GL 4 or GL 5 - "Official Gear Lube Topic"
Page: Previous  1, 2, 3 ... 52, 53, 54 ... 68, 69, 70  Next
Casting Timmy
Casting Timmy is offline
PostPosted: Fri Jun 03, 2016 6:18 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
gears wrote:
Once again, while GL-4 is more than adequate for stock applications, I'd recommend a high quality GL-5 for any Vanagon with significantly upgraded horsepower, or any Bug transaxle pushed to its limits (road-racing or off-road).
Personally I think this is the best summary of this 50 pages. I would personally add that why not use 75-90 or 80-90 GL5 for stock applications (better protection) and a 75-140 or 80-140 for those that really should have a bigger transaxle or push theirs to the limit.
Lingwendil
Lingwendil is offline
PostPosted: Tue Jun 07, 2016 4:57 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
So... my tranny occasionally gently grinds into first gear when i've been on the road for a good hour or so, but if on a slight roll or when the engine is cold it does not. yes my clutch is adjusted properly.
previous owner was a dumbass, and the car is 40 years old, so i want to change the gear oil to be safe. from stuff i can get at napa, autozone, oreillys, what should i put in? 80w/90 right? GL5 should be fine? GL4? im scared now with all the peter measurement going on, but i'm inclined to think i'll be safe with GL5...
73 super beetle, stock 4spd. no leaks, nice and quiet tranny.
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Tue Jun 07, 2016 2:18 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Kill 2 chickens, paint a blood pentagram below your trans then pour in oil selected at random from the shelf at FLAPS. That's about as much sense as this thread has ever made. Rolling Eyes
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
EVfun Premium Member
EVfun is offline
PostPosted: Tue Jun 07, 2016 4:40 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
[snip]
Provided your engine is stock, or close to it, I would look for oil marked GL-4. It may carry other approvals too. The Beetle does not have a hypoid final drive so there is little need for the extra protection, but you are trying to get a little better shifting from what you typed.
That said, a little grinding when downshifting into 1st at more than a few mph is not unusual. That seems to be a weekness with these boxes.
Wildthings wrote:
Lingwendil
PostPosted: Tue Jun 07, 2016 9:37 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
It only has a little "skwhhh" into first when coming from neutral, usually when sitting at a light or something, like when you first get off the freeway and start going through town.
EVfun is offline
PostPosted: Tue Jun 07, 2016 10:02 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
If your light grind into 1st is while stopped, and worse warm than when cold, it is quite possible you have a separating clutch disc. The friction surface can "bubble up" off of the steel disc if the rivets are starting to fail in some area. It can create a little drag against the flywheel and spin the input shaft with a little force even though you have pushed the clutch pedal down.
If the noise happens when you are stopped I would not suspect the gear oil. Stopped with the clutch released means nothing in the gearbox should be spinning.
Wildthings wrote:
Lingwendil
PostPosted: Wed Jun 08, 2016 5:48 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
my 73 has the "long" release arm on the tranny, so I'll try adjusting it a tad bit tighter and see if that helps. I'm running a 1700# Kennedy with a Daikin disc, and when i pulled the engine recently to do rear tranny mounts i pulled the clutch and it looks brand new, dry, tight, etc.
jovanybg
jovanybg is offline
PostPosted: Thu Jun 09, 2016 8:49 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I will be changing the tranny oil on my 1971 Autostick Ghia with Royal Purple Max Gear 75W-90 and will update on the behavior after the change. The description of the oil states is safe for yellow metals and it is GL-4 and GL-5 compatible.
Bug-nut
Bug-nut is offline
PostPosted: Thu Jun 16, 2016 4:06 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Lol, I love this! Laughing
That said, for my own peace of mind, this is what I run in my VW, and it's been running and shifting about as well and flawlessly as a 57 year old, un-restored transmission could. I'm sure GL-5 would work in it just fine, but why take the chance when I don't have to? There. End of discussion and worry on my part.
(As an aside, my AH Sprite uses straight 30 weight, non detergent motor oil in its transmission. Shocking huh? Shocked )
1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote:
A 59 Beetle is just an Oval-Window car with aspirations of modernity.
miniman82
Samba Swamp Donkey
PostPosted: Fri Jun 17, 2016 4:18 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Bug-nut wrote:
my Sprite uses straight 30 weight, non detergent motor oil in its transmission. Shocking huh?
Not really, I had a Ranger that called for ATF in the Mitsu built 5-speed.
Wildthings
Wildthings is offline
PostPosted: Fri Jun 17, 2016 4:58 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
There are automatic tranny fluids which carry GL-4 ratings for transaxle use. As for 30wt, most any 30wt would have met the GL-3 rating and most any 40 wt will meet the GL-4 rating. I have 5w30 oils in the manual tranny in my ancient Toyota Land Cruiser and used the same in the tranny in my ancient Dodge 4x4 truck.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jun 17, 2016 5:03 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I had a Honda that used ATF in a manual gearbox.
So what's your point? This is a VW forum.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bug-nut
Bug-nut is offline
PostPosted: Sat Jun 18, 2016 12:40 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Just making some small talk along with my poor attempt at some humor. That was all.
Sandbar Norm
Sandbar Norm is offline
PostPosted: Wed Jun 29, 2016 12:28 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
After skimming thru 50+ pages.
For higher hp we should use GL-5 and just accept the harder shifts.
Or use GL-4 and get good drivability with a higher ware.
I'm running a ecotec now with a t1 trans now.
I have a rebuilt 5 rib with a 091 4 spider diff ready to install.
I'm thinking about a turbo with the trans/suspension swap.
Best gear lube to use?
I want smooth shifts so GL-4.
Correct Question
Norm
neil68
neil68 is offline
PostPosted: Wed Jun 29, 2016 10:18 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
I switched to GL5 several years ago and the shifting became noticeably smoother thereafter. Plus you get the added protection for the OEM German parts that are NLA.
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
Wildthings
PostPosted: Wed Jun 29, 2016 10:25 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
It is rather pointless to say you "switch to GL-5" unless you specify which oil you switched to as many GL-5 oils give considerably worse shifting. You should also say what oil you switched from.
SBD
SBD is offline
PostPosted: Thu Jun 30, 2016 6:20 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Shocked What, you want him to clog the thread up with worthless details? Very Happy
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
Sandbar Norm
PostPosted: Thu Jun 30, 2016 11:48 am    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
No oil in it now, rebuilt and waiting to install.
I was just looking for putting oil that will shift good and help the trans last.
You know, I want the cake and also get to eat it also. Very Happy
Wildthings, what kind of GL-5?
Norm
Wildthings
PostPosted: Thu Jun 30, 2016 12:14 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
Norm
It is neil68 that needs to fill in some blanks and not I. Wink
Sandbar Norm
PostPosted: Thu Jun 30, 2016 1:50 pm    Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" Reply with quote
This looks like it would work well for me.
https://www.amsoil.com/shop/by-product/transmissio...be-75w-90/
or this
http://www.redlineoil.com/product.aspx?pid=46
Norm
Page 53 of 70
