subject: Re: Matching vin and engine numbers |
Interesting. Are you saying that the silver sticker with the engine number was added later? Is it not the original engine because no AM in the number? I'm really curious about this and haven't been successful in finding much info.
I bought the car in Texas as a 72. And now have it in Oregon . Should I be calling it a 71 despite the papers? I understood the 3rd number thing but thought it might be made in 71 and actually a 72. Thanks! |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Sat Jun 04, 2016 10:06 pm Post subject: Re: Matching vin and engine numbers |
The speedometer appears to be from a 1968 to 1970 VW Bug, as I believe that in Mexico the cars had a speedometer in Kilometers / hour. I had a similiar speedometer in my car, replaced it with a Bug 1970 one in KM/HR. Date/month code should be present on the back of the speedometer. |
Semper_Dad Samba Member
Posted: Sun Jun 05, 2016 6:12 am Post subject: Re: Matching vin and engine numbers |
lostarter wrote: |
Silver Sticker was most likely added after leaving the factory as part of the Mexican registration process.
The 181 VIN would technically make this a 1971 model but it was not uncommon for 71 vehicles to be registered as 72s if actually sold in 1972.
An AM engine would have been used in 73 and up 181s bound for the USA. 71s would have been a single port and most likely a different engine code.
There is a table floating around that lists what engine codes went to what vehicles by year. http://www.thesamba.com/vw/archives/info/engine_letters.php _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Sun Jun 05, 2016 9:22 am Post subject: Re: Matching vin and engine numbers |
Read though the vin number pages and didn't see any "thing" stuff.
The back of the speedo isn't as easy to check out as it is in a bug haha.
It seems most vw engines have a letter prefix but not mine. Is there a Mexican production list out there? |
oconnell Samba Member
Joined: September 04, 2006 Posts: 214 Location: waynesville, missouri
Posted: Tue Jul 31, 2018 3:01 pm Post subject: Re: Matching vin and engine numbers |
all thing engine numbers begin with AM |
Deckard Samba Member
Joined: April 07, 2012 Posts: 296 Location: Knoxville, TN
Posted: Wed Aug 01, 2018 4:40 am Post subject: Re: Matching vin and engine numbers |
Mexico (and Germany, for that matter) does follow the metric system, so the speedometer is definitely a later addition |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Wed Aug 01, 2018 10:18 pm Post subject: Re: Matching vin and engine numbers |
I believe there is a engine production chart out there, for all Type 181's. I saw it at the end of one of the many parts manuals. In fact, I think it was in the parts manual that someone was nice enough to post, not too long ago. Anyway, all of the engines listed had 2 letter prefixes. |
SilverThing Samba Member
Posted: Sun Sep 16, 2018 12:33 pm Post subject: Re: Matching vin and engine numbers |
As far as I have seen in official documentation, the 181 had 5 different engines during its production run.
The first engine was a single port 1500cc engine. The cylinders heads were 311.101.353A, which I believe is the same head the 1600 single port engine used (35.5x32 valve size). Compression ratio was 7.5:1. The power output was DIN BHP 44 @ 4000 rpm, 102 NM torque @ 2000 rpm. Carburetor was a 30pict-2 (24mm venturi). Octane requirement: 91 RON. Other interesting tidbits are galvanized pushrod tubes and clutch plates without torsion springs (those two items carried through to other 181 engines). The letter code is 'H', but I like to refer to them as 'H1' engines because the first digit is 1 unlike other H case engines. For civilian models, the engine was only offered in the 1970 model year (ie 8/69 -7/70). Military users continued to get the engine until the end of January, 1971.
The second engine was the 'AG' engine. It was introduced in the 1971 model year (at different times depending on whether the vehicle was military or civilian) and displacement increased to 1600cc. The compression ratio was reduced to 6.6:1 via dished pistons. Power output: DIN BHP 44 @ 3800 rpm, 100 NM torque @ 2000 rpm. The cylinder heads “were like the new type 1/1600”. The intake manifold is the same as the 1300dp engine (31pict-3 carburetor with 25.5mm venturi) and doghouse oil cooler. Octane requirement is 83 RON. The engine was offered until the end of the 1975 model year.
