cdolsen1 Samba Member
Joined: June 28, 2016 Posts: 66 Location: Crystal Lake, Il
Posted: Tue Jun 28, 2016 5:40 pm Post subject: 77 bay stopped running? |
I have a 77 bay. It has been sitting for 12 years. I replaced the starter, the fuel pump, fuel filter, fuel lines , battery battery cable. On the first test run she was running great for 20 minutes and about the first 3 miles. She then then sputtered and would barely run with the peddle to the floor. I was able to get her home with restarting her a few times. in the garage she will run until i try to give her gas. What should I start with? What would cuase this problem after warm up? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jun 28, 2016 5:42 pm Post subject: Re: 77 bay stopped running? |
Welcome, how's the fuel filter look now? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jun 29, 2016 5:46 pm Post subject: Re: 77 bay stopped running? |
The same |
Posted: Wed Jun 29, 2016 6:02 pm Post subject: Re: 77 bay stopped running? |
I have found vacuum laeks and will start there. |
Posted: Wed Jun 29, 2016 6:05 pm Post subject: Re: 77 bay stopped running? |
OK, so the tank wasn't full of crap?
Try unplugging the temp sensor #2, it's that single black wire coming from #3 head, if it suddenly runs (although rich) try replacing it.
Next step is a fuel pressure test and a look for vacuum leaks with a smoke tester. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Wed Jun 29, 2016 6:09 pm Post subject: Re: 77 bay stopped running? |
Did you drain and clean the tank?
Tcash |
Posted: Thu Jun 30, 2016 4:06 pm Post subject: Re: 77 bay stopped running? |
I did drain the tank and it was clear. I had the bus idle for 20 minutes today and was fine until i hit the gas. I did disconnect the temp sensor and now it won't start. |
Posted: Thu Jun 30, 2016 4:07 pm Post subject: Re: 77 bay stopped running? |
I'm getting vacuum hos to replace and check for leaks. |
Posted: Thu Jun 30, 2016 6:58 pm Post subject: Re: 77 bay stopped running? |
Any idea where to get the heat sensor?
I cant find it on any site so far |
Posted: Thu Jun 30, 2016 8:23 pm Post subject: Re: 77 bay stopped running? |
Sure the electrical plug is firmly fitting into the AFM? |
Posted: Sat Jul 02, 2016 2:59 pm Post subject: Re: 77 bay stopped running? |
I've replaced the vacuum hoses, fuel filter and drained and replaced the gas. Still won't start. It was running perfect three days ago. What could have failed to give this issue? |
Posted: Sat Jul 02, 2016 3:14 pm Post subject: Re: 77 bay stopped running? |
Plastic block on the points broke and the gap closed up?, or maybe dirty contacts?
Connect a test light between the primary coil terminals and see if it lights when the key is on and blinks when cranking. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
timvw7476 Samba Member
Posted: Sat Jul 02, 2016 3:17 pm Post subject: Re: 77 bay stopped running? |
There is an air flap in the intake, it's at the top of the rubber S boot intake.
If your bus back-fired, that door can jam shut, no air flow, no running.
Take the air cleaner off and check that flap opens & closes, you
should be able to do it with your finger, it has a dampening action to it
when it opens/closes. |
SGKent Samba Member
Posted: Sat Jul 02, 2016 3:21 pm Post subject: Re: 77 bay stopped running? |
1) how much fuel did you put in the tank?
2) put a timing light on it and have someone crank it. Glance to see if the timing is still around 7 to 8 BTDC when it flashes if it flashes. If it does not flash look to an ignition problem.
3) Pour a TEASPOON of gas into the S-boot. Crank it, see if it starts. If it does then you have a fuel problem _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jul 02, 2016 4:45 pm Post subject: Re: 77 bay stopped running? |
There are no points. electronic ignition. The tank is half full. the air intake is open. It did back fire a few times but it kept running after. The timing is at 8.5.
Thank you for all the help. |
Posted: Sat Jul 02, 2016 4:51 pm Post subject: Re: 77 bay stopped running? |
injectors? |
Posted: Sat Jul 02, 2016 4:53 pm Post subject: Re: 77 bay stopped running? |
busdaddy wrote: |
Next step is a fuel pressure test . |
Слава Україні! |
Posted: Tue Jul 05, 2016 3:23 pm Post subject: Re: 77 bay stopped running? |
When I replaced the gas in the system I did include a fuel system cleaner. After many attempts to start the bus is alive again!!!
I think maybe somE varnish in the hard lines may have caused the problem.
Thank you all for your help!
I'm sure I will have many other Questions along the way.
Great to Know I will have such AWESOME help!!
Thank you |
Posted: Sat Jul 16, 2016 12:32 pm Post subject: Re: 77 bay stopped running? |
Well the good news is that from a cold start, the bus will start and run at idle perfectly.
The bad news seems to be that during a test ride all is good for a couple of miles, then it will backfire if I try to put any strain on the engine. First any second gear seem OK but third or up a small incline and the fun begins.
After I get home and shut it off it won't restart until the next day.
Why does it seem to only happen when the engine is warmed up? |
