airschooled Air-Schooled
Posted: Sat Jun 11, 2016 11:53 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
WhirledTraveller wrote: |
Smurf wrote: |
This method might have worked for you but for me this was the worst method. This is what caused my bolts to get cross threaded. |
Sorry this happened to you but I don't think the technique is to blame. Done correctly the bolts can be started by hand without any load on them and you should be able to tell that they are started correctly and not cross-threaded.
Not to sound high and mighty though, I've cross-threaded bolts aplenty. Sucks. |
Yes, been there done that, (my lovely PO tapped my bumper bolt holes for standard threads uuughhhh) so I know the "feeling" in Volkswagen/Kamex bolts is usually always right. I trust these machines more than I trust people to tell me what is ailing them.
www.airschooled.com |
Smurf Samba Member
Joined: January 20, 2004 Posts: 914 Location: Colmar, PA
Posted: Sun Jun 12, 2016 6:34 am Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
cdennisg wrote: |
Smurf wrote: |
No, cross-threading the bolts and continuing to crank down on them caused your problems. Sorry you had these issues, but others have done this job many times without ruining the bolts or the hole threads. |
Don't mean to disrespectful but this method did not work for me. There are more simple methods than cranking down on a torsion cover without a bushing to achieve what you're trying to do which is getting the spring plate over the stop.
That is an extreme amount of pressure for those bolts to handle.
You find this easy to do it this way and I find it easy to do another way. Blaming me for my practice over yours isn't solving anything and it counter productive to not only me but others who are doing this job.
Find a method that works for you is all I'm trying to say. _________________ 1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sun Jun 12, 2016 8:38 am Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Smurf wrote: |
cdennisg wrote: |
Smurf wrote: |
Find a method that works for you is all I'm trying to say. |
You misunderstood what I said. the method didn't cause your bolts to get cross-threaded. Starting the bolts incorrectly and continuing to force them into place caused that. It has happened to all of us at times. Just gotta be careful.
We are all glad that you finally were able to solve the issue. _________________ nothing |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Fri Jul 22, 2016 10:54 am Post subject: Re: VW factory installed the lighter duty torsion bars |
patayres wrote: |
Interesting development today: I think my Westfalia left the VW factory in Hanover with the lighter duty torsion bars. The undercarriage still has the dealer undercoating including the spring plate cover. The paint underneath the undercoating is perfect... I'm pretty sure that the spring plate covers have never been off. Not to mention the state of the doughnut bushings - old, ovaled, and with the VW emblem and part #.
Here is the right torsion bar:
I am in the process of replacing my torsion bushings and had planned to install adjustable spring plates as well, however, the spring plates that I rec'd were too big for my torsion bars, which are also 26.90mm diameter (edited: actually, after removing them they measured 26.29mm so assume they are the 26.20mm spec). Clearly the spring plate maker assumed that my bars were the larger ones as well. _________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
kevin77westy Samba Member
Joined: November 12, 2004 Posts: 795 Location: Ocean Springs, MS
Posted: Wed Dec 28, 2016 8:53 am Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Going thru this process now on my 77 Westy and this thread has been extremely helpful.. My M14 bolts that hold the bearing hub to the spring plate/trailing arm did not fair well when removed. I just measured mine and contrary to an earlier post my short ones are 35mm in length, not 28mm. They just barely protruded from the assembly when installed so a shorter bolt will not work. Just wanted to post it up in case it helps some other poor sole with buggered threads. These are M14 x 1.5 (fine thread) grade 10.9.
Short bolt is 35mm and long one is 95mm. https://www.thesamba.com/vw/gallery/pix/1589782.jpg
I found replacements (35 and 100mm, 10.9 grade) and matching tap at Belmetric. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Dec 28, 2016 11:07 am Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Smurf wrote: |
A technique to save your sorry-ass cross-stripping disaster is to quit trying as soon as you know it is screwed up. Disassemble.
