kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Fri Jul 22, 2016 6:12 am Post subject: Using a 0231172019 Distributor |
I am currently using a 009 Distributor in my 2 liter type iv motor and i've got a line on a 0231172019 from a 914 (it has a vacuum advance that i'm hoping will help me with the "flat spot" of the 009. My question is does anybody have this setup in there motor? _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
Bleyseng Samba Member
Posted: Fri Jul 22, 2016 6:22 am Post subject: Re: Using a 0231172019 Distributor |
Yes it will help as the 009 has only 17 degrees of advance. Set the 914 dizzy at 28 degrees @ 3500rpms with the no hose to the vacuum advance. Then add on the hose to see that it runs up to 30 plus degrees of advance. Don't hook up the vac retard _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Fri Jul 22, 2016 6:36 am Post subject: Re: Using a 0231172019 Distributor |
Ok cool. I'm getting some conflicting info on the points/Condensor is it the same or different than a 009? _________________ 1976 Type II Westy P22
Posted: Fri Jul 22, 2016 7:32 am Post subject: Re: Using a 0231172019 Distributor |
I don't recall _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jul 22, 2016 4:24 pm Post subject: Re: Using a 0231172019 Distributor |
points, condenser, cap and rotor are the same as the 009 on that distributor. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
