Sodo Samba Member
Joined: July 06, 2007 Posts: 9606 Location: Western WA
Posted: Fri Aug 19, 2016 2:45 pm Post subject: Larger SVX oil filter fits on EJ25 (just an FYI) |
Having a cut oilpan (Subaru EJ25) a larger filter means more oil in the system which will help (just a little).
This post is to provide confirmation that it fits (with Smallcar.com engine bracket).
If anyone knows of an even larger filter that's just "better!" Please share, I'd run that next time.
Photo of larger 1334 SVX filter on an EJ25 motor.
WIX 57356 is the normal filter for an EJ25.
NAPA Gold filter 1334 is the SVX filter.
I don't know if it fits EJ22. Maybe someone with an EJ22 can confirm. _________________
....KTMs, GasGas, SPOT mtb |
Wolfram Samba Member
Joined: June 23, 2005 Posts: 184 Location: Waiheke Island/On The Road USA
Posted: Fri Aug 19, 2016 5:44 pm Post subject: Re: Larger SVX oil filter fits on EJ25 (just an FYI) |
The EJ filter is tiny.......I have often thought. _________________ 88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat Aug 20, 2016 8:08 am Post subject: Re: Larger SVX oil filter fits on EJ25 (just an FYI) |
I use the NAPA Gold 1344, made by Wix. IIRC the Wix version is 51344.
I did the volumetric calculations a long time back but it holds a lot more oil than the OEM without hanging down too low. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
kalispell365 Samba Member
Posted: Sat Aug 20, 2016 1:11 pm Post subject: Re: Larger SVX oil filter fits on EJ25 (just an FYI) |
EJ22 and EJ25 filters all interchange, the OG EJ22 filter (15208AA060) was much larger than the 2.5 filter. Denso makes the larger filter, its the highest quality Japanese made filter out there. I try and steer clear of American filters on my van as well as my customers Subaru vehicles. I have seen several motors go away using square cut filter seals like those on the US style filters.
https://www.amazon.com/Denso-150-1006-Oil-Filter/d...oil+filter
Current production factory blue Subaru filters are made by Fram(!) and are total garbage, even the dealers are having troubles with them. I wont even use them on my old shop car. _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
akspietz Samba Member
Joined: July 04, 2016 Posts: 10 Location: Bozeman, MT
Posted: Sat Aug 20, 2016 3:45 pm Post subject: Re: Larger SVX oil filter fits on EJ25 (just an FYI) |
All Subaru filters have the same thread pitch and o ring diameter. The only difference is capacity and, I believe, different drain back valves. Many people run the larger capacity H6 filters on there turbo cars. |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Sat Aug 20, 2016 5:25 pm Post subject: Re: Larger SVX oil filter fits on EJ25 (just an FYI) |
This is all very good to know. Great post! _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
Posted: Sun Aug 21, 2016 12:16 pm Post subject: Re: Larger SVX oil filter fits on EJ25 (just an FYI) |
Another tidbit. The reason they went to the smaller filter a dozen or so years ago was certain models started coming with a ridiculous cumbersome exhaust manifold that surrounded the filter entirely. The larger filters were too tight to reach for service and I assume too heated up by the manifold. Subaru then superseded all the early filters to the smaller one, even for the EJ22.
