Canadian Found 1950 Beetle Build
CommodoreCollector
CommodoreCollector is offline
PostPosted: Wed Jul 13, 2016 12:03 pm    Post subject: Canadian Found 1950 Beetle Build Reply with quote
Back in early june this year I recieved a lead on a 1950 beetle thru the grape vine. At first the project looked like a lot to take on for my restoration shop, which is currently full, but after a couple weeks of thought I ended up making a deal with its current owner.
After driving 2100 km and getting an enclosed trailer to keep prying eyes from seeing it, the car came home and now the work begins...
At the moment I am having difficulty reading the VIN number on the tunnel, since it is very faded on some numbers. Depending on how you intrepet it, it is either a December 1949 or August 1950 beetle. Does anyone have any suggestions for making that clearer to read before I pay for a birth certificate?
The Beetle in question is far from complete, all I have is the original Pan, body, doors and am missing everything else.
Any help/advice would be much appreciated!
Christopher
Not For Sale:
1969 Karmann Ghia
1961 Type 2 DD Panel
1960 Euro Kombi
1959 Type 2 Single Cab
1958 Type 2 Panel
1958 Type 2 Single Cab
1958 Karmann Ghia
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Wed Jul 13, 2016 12:16 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
The vin is stamped, so it shouldn't fade. But a trick I've used is to make an etching of the stamped vin with pencil and paper. Cleaning with wire wheel or brush is usually a good starting point also
https://instagram.com/mr.ogpaint
Patrick Hall
CommodoreCollector
PostPosted: Wed Jul 13, 2016 1:07 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
I was worried that the wire wheel would be aggressive on the vin. Would Vinegar or Lemon juice work also the clean it up?
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Wed Jul 13, 2016 1:33 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Let's see a picture or two of the tunnel around the ebrake/ shifter/heater/choke area. There are differences that could determine which it is.
Also the body number if it's a split body,
Also the frame number if you can see that.
The raised plate has the VIN and the other number is the frame number.
CommodoreCollector
PostPosted: Wed Jul 13, 2016 4:45 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
sled
sled is offline
PostPosted: Wed Jul 13, 2016 5:16 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
well the body is august of 50.
so assuming they match (which they probably do) then august of 50 sounds about right.
pretty uncommon for a split to be swapped onto another split pan, obviously a very long time ago.
pan looks like 0189xxx? Both very late august of 50
drive your split.
nlorntson
Crazy VW Lady
PostPosted: Wed Jul 13, 2016 5:28 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Agree, August 1950 for the pan and body. Definitely not a later 49
CommodoreCollector
PostPosted: Wed Jul 13, 2016 6:38 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Thank you Sled and nlorntson for confirming that.
Next challenge is finding the parts.
I am missing:
Steering column
Dash Clock
Speedo Surround
Rear Fenders
Hood
Pope's Nose
Tail Lights
All seats
Need a Donor Front beam
Need crash box transmission gears
Window Winders
Door pulls
Interior light glass
16" rims
25hp engine.
bumper mounting brackets (front and rear)
bumpers
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
Last edited by CommodoreCollector on Thu Jul 14, 2016 8:54 am; edited 1 time in total
sled
sled is offline
PostPosted: Wed Jul 13, 2016 6:57 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Good luck..
Be ready to open your wallet and let the Franklin faces fly.
drive your split.
RareAir
RareAir is offline
PostPosted: Wed Jul 13, 2016 9:28 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
sled wrote:
Good luck..
Besides Franklins, I also accept currency featuring Grover Cleveland & William McKinley
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
CommodoreCollector
PostPosted: Wed Jul 13, 2016 11:00 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
sled wrote:
Good luck..
You mean Canadian funny money, which is worth less than franklin?
yep, I already figured that.
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
ToolBox
ToolBox is offline
PostPosted: Thu Jul 14, 2016 8:51 am    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
sled wrote:
Good luck..
He will need to make QEII's rain...
bwaz
bwaz is offline
PostPosted: Thu Jul 14, 2016 12:01 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Nice find Christopher, can't wait to see it in the Victoria show or at the Great Canadian!
CommodoreCollector
PostPosted: Thu Jul 14, 2016 12:43 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
thanks Bwaz; Depending on how long it takes to find the parts will determine when it will be on the road again.
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
CommodoreCollector
PostPosted: Thu Jul 14, 2016 9:18 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
I did order the birth certificate last night, but on the website they said it could take as long as 5 months to receive it. Maybe by then it might roll?
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
bwaz
bwaz is offline
PostPosted: Fri Jul 15, 2016 9:24 am    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
When I emailed them directly before, they were able to give me the info on an email... once I had already paid, and the certificate would be coming...
oldbusboy
oldbusboy is offline
PostPosted: Sat Jul 16, 2016 7:23 am    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Hi Chris,
Great find!
Where does 2100km take you? North to the Cariboo? or East to the Kootenay's.. just curious where I should be looking Wink
Trevor
1958 kombi
1968 porsche
CommodoreCollector
PostPosted: Sun Jul 17, 2016 3:21 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
HerrLowlight wrote:
Hi Chris,
Great find!
Trevor
If you are looking for parts, i'd try online first. I don't know where the beetle was found but I drove to Alberta to pick it up.
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
Bruce
Bruce is offline
PostPosted: Mon Jul 18, 2016 5:07 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
Can we see some pics of this car?
CommodoreCollector
PostPosted: Mon Jul 18, 2016 5:09 pm    Post subject: Re: Canadian Found 1950 Beetle Build Reply with quote
How about two
Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
