busdaddy Samba Member
Joined: February 12, 2004 Posts: 52725 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 30, 2007 5:50 pm Post subject: Fan shroud pull, what if the studs were out? |
My oil filter adaptor gasket on the GE engine in the 72 has started leaking and the fan shroud has to come off.
Has anyone tried removing the shroud mount studs in place so you don't have to drop the exhaust?
It looks to me if I can get the studs out I can lift the shroud up out of the HE's and not have to open up my non leaky exhaust system. Looking for previous experience here so I don't have to learn the hard way. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Mon Jul 30, 2007 9:19 pm Post subject: oil leak |
Busdaddy, I think it would be worth a try,Since i never tried it..lol..and yeah it's a pain to pull off the 3/4 heater box along with the muffler and etc..But the studs for the fan housing are in there pretty tight too.give it a try and let us know.. _________________ V.W.owner since 1967 |
Posted: Wed Aug 15, 2007 7:30 am Post subject: |
Well, it WORKED !
The first stud came out without a fight (double nuts), and another saw it my way with a few tries, last 2 needed a weld on the end and came right out.
Pulled the alternator and the upper bracket (left alternator sitting on the HE).
Slacked off the left HE hanger and removed the bolt for it and the oil cooler support.
Shroud comes back 1/4" and lifts straight up in one piece.
Off to the store today for replacement bolts (will post size).
And my exhaust system is undisturbed, wooohoooo. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Aug 15, 2007 12:48 pm Post subject: fan housing |
Busdaddy, That's Awesome! Its great to beat flat- rate _________________ V.W.owner since 1967 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13468 Location: West Coast, USA
Posted: Wed Aug 03, 2016 10:59 am Post subject: |
busdaddy wrote: |
Off to the store today for replacement bolts (will post size).. |
Did you ever make it back from the store? Or should we send out a search party. It's likely the museum would like your frozen carcass, but I would like to know the bolt sizes…
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42384 Location: at the beach
Posted: Wed Aug 03, 2016 11:37 am Post subject: Re: Fan shroud pull, what if the studs were out? |
Robbie - the real question is did the REAL BusDaddy get back from the store? We could have an imposter. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Wed Aug 03, 2016 11:50 am Post subject: Re: Fan shroud pull, what if the studs were out? |
Damn, there's nothing that bugs me more than when some idiot starts a thread and doesn't finish it up, WTF?
The holes in the case are 25mm deep, the shroud is 15mm thick at the bolt holes, allowing for the lack of threads at the very bottom of the holes I'll guess the bolts should be ~35mm long.  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1414 Location: Cambridge, MA
Posted: Thu Aug 04, 2016 9:46 am Post subject: Re: Fan shroud pull, what if the studs were out? |
Wow this is an old thread!
I didn't have a welder when I pulled my studs so I just took a pair of vice grips and made a mangled mess of the threads on the end of the stud, hence "capturing" the nut. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23776 Location: NYC/Upstate/ROW
Posted: Thu Aug 04, 2016 12:15 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
I don't remember being alive 9 years ago, let alone a thread. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1603 Location: Indianapolis, IN
Posted: Thu Aug 04, 2016 1:29 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
I did thid when i changed my cooler awhile back, highly recommend pulling the studs for bolts. Another practical upgrade that will shows its merit if you ever need to remve the shroud with the engine in place.
Im sure just an oversight by those, 'not to be questioned genuis' VW engineers....  _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
SGKent  Samba Member
Posted: Thu Aug 04, 2016 2:01 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
one possibility is that studs do a better job of locating things than bolts do. The other is when one strips it can be replaced while repairing the threads that hold a bolt requires considerably more work. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Aug 04, 2016 3:46 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
There's a fairly big load on those when the bus has A/C installed, perhaps they were anticipating the future? or maybe it's just easier for production and no thought was given to future maintenance scenarios?
Mine haven't stripped yet, but if they ever do then I'll add some inserts on all 4. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 04, 2016 4:38 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
False alarm; the fellow I caught spewing oil didn't need the pull, but thanks for the info!
I'm sure the studs were used because the aluminum is a "softer" metal in terms of mounting something like that. Always studs when mounting to softer metal, especially when locating it might be awkward. SGKent; did your Spiders have the 27-thousand oil pan bolts when studs would have added years to your life? gotta love trying to stack your gasket and sealant and also line up invisible holes upside down.....
www.airschooled.com
75 Westy FI noob Samba Member
Joined: November 04, 2022 Posts: 430 Location: MidWest
Posted: Tue Jan 17, 2023 3:27 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
So, I thought about it.. and given that i am older now, decided to take it out in pieces and easy. So, i dropped the exhaust and removed the filler neck from the block. came off easy then as you would imagine.
Def needed cooler seals, but prob needs more. looks like the main seal is bad here. Or, might all be from the cooler (and pressure sender)?
Gonna need more degreaser and time. Super dirty.
And ive put a lot degreaser on that (pic) already.
Note: i wiped it clean under the flange. Its not washed clean from oil.
Whole thing was black dirt nd oil.
Tempted to chnge filter mount gasket too.
would run it to check for leaks… but, no exhaust.
any links/tips to change that seal?
Posted: Tue Jan 17, 2023 3:45 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
75 Westy FI noob wrote: |
any links/tips to change that seal? |
https://www.thesamba.com/vw/forum/viewtopic.php?t=703084&highlight=fan+seal
I'd change the filter mount gasket while it's apart just because it'll never get easier to reach, and it's likely 48 years old.
You can run it without the exhaust and fan for 3-5 minutes idling in the driveway at a time, it just depends on your neighbours tolerance for you, shovelled their driveways or brought them cookies lately?. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jan 17, 2023 5:42 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
I get some sideways looks wrenching on my cars ..
Theyd flip at straight exhaust. But im dying to hear it. |
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 287 Location: East Tennessee
Posted: Tue Jan 17, 2023 10:07 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
Take notice of how tight the nuts holding the oil filter mount are. It's easy to over tighten them and crush the gasket. Maybe stagger the tightening. Check the thermostat cable pulley bolt also, it's a through bolt and as we all know, oil leaks travel. _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
SGKent  Samba Member
Posted: Tue Jan 17, 2023 11:22 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
I rebuilt a T4 engine in 2009. Treated the paper gasket for the oil filter holder with gasgacinch. Let it dry. Bolted it up and torqued it. All was fine. 30 minutes later I am working in the garage on something else and I hear a pop-crack from the engine. The gasket blew out and that caused a stress fault along the area where the gasket blew out. The crack was the filter mount breaking along that area the gasket blew out. Since then I mount the gasket dry. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Wed Jan 18, 2023 10:56 am Post subject: Re: Fan shroud pull, what if the studs were out? |
Thanks for the advice guys. I will use dry paper gaskets.
Does the oil pressure sender have a crush washer to replace?
Do they leak from ‘the threads’ or from the switch itself?
Bad as these oil leaks look… the (automatic) transmission is similar.
Guessing the seal is gone on it too. Really trying not to pull both out, but.. not looking good. Can the main seal on the trans be done in the bus? Idk what makes the Torque Converter difficult, but I believe it.
Last edited by 75 Westy FI noob on Wed Jan 18, 2023 12:58 pm; edited 1 time in total |
Posted: Wed Jan 18, 2023 12:47 pm Post subject: Re: Fan shroud pull, what if the studs were out? |
SGKent wrote: |
The gasket blew out and that caused a stress fault along the area where the gasket blew out. |
Thats wild.
any advice for removing a 40yr old gasket? (Oil fill tube gasket). |
