Terriers 2121 Samba Member
Joined: September 09, 2014 Posts: 53 Location: Alberta
Posted: Tue Jan 06, 2015 8:59 pm Post subject: |
Thanks for the advice, some good points there. Before i do that, I have been putting back the parts that were off the engine when i bought it and basically getting a list together of stuff that i don't have. Couple of questions i have that you guys could maybe answer. The Crankcase ventilation, (hope thats what its called), i haven't seen many engines with this on, is this a common thing?.
My next one, what do you think of the condition of the heater boxes and ducts? is this something that can be repaired?
Anyone know what this part is for? |
Artvonne Samba Member
Joined: January 03, 2015 Posts: 74 Location: Rogers, Ar
Posted: Tue Jan 06, 2015 10:46 pm Post subject: |
If it were mine...
The motor is about as simple as anything, just putzy plus a few technical things you have to pay attention too.
I would tear it down completely and put it back together clean with whatever new or good used parts it needs. Thats the only way to know for sure what you have. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3777 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Jan 07, 2015 7:35 am Post subject: |
Use a brass wire brush and have at it on those heater boxes. Once done soak them in rust converter. How do the levers move on the heater junctions?
When satisfied the rust is dealt with paint them with some hi-temp VHT paint. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Thu Apr 16, 2015 7:25 pm Post subject: |
So, since my last post ive managed to achieve i locked engine, not sure why, so here goes the tear down. Never gone down this road before, so it should be good learning process. Heres some pictures of what i've found so far,
Being new to this, what condition would make the right head look like that? |
Posted: Thu Apr 16, 2015 7:29 pm Post subject: |
Tcash Samba Member
Posted: Thu Apr 16, 2015 7:44 pm Post subject: |
Looks like something got in the cylinder at one time. Can you turn the engine over now?
Tcash |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Thu Apr 16, 2015 8:04 pm Post subject: |
Terriers 2121 wrote: |
Bottom photo - Pre heat connection on the firewall. Keep it. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Fri Apr 17, 2015 7:40 pm Post subject: |
Heres what i found today which would possibly, maybe, explain the condition of the head
hopefully you can make it out from the pics, the side of the cylinder has a worn V into the side of it, has anyone seen this before? what would cause this?.
udidwht, thanks for the reply on the preheat connection. T cash we are still locked!, unfortunately. Wasted youth, thanks for that link, i think i glanced at your post one time, i'll be sure to read it proper now. |
Posted: Fri Apr 17, 2015 7:47 pm Post subject: |
Heres what i found on the other side, lots of junk in there and a broken ring.
Both pieces of the ring were still attached to the cylinder.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Apr 17, 2015 7:54 pm Post subject: |
Wow, either too much starting fluid or too much advance, it's been like that for quite a while, it must have run like ass _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Apr 17, 2015 8:36 pm Post subject: |
Must have had some serious heat to do that hey?, damn shame, they kept the inside pretty clean, must have just ran it hard, and not bothered with the engine. |
Tcash Samba Member
Posted: Fri Apr 17, 2015 9:54 pm Post subject: |
Hopefully you can make it out from the pics, the side of the cylinder (piston) has a worn V into the side of it.
Picture is blurry. Can't make it out.
Tcash |
Posted: Sat May 16, 2015 8:32 pm Post subject: |
Been a bit since the last post. Since then i have stripped the engine down, after each step i kept on checking to see if the engine would turn over, no such luck. Until, that is, i split the case. It opened up about an 1/8 in then turned. Once the two half's were separated i found that one of the main bearings had become seized to the crankshaft. How this happened i,m still not sure. I found part of one of the cam shaft bearings to be broken away, so maybe part of that has somehow got in there, heres some pictures,
Pretty sure that the oil pick up shouldnt look like this!. |
Posted: Sat Jun 25, 2016 12:28 am Post subject: Re: 72 Westfalia |
Been a while since the last post. I originally had plans to rebuild the engine. As that was going on, another bus came up, same year as mine with a running engine. The body needed a lot of work, so i took the engine out with the plan of putting it in my original bus. Before i did that i checked it the best i could and got it up and running. The po must have liked his sealant or whatever that blue stuff is.
