V8 Bug Volksrod Project
Page: 1, 2, 3  Next
TheGreenVW
TheGreenVW is offline
PostPosted: Fri Jul 22, 2016 6:06 am    Post subject: V8 Bug Volksrod Project Reply with quote
This has been on hold for a while now....but finally going back together.
The Video Build Series, to date, is here:
https://www.youtube.com/playlist?list=PL8xzCtTkH46aTgU1sOSh8VZOV52aD9irG
Latest chapter here:
TheGreenVW
PostPosted: Mon Aug 08, 2016 1:54 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Progress fabricating and installing the clutch pedal and master/slave cylinders and relocating the engine mounts.
Rough Clutch Pedal will be shaped and trimmed to match brake pedal
http://www.BenModified.com
TheGreenVW
PostPosted: Wed Aug 10, 2016 6:29 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
andk5591
andk5591 is offline
PostPosted: Thu Aug 11, 2016 4:15 am    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Nice work. Applause
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
TheGreenVW
PostPosted: Sat Aug 13, 2016 8:08 am    Post subject: Re: V8 Bug Volksrod Project Reply with quote
andk5591 wrote:
Nice work. Applause
Thanks!
TheGreenVW
PostPosted: Sun Aug 14, 2016 2:15 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Since repositioning the engine, the customs headers no longer fit. I cut the flange off and inserted some filler tubing. The modified area will be wrapped in heat wrap.
TheGreenVW
PostPosted: Mon Aug 15, 2016 3:13 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Progress on the headers
Machine Dr.
Machine Dr. is offline
PostPosted: Tue Aug 16, 2016 3:54 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
I am studying these pictures very closely and putting them to good use. Keep them coming!
The Truth can be brutal, but a lie is worse.
TheGreenVW
PostPosted: Tue Aug 16, 2016 7:20 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
I'll do my best.
Leak tested the headers today, fixed a few pin holes. applied a coat of high temp paint and wrapped them in insulation.
TheGreenVW
PostPosted: Fri Aug 19, 2016 3:10 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Driveshaft is installed. Fits very well.
Also got a set of headers for a very good price that I had ordered a while back. They do give me more clearance around the master cylinder, so no insulating wrap needed, but I really like the look of the roadster headers
For comparison
eyetzr Premium Member
eyetzr is offline
PostPosted: Fri Aug 19, 2016 3:19 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Maybe a combination of both. Project is looking great.
I think he meant "rare", as in "not well-done"
TheGreenVW
PostPosted: Wed Aug 24, 2016 4:37 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Finished drilling and air hammering off some of the left over metal from what has become the driveshaft tunnel
Fitting the tunnel so that it does not interfere with the bench seat sliding motion
Also cut out a large rust hole and welded in a new panel
TheGreenVW
PostPosted: Thu Aug 25, 2016 2:20 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Welded in the driveshaft tunnel today along with more rust repair
TheGreenVW
PostPosted: Thu Aug 25, 2016 8:15 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
TheGreenVW
PostPosted: Sat Sep 03, 2016 5:54 am    Post subject: Re: V8 Bug Volksrod Project Reply with quote
I spent some time chasing the body mount threads with a tap and bolting it down.
Still working on some rust repairs. At some point. the previous owner filled all the body cavities with expanding spray foam which held water and caused rust. This was main reason for having it sandblasted. but unfortunately, there is still some foam in hard to reach places. such as under the rear side glass. That said, instead of welding up the rust pin holes which may cause a fire or release of toxic gas, I decided to use something call Strong Steel Stik from LPS. I worked well and make a strong enough repair.
The lower sections of the door were also filled with foam but stripped clean with the blasting. Passenger side wasn't too bad but the drivers door will need some new metal both inside and out.
TheGreenVW
PostPosted: Tue Sep 06, 2016 4:48 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Spent some time shaping and installing some sheet metal to replace the inner and outer lower door
Inner door frame work
I used a width of sheet metal and used a piece of threaded rod to get the correct rough shape
Then used a piece of flat stock in the correct width to make the channel more square
Welded in all in
Just needs a skim coat of body filler
TheGreenVW
PostPosted: Wed Sep 07, 2016 7:18 pm    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Door is done.
TheGreenVW
PostPosted: Sun Sep 11, 2016 10:53 am    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Rust repairs on both doors are complete. Re-installed them this morning
Prior to removing the doors, I drilled a small hole thru the hinges, the body and the backing plates to make re-assembly and alignment easier. It worked very well, I was able to re-install the doors by myself with the help of a floor jack and a couple of drill bits. I tightened them down and they shut properly on the first try!
Machine Dr.
PostPosted: Mon Sep 12, 2016 9:25 am    Post subject: Re: V8 Bug Volksrod Project Reply with quote
That is a great idea. I may have to try that.
TheGreenVW
PostPosted: Thu Nov 17, 2016 5:43 am    Post subject: Re: V8 Bug Volksrod Project Reply with quote
Currently replacing all the brake lines and the master cylinder
Page: 1, 2, 3  Next