Start a well-greased "mule" bolt from the other direction, under the car, and run it in until it is protruding from the hole. Then, start one of your final bolts from the outside without the cover plate in the way, and work it until the bolt and the hole understand each other.
(this technique has worked especially well for some of the cross-threaded disasters in relay arms when replacing center pin bushings)
Upon reassembly, do NOT press the cover plate fully onto the bushing, just let it loosely hang and get one bolt started, just one. Bottle jack the wheel bearing housing up just enough to unload the spring plate from the stop a barely at all. Then get your mighty visegrips to pull the opposite side of the cover in close enough to start another bolt. The alignment will be off. Now get you brake adjusting spoon or other prying implement to pry the cover slightly up or down to line up the holes. My easiest installation seems to be upper forward/lower rear/lower front/upper rear.
With these new bushings seemingly smaller the factory originals, I have not had to fight these covers for fifteen years now.
Colin
this bushing is beginning to show signs of wear:
_________________ www.itinerant-air-cooled.com |
Posted: Wed Dec 28, 2016 11:13 am Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Amskeptic wrote: |
Who supplies the best bushings in your opinion?
Posted: Wed Dec 28, 2016 11:18 am Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Wildthings wrote: |
I barely tolerate in-house Wolfsburg West replacements, and tell myself that I am lucky I can even get them at ALL.
Colin _________________ www.itinerant-air-cooled.com |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Wed Dec 28, 2016 12:15 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Will old bushings cause the rear suspension to sound creaky/squeaky when the Bus is loaded?
I had forgotten about having not heard it since the summer, but in the '73 when it is full of people the rear suspension gets noisy. The shocks are only a year or two old, so I doubt that is the issue. _________________ Dave Cook
1973 Wild Westerner
My Thing |
wcfvw69 Samba Purist
Posted: Wed Dec 28, 2016 1:00 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
vwwestyman wrote: |
I had forgotten about having not heard it since the summer, but in the '73 when it is full of people the rear suspension gets noisy. The shocks are only a year or two old, so I doubt that is the issue. |
If your spring plate bushings are original, then they are wasted and should be replaced. Yes, they will make all sorts of racket especially if they are worn through like the pics above.
You need to also look at the rear lower control arm that connects to the bearing housing. It has a bushing in there as well. Most of the time, that bushing is ok though.
You could load the bus and have folks move up and down while it's parked in the driveway try to identify where the noise is coming from too. My guess would be the spring plate bushings. _________________ Contact me at [email protected]
The Samba member since 2004.
SGKent Samba Member
Posted: Wed Dec 28, 2016 2:10 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
originals still come up packed in that spray stuff that protects them. They may be harder to work with but think of them more like poly when they get harder. Use lots of real talc when installing them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Dec 28, 2016 3:26 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
SGKent wrote: |
originals still come up packed in that spray stuff that protects them. They may be harder to work with but think of them more like poly when they get harder. Use lots of real talc when installing them. |
Are you saying that the VW dealer parts network still can get the bushing or who? |
SGKent Samba Member
Posted: Wed Dec 28, 2016 6:38 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Wildthings wrote: |
SGKent wrote: |
no - gotta watch for them in classifieds and in Europe on Ebay etc. Be sure they are in the factory box. The part also fits splits so lots were made sold in both blue box and white audi box 211 511 245 A. FWIW Some folks still list them as genuine VW so they may be available thru VW Heritage, Paruzzi etc. This is the torsion bushing. The "rear"arm bushing 211 501 121 is still available if one watches for them too. Most retail sites show repops though on those. NOS still come up. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Mar 02, 2017 7:38 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Finished this job a couple weeks ago (had some unexpected delays) and thought I would add some of my experiences. I used bushings from BugHaus - they had FAG bearings so I figured I'd give their bushings a shot while I was ordering. Here's the side to side comparison of the 2 drivers side old ones and vs 2 new ones. They seemed like good quality to me.
