Oper$123 Samba Member
Posted: Fri Jun 24, 2016 6:24 pm Post subject: 1915cc turbo |
Looking to do a turbo on my 1967 beetle...Any thoughts or advice. Wanna do it right. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Posted: Fri Jun 24, 2016 6:33 pm Post subject: Re: 1915cc turbo |
What's your budget?
Have you upgraded the transmission and brakes yet? _________________ Glenn
Member #1009
#BlueSquare |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Fri Jun 24, 2016 10:57 pm Post subject: Re: 1915cc turbo |
Up grade trans or brakes has NOTHING to do with his question.
That was a wrong answer..
DRAG car yes but for the street NO upgrade is needed.
I have a 66 bug 1776 Turbo and the trans and brakes are all stock. Engine is over 20 yrs old and in it's 2nd 66 bug and both had a stock trans and brakes.
I change cars but keep the same engine.
A 1915 Turbo would be no problem in any stock running gear. As for cost it can be done with Used Turbo modified or a NEW Turbo kit for that size engine. There are a few on Sambo that have done a low cost Turbo installation.....all comes down to a choice which way to go depending on $$$ flow. I went with the NEW high end doing mine thus the long years of service.
I went with a stainless exhaust....never a problem.
A good street compression would be 8:5 -1 using 87 gas.
041 heads etc with 40x35 or 39x35 will work.
Carb is a Weber 40DCOE and jetting is easy.
Engle 110 Cam with a 69CW crank combo will work.
Key thing is to Balance the bottom end.
Basically a 1776 has the 90.5 cyl while the 1915 would be the 94 using more gas.
Decades ago I tried different combos for a Turbo in my NHRA Legal Dragster and found that a 1776 would work real nice in a stock bug, thus the setup went in a 70 bug I then had and later to a 66 bug ending to today.
As to compression I started real low and needed stock in Shell or Mobil as the engine gulped gas. Increased the comp for the same HP and less fuel was needed. Some run a higher comp so a matter of choice and needs.
Just a thought and personal experience. |
74 Thing Samba Member
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Jun 25, 2016 3:22 am Post subject: Re: 1915cc turbo |
I did one or two :lol:it's the most fun u can have with your clothes on _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Sat Jun 25, 2016 4:21 am Post subject: Re: 1915cc turbo |
Don't do a lowbugget kit if you do. Expensive moneypits.
I've helped put together a couple of the CB kits and they are nice. the turbo hideway headers are very good products.
Don't lock out your timing, use a real boost controller or go crank trigger, which leads you down the path of EFI, which is the best way to do it right. Megasquirt + Mexican EFI hardware + CB turbo hideaway header = clean, efficient, powerful, endlessly tunable on a better budget than you think.
first turbo setup I worked on was a K03S blowing into a stock 34PICT-3, with homebuilt manifold, and a boost-referenced stock fuel pump. Small turbo= instaboost. ran great but kept going pig rich on the top end. talked him into megasquirt EFI and he ordered up a set of intakes etc. from Antonio triejo. night and day difference in smoothness and driveability, and it was great on gas too, like 32MPG hwy. after that i decided that turbo+carb was a waste of my time.
What sort of car? only way I would go turbo on my own car is if it was a Baja, let that beautiful mess hang out to show it off to everybody _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Sat Jun 25, 2016 6:45 am Post subject: Re: 1915cc turbo |
Do lots of research..........start here.
http://www.shoptalkforums.com/viewforum.php?f=3&sid=336096b380c0c1446ab8dc443fc9d7a6
Look at as many systems as you can and if possible see how they run.
I see you are in Washington.
There is a big VW show coming up in the middle of July in Seattle. Go there and look at a few turbo systems if you can find any.
I plan on being at the Burger Meet on Friday night and will have my turbo buggy there if you want to see it.
You might be able to catch Mario there and he can give you info on Fuel Injection which I recommend for a great driving experience.
I feel a blow through turbo system will give better results in the cool, wet climate of our State.
Just remember......you are the mechanic and the engineer when you go turbo. Even if you buy a kit you will spend much time installing and tuning it.
Most kits are a bunch of parts and you will need to make them run.
When you look at turbo cars, ask how many miles they have been driven. That will tell you how well they perform. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
rockurob Samba Member
Joined: August 23, 2009 Posts: 358 Location: Okla City, Oklahoma
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sat Jun 25, 2016 6:34 pm Post subject: Re: 1915cc turbo |
Glenn's advice is valid, I don't care what the other guy said. If you plan to use the turbo's power a transaxle upgrade will be needed. A well built 1915 turbo would be pushing somewhere between 150-180hp
Upgraded brakes is just common sense...and a good idea if your engine is stock or high performance.
