1978 Westy Full Restoration with Matching Custom Trailer
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
scirocco_crazy
scirocco_crazy is offline
PostPosted: Sun Aug 14, 2016 8:21 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
how about some air conditioning talk? this unit is a 6000 btu model with a super high seer rating. the fit is very snug but I wanted the end result to look factory installed. when the unit is running its really quiet and belts out some serious cold air. I used the exact dimension of the piece of glass I removed so that a factory window seal will work of it ever needs to be removed. What do you think?
[img]
[/img]
[img]
[/img]
Current Build 1976 VW Bus Subaru with EZ36 https://www.thesamba.com/vw/forum/viewtopic.php?p=9443081#9443081
Second Current Build 1979 Porsche 911SC
https://www.thesamba.com/vw/forum/viewtopic.php?p=10117349#10117349
Previous Builds 78 Westy with matching trailer
http://www.thesamba.com/vw/forum/viewtopic.php?t=589790&highlight=westy
78 Bay with Acura 3.2 Type S engine
http://www.thesamba.com/vw/forum/viewtopic.php?t=516038&postdays=0&postorder=asc&start=0
scirocco_crazy
PostPosted: Sun Aug 14, 2016 8:23 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
To Keep water from coming in during a rain I will have a magnet panel that will attach to the scoop portion
scirocco_crazy
PostPosted: Sun Aug 14, 2016 8:33 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
now that the a/c unit is installed I went on to building a device to catch the condensation produced during operation. This will be installed at the base of the mounting plate. The photos will show what I am yacking about.
I will install it tomorrow.
[img]
[/img]
newstarr
newstarr is offline
PostPosted: Sun Aug 14, 2016 9:26 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
This is so amazing!!!! You are making me want to take a welding class!!!
scirocco_crazy
PostPosted: Mon Aug 15, 2016 5:51 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Thank you, It has taken me years to learn how to do it. and yes I still mess up from time to time
scirocco_crazy
PostPosted: Mon Aug 15, 2016 6:03 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
suspension update, due to a trailer tow need I felt that Koni's on the rear wouldnt work with a heavy load so I put in air shocks so that they can be leveled depending on the load. I put a schrader valve port under the rear seat that can be hooked up to a small compressor. Up front I did opt for a pair of koni shocks, while I had the front on jack stands I dropped out the front beam and welded in a wagenswest beefcake adjusters to lower her down. After that I finished it off with new ball joints, rotors, brake lines, and calipers thanks to The Bus Depot. The new large diameter sway bars (front and Rear) help out the ride. I also installed the lowering plates in the rear from Nate at Wagenswest. By the way his products are some of the best I have ever used.
Last edited by scirocco_crazy on Thu Aug 25, 2016 12:30 am; edited 1 time in total
scirocco_crazy
PostPosted: Thu Aug 18, 2016 12:26 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Here is a quick video of the almost finished air conditioning and refrigerator install. enjoy
chabanais
chabanais is offline
PostPosted: Thu Aug 18, 2016 2:40 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Clean install!
"I spud therefore I yam."
Hikelite
Hikelite is offline
PostPosted: Fri Aug 19, 2016 10:21 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
What a great build.
I hope my wife doesn't stumble upon this, or I'll have to figure out how to add AC to our bus :p
So I take it you don't plan to do a lot of off road type camping since you lowered it, huh?
Love the whole build. The only thing I can't wrap my head around is a lowered Westy. I guess there are plenty of places to camp that don't need high clearance. *shrug* to his own. It does LOOK great! Just confusing to my eyes. lol
Hope you're health is still improving. Thanks for sharing your project. Beautiful work.
~Kevin
My 1968 Campmobile
scirocco_crazy
PostPosted: Sun Aug 21, 2016 9:05 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Hikelite wrote:
What a great build.
One of the best things about the Wagenswest kits are the fact give an afternoon you can return it to stock height. Best of both worlds
scirocco_crazy
PostPosted: Sun Aug 21, 2016 9:07 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Tonight I installed what I hope will be a great addition to the bus. Its the Empi Heavy duty rear sway bar. Pretty straight forward install.
[img]
[/img]
scirocco_crazy
PostPosted: Thu Sep 01, 2016 4:06 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
I put together a video illustrating the build from day 1 to the finish. I had music to go with it but due to youtube copyright concerns they muted it. No worries. Enjoy
BusPriest
BusPriest is offline
PostPosted: Thu Sep 01, 2016 6:30 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Can the A/c run off the house battery?
1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest.
Tcash
Tcash is offline
PostPosted: Thu Sep 01, 2016 9:34 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Nice video. I added to:
Youtube Videos
Thank you
Tcash
brettsvw
brettsvw is offline
PostPosted: Sun Aug 13, 2017 8:48 am    Post subject: Reply with quote
scirocco_crazy wrote:
Fella's, here it is. I must say I love it!
[img]
[img]
[/img]
[/img]
Trailer is fantastic. Love the fact you can see the torsion housing covers.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
MorkC68
MorkC68 is offline
PostPosted: Sun Aug 13, 2017 1:18 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
excellent build thread, that's one stunning westy you have Very Happy
Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
My blog: https://twolatebays.wordpress.com/
Page 9 of 9