I dove into this job because of an annoying squeak from my rear end. My bushings were in pretty good shape compared to some but I found the source when I pulled the driver's side bushing cover:
As far as removing the spring plates, I had no luck just prying the spring plates out. I saw old posts and youtube videos that made it look easy and even saw one post that said to "gently pry" them out. Mine were in there good. I ended up using my biggest cold chisel and a 12" pry bar as a wedges from different angles and banged them behind the spring plate to get it started. Once it moved a little then the gently prying came into play. I did scratch the paint a little doing this so I cleaned up the area and hit it with clear coat to keep the rust at bay.
On installing the torsion cover plates - I went with the no outer bushing technique and used the cover plate to push in the spring plate and inner bushing - worked great - just gotta keep it all in the same plane. Once the spring plate was near home I pulled the cover and installed the outer bushing. I tightened the cover bolts in a cross pattern a little at a time to keep things straight.
And a pic of the completed rear end. Can't wait to drive! Waiting on a replacement drum - one of mine chipped a rim in delivery. ts always something.
Posted: Thu Mar 02, 2017 8:00 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
kevin77westy wrote: |
Also wanted to update this post. When removed my hub bolts they had no washers. I had a hard time figuring out which washers were correct (some reading indicated they might be spring washers) but I ended up with10.9 grade flat washers which were pretty thick. The 100mm bolts handled these washers fine but they were too thick for the 35mm bolts (was a couple threads short of coming thru the hub holes) so I did not use washers on those - I needed 40mm. Might replace them but not too worried about it. 95ft/lbs is pretty good torque and they never came loose before.
BusPriest Samba Member
Joined: October 08, 2014 Posts: 420 Location: Denver, Co
Posted: Thu Mar 09, 2017 5:08 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
I sure had a frustrating morning and afternoon. I have read this is a 2-3 hour job. Well i spent 7 hours on one side... that included a few trips to the store.
So I am lifting the rear to go along with my bigger tires and fix the saggin rear.
I pulled it all apart and the bushing looked in decent shape so I didnt plan on changing them. My original angle was 23* after compensating for the angle in the driveway. I regeared to have an angle of 30*
Heres the issue i have. I cant get the arm back far enough to stay on the stop. I did get it on once, but the hub would not bolt on, as the arm wasnt pushed in far enough onto the inside of the bus.
The method i have been using to put it on is pushing the index bar in all the way so that the bar is fully on on the inner splines, then put on the plate and put on 3 screws. Then jack it up to be above the stop bump. Then tighen the 4 bolts on the plate in and it will push it on, but not push it on enough. When the jack is let down, it slides off the bump.
I have tried messing around with the jack, sliding it all around. Hitting the arm with a 4lb mini sledge, hitting a block of wood on the splines. Lots of Johnson & Johnson baby talc.
Any suggestions?? This is suppose to be an easy job
_________________ 1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest. |
Posted: Thu Mar 09, 2017 5:47 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Maybe your old inner bushing is deformed and will not let it get where it needs to be? |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Thu Mar 09, 2017 6:07 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
Try bolting on the hub and torque arm,the arm should hold the spring plate inward and prevent it from slipping off the stop.
You may need to use longer,smaller bolts with nuts and washers to get the torque arm to line up on the hub,use 2 of them where the vw nuts and bolts go,[a good clamp may also work]when it's lined up install and tighten the 2 short bolts that screw into the hub.
GoodLuck,have fun;Nelson. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
Posted: Thu Mar 09, 2017 6:14 pm Post subject: Re: Spring Plate Angle/Torsion Bar Adjustment (Pics Added) |
lil-jinx wrote: |
GoodLuck,have fun;Nelson. |
For this, The CV joint would have to be taken off, which is fine... but the issue would be to get it all together with the arm on the jack. it wouldnt be able to match up _________________ 1977 Champagne Transporter Custom Camper.
Not a Priest. |