There are a few kits available as mentioned above |
Glenn Mr. 010
Posted: Sat Jun 25, 2016 6:45 pm Post subject: Re: 1915cc turbo |
txoval wrote: |
It would be best to take your question to the high performance section. |
If the OP wants it moved... just ask.
txoval wrote: |
Also, Glenn's advice is valid, I don't care what the other guy said. If you plan to use the turbo's power a transaxle upgrade will be needed. A well built 1915 turbo would be pushing somewhere between 150-180hp
Seen a friend put a 2276 in with a stock tranny. When he got to the first top sign he dropped the hammer and the tranny let go.
Years ago I was chasing a Corvette in the parkway when we came around a turn and the cars were dead stopped. He hit the brakes and came to a stop. I hit the brakes and barely slowed down so I headed for the grass shoulder and finally stopped after passing a few stopped cars. I have since upgraded my stock drums to front disc and Type 3 rear drums.
Every new car manufacturer that offers a hi-po version of their 'standard" car included brake and suspension upgrades when they add a high HP engine.
Mustang GT
WRX
Porsche GT2
Challenger w/ Hemi
Lexus F Sport
All are not just engine upgrades. _________________ Glenn
Member #1009
#BlueSquare |
Glenn Mr. 010
Posted: Sat Jun 25, 2016 6:46 pm Post subject: Re: 1915cc turbo |
Lingwendil wrote: |
Which other guy lol |
This:
HRVW wrote: |
DRAG car yes but for the street NO upgrade is needed. |
Member #1009
#BlueSquare |
jason Samba Member
Posted: Sat Jun 25, 2016 7:39 pm Post subject: Re: 1915cc turbo |
A high performance motor at 60 will stop the same as a stocker at 60, just saying |
Glenn Mr. 010
Posted: Sat Jun 25, 2016 7:59 pm Post subject: Re: 1915cc turbo |
jason wrote: |
Correct, but a stock engine will not get you to 90-100mph.
Also when you have a high performance engine you tend to accelerate faster. _________________ Glenn
Member #1009
#BlueSquare |
Dauz Samba Member
Posted: Sat Jun 25, 2016 9:25 pm Post subject: Re: 1915cc turbo |
I got tired of standing on my brake pedal with drums.. now I almost have to paint my toenails while I twinkle toe the pedal with discs. |
HRVW Samba Member
Posted: Sat Jun 25, 2016 10:11 pm Post subject: Re: 1915cc turbo |
A Turbos function is to operate under Boost which is generally done on hard acceleration thru the gears.
Driving normally the vac/boost guage will move between 16 and 5 inches of Vac as it does on my Turbo when shifting gears.
If I step harder and longer on the gas pedal I go into BOOST mode.
Works great on the FWY on ramp etc while in city traffic with the traffic signals a little difficult w/o drawing attention to myself.
I have a longer exhaust pipe coming out of the Turbo thus a slight megaphone sound. Do have two extra pipes so I could cut one down to a small short outlet. Will take a looksee tomorrow.....no harm no foul. |
Posted: Sun Jun 26, 2016 3:44 am Post subject: Re: 1915cc turbo |
Trans up-grade: at least a super diff
or don't do burnouts : ( I made 6 passes on a bone stock trans and didn't hurt a thing inside the trans) 73 with 10/15 spiders ,,
turbo bugs love STOCK ratios
Just like HRVW sez: they drive like a stock bug (in vacuum 15-20" on mine step on it,, an hang on 12 lbs on pump gas 1915cc all Balanced
40 DCOE or 45 dcoe keep the vents about 30mm
turbo header 1 1/2 or 1 5/8 (check with CarCraft in Riverside
cam? keep it small(dur.@ 250 or less don't need a turbo cam
full MSD ignition
T3 or t3/t4
full flow oiling & 1 1/2 qt sump,, this will push a bug to an 11's in the 1/4 _________________ 'Black Ice'Drag Buggy 'Turbo'
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Sun Jun 26, 2016 6:58 am Post subject: Re: 1915cc turbo |
jason wrote: |
This is only true if you are just cruising at 60, even then I got tired of slamming on the brakes and still having to dive into a shoulder while going around a blind turn. After the third or fourth time that happened I threw the drums in the garbage.
Accelerating to 60mph with a stock engine that is starting to run out of breath is no comparison to a turbo car pulling hard past 60 with power to spare. With the design of a VW being light in the front, RWD and rear engine I found the need to go 4 wheel disc and a valve to adjust rear bias. You don't have the weight in the car to slow you down like a big muscle car or truck. Your brakes and a fast downshift are important to prevent an accident. If you don't think so, I don't think you've driven a bug that's fast enough to make you believe in it _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun Jun 26, 2016 2:49 pm Post subject: Re: 1915cc turbo |
I took my 1915T down the 1/4 one day, nearly ran off the long end of the track because drums suck. I literally hit the pedal and nothing happened. Turbos and disc brakes go hand in hand IMO, I wouldn't drive a turbo again without better brakes take it from me. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
