saw2 Samba Member
Joined: November 06, 2008 Posts: 321 Location: nw Oregon
Posted: Thu Jun 23, 2016 8:26 am Post subject: Wideband reading dirrerences? |
Just installed new engine want to start tuning with a AEM wideband. I have not used a wideband a lot, but have read wideband posting several times and think I have a good grasp on the procedure.
I now have a chrome 1 1/2 Tri-Mil header with muffler. I don't want to weld a 02 bung in and ruin the chrome finish. So I purchased a used Tri-Mil stinger section from Samba classifieds. It has a Super Trapp setup welded on the end
I have crudely welded a 02 bung for sensor.
My question is will the different exhaust flow am I going to get different afr readings and settings due to using the temporary stinger set up and then going back to the muffler setup for normal street use?
Also how is this for jetting starting out at sea level elevation. Here are engine specs.
Weber 40 IDFs. 32 venturi. F11 e tube
52 idles
135 mains
200 air
2180 cc
8.8:1 comp ratio
40×35 mild ported heads
CB 2242 cam
1:1 ratio rockers
AC.net SVDA Bosch 034 distributor
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Jun 23, 2016 12:31 pm Post subject: Re: Wideband reading dirrerences? |
I doubt it, but you'll get more HP with a proper muffler than you will that supertrap. Think about the name for a second... _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Thu Jun 23, 2016 12:44 pm Post subject: Re: Wideband reading dirrerences? |
It could make a difference if it restricts flow to the the point the exhaust stroke fails to extract as much from the cylinder as with the normal setup. So then the next induction stroke might have a little less O2 getting in because of higher pressure in the cylinder so might indicate leaner.
But as a general tool it will work and you will learn a lot if you can manage to drive without constantly staring at the gauge while you are in the real world accelerating hard towards something slow moving in front.
My PLX devices AFR meter with sensor welded into my stainless exhaust has saved me the cost of rolling road tuneups and let me instantly spot that there is a problem with a carburettor jet or an air leak. _________________ Ancient vehicles and vessels
saw2 Samba Member
Posted: Thu Jun 23, 2016 4:22 pm Post subject: Re: Wideband reading dirrerences? |
I will only use the stinger with Supertrapp temporarily while wideband tuning. Then going back to the chrome muffler set up. Am just concerned if it would cause different afr readings between the two exaust end section styles
I never really thought about until now, but I could also cut off and replace with a small muffler of some type. Not concerned about looks as the stinger set up is only temporary. Or even just take off Supertrapp and go with straight stinger.
Going to try stinger with Supertrapp and then with Supertrapp plates and end removed to see if there are any differences in afr readings. |
henk Samba Member
