asaph Samba Member
Joined: August 01, 2016 Posts: 9 Location: New England
Posted: Fri Aug 05, 2016 7:08 am Post subject: Digijet controller locations? |
| I'm trying to locate the FCU and ICU modules on my '84 westy 1.9l T3. |
ohhorob Samba Member
Joined: September 26, 2013 Posts: 217 Location: Santa Cruz
Posted: Fri Aug 05, 2016 8:08 am Post subject: Re: Digijet controller locations? |
| asaph wrote: |
The Bentley book is the bible for the T3/Vanagon.. worth having a copy to reference.
Follow the big bundle of wires from the injectors and sensors around the engine bay, back to the big metal box. And I believe the standard/common term for the Digijet itself is the "ECU". (Bentley 24.31 just calls it "Control unit").
Ignition control unit a.k.a. "Hall control unit" (Bentley 28.28 ) should be near the coil on the driver-side wall of the engine bay. _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10291 Location: Mt Lemmon, AZ
Posted: Fri Aug 05, 2016 8:26 am Post subject: Re: Digijet controller locations? |
Look for the ECU just forward of the left hand tail light:
And the Ignition Control towards the left front side of the engine bay:
If you remove that module you'll want to use some special paste behind it to assure good conductivity with the heat sink. 'Special' but I have heard that even toothpaste will work well enough. |
asaph Samba Member
Posted: Fri Aug 05, 2016 9:07 am Post subject: Re: Digijet controller locations? |
| Thanks for the pics! my plan was to Deoxit the connectors on both units. |