https://www.thesamba.com/vw/gallery/pix/thumbnails/1523288.jpg
With the engine and transmission out, https://www.thesamba.com/vw/gallery/pix/thumbnails/1523287.jpg
(that was an experience being my first engine drop), i was ready to start looking at changing seals and giving it an half decent clean. Pushing the donor back up the driveway
https://www.thesamba.com/vw/gallery/pix/thumbnails/1523286.jpg
I decided not go to far into stripping it down, basically because of experience and not wanting to get into something difficult. Im pretty much a complete novice at this point, learning everything as i go.
https://www.thesamba.com/vw/gallery/pix/thumbnails/1523285.jpg
https://www.thesamba.com/vw/gallery/pix/thumbnails/1523284.jpg
I have changed the rear main seal, the oil filler gasket and the oil cooler seals. I have to change the oil pressure switch as i have no continuity between the electrical tab and the body. This switch should be normally closed, correct?. Everything i've changed or taken off has been cleaned and where necessary primed and painted. I've replaced the fan shroud studs that go into the engine with regular bolts. This should make it easier to get off with the heat exchangers in place. As of now the shroud is in place and the heater flaps for this are being cleaned. I have replaced the fan bolts with regular allen key bolts, since the last ones were a little stripped, making one of them fun to get out!.
I decided to give the gas tank a once over by having it coated inside. wouldn't call it the greatest job vie ever seen and to be honest, i may have been better to just leave it as it was, but i started reading some threads on the subject, got a newbe panic on that it needed doing and went ahead with it. As it was out already i finished the outside after sanding out any rust spots. I applied some rust protector/inhibitor primer, then painted it with Rustoleum. Turned out not too bad. I applied some foam tape in the areas where the original had come off, put it back in place and changed all the fuel lines except the filler hose. This seemed in pretty good condition so i changed the clamps and carried on.
https://www.thesamba.com/vw/gallery/pix/thumbnails/1523282.jpg
http://imhttps://www.thesamba.com/vw/gallery/pix/t...523281.jpg
https://www.thesamba.com/vw/gallery/pix/thumbnails/1523279.jpg
My plan is to get the engine back together, test it while its still out, check for possible leaks/problems and then put it in the bus. |
Posted: Sat Jun 25, 2016 12:35 am Post subject: Re: 72 Westfalia |
Oops, didn't upload the previous posts pictures right.
Posted: Wed Jun 29, 2016 10:11 pm Post subject: Re: 72 Westfalia |
Managed to get a couple of things done since the last post. Got the fan put back on. I wanted to change the torx bolts to allen key heads. Got a couple of sizes, but on was just a touch shorter and the other one just slightly longer. The short one wouldn't reach the other side of the fan hub an the longer one ended up nearly touching the seal. So in the end, the original ones were cleaned up and put back in.
Got the thermostat flaps cleaned up, rust all sanded off and primed.
I think i have the wrong pins for the heater box flaps. From pictures ive seen both are straight, but i have one that is dog legged on the end, is this how it should be?.
Thought too long on cleaning and painting the original engine tin screws, but came conclusion that i'd be better off starting with new m6 hex heads, so i gave them a light sanded and painted them black.
My aim and the start of this engine was to change the necessary seals and a few other things then try to get it on the road at least for one camping trip this year. Maybe i should have done this sooner, but i pulled the spark plugs for a look tonight and it looks like to me that the piston rings are worn and need replacing, any input on this would be appreciated. |
canadadude Samba Member
Joined: November 21, 2015 Posts: 41 Location: Regina ,Sasktachewan
Posted: Tue Mar 19, 2019 5:02 pm Post subject: Re: 72 Westfalia |
How’s the progress coming on this van is it completed?Any new pics?Ive found a 72 bus like this one with similiar rust spots ,wondering if you could tell me roughly what you spent on rust repair?Paint etc Thanks _________________ 66 VW Beetle |
rustbus Samba Member
Posted: Tue Mar 19, 2019 11:10 pm Post subject: Re: 72 Westfalia |
yeah this is a nice bus, whats the update, did you get it running yet? _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