In March/April of 1973 two new engines were introduced: 'AL' and 'AM'. The dished pistons of the 'AG' engine were replaced with slight dished pistons (standard equipment on all other 1600cc engines since Aug 1971). Compression ratio was back up to 7.3:1, power output was DIN BHP 48 @ 4000 rpm, 102 NM torque @ 2000 rpm. The intake manifold was increased in size (35mm – previously 33mm) and the heat risers were also enlarged (24mm from the previous 20mm). The carburetor was 34pict-3 (26mm venturi). Octane requirement was back up to 91 RON (I have one brochure that also mentions 80 MON). 'AM' engines were for US market emissions in 1973 and 1974 (fuel vapor recovery system, dual vacuum distributor, and exhaust gas recirculation). AL engines were available everywhere else for 1973 thru 1978.
In 1974, the 'AF' engine was added to the lineup (or rather borrowed from other lineups). It is listed as a 6.6:1 compression ratio with 46 DIN BHP @ 4000 rpm, and 100 NM of torque @ 2600 rpm. Carburetor is 34pict-3. Octane requirement is 83 RON.
Now with regards to the engine without a letter code: I can't say for sure whether it is factory or not. The 181 that were built in Mexico were initially done as complete knock down kits (that changed sometime after 1974 - anecdotally I have heard 75/76). I don't know how much assembly was required for the knock down kits and I don't know if the factory in Mexico had the flexibility to substitute locally manufactured parts (like engines). Birth certificates from VW are notoriously inaccurate for CKD 181 (this includes US market Things). |
stevegsmith Samba Member
Posted: Wed Feb 12, 2020 9:01 am Post subject: Re: Matching vin and engine numbers |
Hi, new here but not so new to VWs. Had two '66 busses in late 80's and that started my backyard-mechanic life. Now, my daily is a 1982 Gwagen. I've long lusted after a Thing and came across one by chance. A friend of the family and ex-pat living in Sonora Mexico has agreed to sell me his Thing.
1. It doesn't have a VIN plate but he does have current registration...which strangely doesn't have a vin BUT does have an engine number...and a make date of 1972.
2. The engine doesn't appear to have a stamp so I can't verify or match the Reg. The Reg says the engine number is 1311437 (very close to another forum members 1972 Things engine, from this post: https://www.thesamba.com/vw/forum/viewtopic.php?t=656187). The firing order is in spanish....."Ignicion 1-4-3-2"...not German like the forum post pic in the link.
3. The vin stamp is illegible but appears to start with "1852...." which suggests...or perhaps confirms that it is indeed a 1975 or late made 1974. Maybe one of you kind folks will confirm that...or is there any chance at all that it could be a '72?
4. On one of his documents, has two other numbers:
a. Registro Federal de Automoviles 2385759 (which looks like these could be the numbers that follow the VIN stamp starting with "185..)
b. Padron: 290229924
Any thoughts or advice would be greatly appreciated from you kind folks. I love forums and am part of the clubgwagen group and understand how this works. If I acquire a Thing, I will surely be a contributor someday.
Help me Obi Wan,
steve
SF Bay Area
ps. will post a pic or two shortly. |
Posted: Wed Feb 12, 2020 9:52 am Post subject: Re: Matching vin and engine numbers |
Sounds like a total nightmare, if it is not registered in the US. If the Vin Stamp says 185 then it is a '75 model. To bring a '75 model into the US (legally) requires it to meet all the DOT requirements. I know someone that just did it and it cost him about 10k or more. You really need to do your homework on that one. |
Joe 20 Samba Member
Posted: Wed Feb 12, 2020 8:42 pm Post subject: Re: Matching vin and engine numbers |
Instead of asking us what we think, why don't you contact your DMV and see what they think? Their opinion matters more than ours since they will title it. You can also do a forum search on here relating to bringing a car in from Mexico. I'm sure you're not the first. Good Luck!! |
Posted: Wed Feb 12, 2020 11:17 pm Post subject: Re: Matching vin and engine numbers |
Al Capulco wrote: |
Agreed, hence the homework starting here, with the forum. Thanks. |
Posted: Wed Feb 12, 2020 11:19 pm Post subject: Re: Matching vin and engine numbers |
Joe 20 wrote: |
Yep, that's next. Just thought I would check here first. Thanks. |
