jrailer Samba Member
Posted: Tue Nov 03, 2015 8:47 pm Post subject: |
I got my seats today and got a boy and girl set too. I had them shipped but I didn't get the support bar I thought it would come with it it said they came with mounting hardware |
dbsmith Samba Member
Posted: Thu Nov 05, 2015 8:43 pm Post subject: |
You should have gotten the support bar. If not it is just a piece of 3/4" black pipe with some tabs welded to it.
Let me know if you want some pictures..
Not any update on mine. Life has gotten in the way. I do open the garage door and smile at it now and then.
I'm so jealous your having so much fun with yours. Seen posts on FB. _________________ dbsmith
SoCal
#127 Manxter - 99.5% done.... |
Posted: Sat Nov 07, 2015 9:05 pm Post subject: |
Bar showed up the next day |
TSFR Samba Member
Joined: May 14, 2013 Posts: 365 Location: Columbia, SC
Posted: Tue Feb 16, 2016 1:02 pm Post subject: Re: Manxter #127 -Build |
Hey David, I hope everything is going well with you! I'm curious what steering column you went with and what wheel adaptor you used for the beautiful MOMO steering wheel.
Thanks!
Jeff _________________
Thanks,
Jeff
Manxter 2+2 #160 |
Posted: Thu Feb 18, 2016 12:03 pm Post subject: Re: Manxter #127 -Build |
any update on the build Dave? |
Posted: Sun Mar 20, 2016 3:08 pm Post subject: Re: Manxter #127 -Build |
Wow, guess I've been out of touch for a while. Life still been way too busy to play with her. Hopefully by summer time. She does wimper ever time I open the garage door.
Jeff, your making good progress. I used the flaming river column with adapter K2401. But there is about a 1/4 " gap between column and adapter. Will need to play with it more.
Jim. You've been taking some great photos of ours. Glad you loving it. _________________ dbsmith
SoCal
Posted: Sun Jun 26, 2016 4:16 pm Post subject: Re: Manxter #127 -Build |
Well
Life has calmed down a bit so it's time I got after it again. Got the side bars done, front seat belts installed and the dash finished up.
SoCal
sbussard Samba Member
Joined: April 19, 2011 Posts: 432 Location: Pittsburgh, PA (near enough)
Posted: Tue Jun 28, 2016 4:14 am Post subject: Re: Manxter #127 -Build |
It's going to be fun pegging that speedometer!
Looks great! _________________ Manxter #122
First time, garage built, and living out the childhood dream of owning a life-size Hotwheel!
Check out my build thread-->My Manxter 2+2 |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Tue Jun 28, 2016 10:39 pm Post subject: Re: Manxter #127 -Build |
Looks great. How did you attach the seat belts to the roll bar? |
Posted: Thu Jun 30, 2016 7:30 pm Post subject: Re: Manxter #127 -Build |
It's a threaded rod welded in. Think called a 'Bung'. Uses the seat belt thread 7/16 fine.
Turnkey Manx may still sell them. _________________ dbsmith
SoCal
JCockrill Samba Member
Joined: January 14, 2016 Posts: 33 Location: Charleston, SC
Posted: Sat Jul 02, 2016 9:18 am Post subject: Re: Manxter #127 -Build |
I have a type 1 mount and thought it would just be a bolt on situation. Where or what are these pads that are shown in your photo above? I have the original pads but they don't fit. I could cut them off but it wouldn't give me any horizontal restraint. It looks like this might be a specialty pad for this application? Anyone that can shed light on this for me would be greatly appreciated.
Thank you!
_________________ '15 Manxter on a '72 pan with '74 engine/trans/and axles. Just trying to work out the gremlins in the build |
jsturtlebuggy Samba Member
Posted: Sat Jul 02, 2016 1:48 pm Post subject: Re: Manxter #127 -Build |
For the rear transaxle mounts you need the 1972 and earlier style
#113-301-263 is the part number.
Seeing your signature you may have the later rear mounts that do not work. They are very soft.
Switching to the earlier mounts should be the fix. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Sat Jul 02, 2016 6:08 pm Post subject: Re: Manxter #127 -Build |
jsturtlebuggy wrote: |
Switching to the earlier mounts should be the fix. |
Thank you! It appears I do have the later mounts. Ordered the new ones today. Thank you so very much for your help!! _________________ '15 Manxter on a '72 pan with '74 engine/trans/and axles. Just trying to work out the gremlins in the build |
Posted: Sat Jul 09, 2016 6:04 pm Post subject: Re: Manxter #127 -Build |
So,, while everyone is playing in Big Bear, the wife was gone, so I had a good buggy day in the garage. I got the gas tank installed along with reserve valve, front bumper bolted in, rear license plate install with LED lights, and bracket made for horn. I dropped off my old engine case at Topline in Anaheim this week to see if it salvageable and dropped off metal parts to be welded...I looked in my boxes and all the parts are about gone. Just a 1000 ft of wire.
Almost there...
David _________________ dbsmith
SoCal
Posted: Sun Jul 10, 2016 5:18 am Post subject: Re: Manxter #127 -Build |
Keep at it! You'll be driving soon! _________________ Manxter #122
Posted: Sun Jul 24, 2016 3:26 pm Post subject: Re: Manxter #127 -Build |
So a few week ago I got the gas tank installed along with the reserve valve.
And today I got a wild hair up my .... Got up at 5am (before it got to 100') And went crazy with the U-pol.
Spray the hood, engine cover and the rear seats. Now instead of boy and girl seats, I have uni-sex, so ther is no confusion on who sits where.
Really came out nice..I wish I would have flipped the body over and done the whole underside. And I was thinking with complaints about the black roof top being hot, how about if I spray the underside white or light gray?
JEFF ARE YOU PAYING ATTENTION.......
And now about ready to pull trigger on motor
David
SoCal
Posted: Sun Aug 21, 2016 8:06 pm Post subject: Re: Manxter #127 -Build |
Who says the kitchen table isn't a great place to wax the hood?
Should have seen her face when I said we needed to make room for the motor..
And just a few more pictures of progress
SoCal
Posted: Sun Aug 21, 2016 8:29 pm Post subject: Re: Manxter #127 -Build |
SoCal
Posted: Sun Aug 21, 2016 8:43 pm Post subject: Re: Manxter #127 -Build |
looking good |
Posted: Thu Sep 01, 2016 7:08 pm Post subject: Re: Manxter #127 -Build |
SoCal
