1915cc turbo
Page: Previous  1, 2
jason
jason is offline
PostPosted: Sun Jun 26, 2016 3:55 pm    Post subject: Re: 1915cc turbo Reply with quote
Never had problems with my drums stopping. My new car has drums on back. Discs are better at not fading and fetting rid of water. I would get discs though.
Eaallred
Eaallred is offline
PostPosted: Sun Jun 26, 2016 4:36 pm    Post subject: Re: 1915cc turbo Reply with quote
How poor condition are your damned drum brakes, guys?
Kris Laffer ran the Devils hot rod into the low 9's with stock drum brakes
When my 63 bug was N/A, I was running 11.70's with ONLY stock rear drum brakes and was making great the first turn out at my local track.
You guys make them sound like a suicide ride, lol.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
TinCanFab
TinCanFab is offline
PostPosted: Sun Jun 26, 2016 6:09 pm    Post subject: Re: 1915cc turbo Reply with quote
When freeway traffic all slams on the brakes at the same time, you realize your drums are like a knife in a gunfight. I had no problems with all drums until all the other idiots driving in front of me showed me how unsafe they were, and I leave a good amount of following distance when I drive. I feel Beetle brakes aren't all that bad until you need a panic stop.
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
modok
modok is offline
PostPosted: Sun Jun 26, 2016 7:55 pm    Post subject: Re: 1915cc turbo Reply with quote
They work ok sometimes. When the shoes are worn in, but before you cook the crap out of them. I don't know what the deal is but I never had a shoe wear out, I start getting fade even as low as 70mph and don't know why, switch to different shoes and it improves. I try different shoes but they are all the same, all cheap, just different colors.
Kymco is gone, right?
bugguy1967
bugguy1967 is offline
PostPosted: Sun Jun 26, 2016 9:43 pm    Post subject: Re: 1915cc turbo Reply with quote
Joel Mohr from Mohr Performance in Hesperia, CA had a 1915 turbo kit for $1900. It uses a single modified Kadron. Very clean and discreet setup that makes decent power for a budget 1915. He also has a kit for a stock 1600.
yamaducci
yamaducci is offline
PostPosted: Mon Jun 27, 2016 8:57 am    Post subject: Re: 1915cc turbo Reply with quote
Whatever you do; do not go with Lowbugget. It will never happen.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
Dauz
Dauz is offline
PostPosted: Mon Jun 27, 2016 10:33 am    Post subject: Re: 1915cc turbo Reply with quote
HRVW wrote:
A Turbos function is to operate under Boost which is generally done on hard acceleration thru the gears.
Driving normally the vac/boost guage will move between 16 and 5 inches of Vac as it does on my Turbo when shifting gears.
If I step harder and longer on the gas pedal I go into BOOST mode.
smaller turbos with smaller diameter piping are almost always on boost.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Tue Jun 28, 2016 3:30 pm    Post subject: Re: 1915cc turbo Reply with quote
New, still fades like a summbitch.
Kris Laffer ran the Devils hot rod into the low 9's with stock drum brakes.
He also had a chute, I don't. Wink
When my 63 bug was N/A, I was running 11.70's with ONLY stock rear drum brakes and was making great the first turn out at my local track. You guys make them sound like a suicide ride, lol.
Maybe your local track has more runout in it, Union Grove WI nearly didn't have enough for me but it's not the tracks fault. I stand by my statement, racing and good brakes go together like rednecks and dentures. Laughing
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
Page: Previous  1, 2
Page 2 of 2
